5th October 2009, 06:10 | #2201 | Link |
Hi Buzz,
Thanks for the comments. I will note and apply that. I have an trouble with the conversion. I convert the video and audio make so fast step (movie stop to move and continue in every second). Could you tell me what i've made wrong? Here avs file info: Code:
#HDConvertToX Avisynth Script # #Input File = z:\--= films hd =--\star wars episode1.mkv #Original Resolution = 1280x720 #Aspect Ratio = 1.7778 #Frame rate =25.000 #Number of Frames = 195834 #Lenght (hour:minutes:seconds) = 2:10:34 #Display Aspect Ratio = 2.3530 #Aspect Error = 0.0013 # #Resized resolution = 1280 / 544 #Crop Left = 0 #Crop Top = 88 #Crop Right = 0 #Crop Bottom = 88 # LoadPlugin("C:\HDConvertToX\filters\AddGrain.dll") LoadPlugin("C:\HDConvertToX\filters\AddGrainC.dll") LoadPlugin("C:\HDConvertToX\filters\asharp.dll") LoadPlugin("C:\HDConvertToX\filters\autocrop.dll") LoadPlugin("C:\HDConvertToX\filters\Average.dll") LoadPlugin("C:\HDConvertToX\filters\avss.dll") LoadPlugin("C:\HDConvertToX\filters\ColorMatrix.dll") LoadPlugin("C:\HDConvertToX\filters\deblock.dll") LoadPlugin("C:\HDConvertToX\filters\Decomb.dll") LoadPlugin("C:\HDConvertToX\filters\deen.dll") LoadPlugin("C:\HDConvertToX\filters\degrainmedian.dll") LoadPlugin("C:\HDConvertToX\filters\dfttest.dll") LoadPlugin("C:\HDConvertToX\filters\DGAVCDecode.dll") LoadPlugin("C:\HDConvertToX\filters\DGDecode.dll") LoadPlugin("C:\HDConvertToX\filters\DirectShowSource.dll") LoadPlugin("C:\HDConvertToX\filters\EEDI2.dll") LoadPlugin("C:\HDConvertToX\filters\ffms2.dll") LoadPlugin("C:\HDConvertToX\filters\FFT3DFilter.dll") LoadPlugin("C:\HDConvertToX\filters\FluxSmooth.dll") LoadPlugin("C:\HDConvertToX\filters\frfun7.dll") LoadPlugin("C:\HDConvertToX\filters\gradfun2db.dll") LoadPlugin("C:\HDConvertToX\filters\GrainOpt.dll") LoadPlugin("C:\HDConvertToX\filters\hqdn3d.dll") LoadPlugin("C:\HDConvertToX\filters\MSharpen.dll") LoadPlugin("C:\HDConvertToX\filters\mt_masktools-26.dll") LoadPlugin("C:\HDConvertToX\filters\mvtools.dll") LoadPlugin("C:\HDConvertToX\filters\mvtools2.dll") LoadPlugin("C:\HDConvertToX\filters\NicAudio.dll") LoadPlugin("C:\HDConvertToX\filters\nnedi.dll") LoadPlugin("C:\HDConvertToX\filters\RemoveDirtS.dll") LoadPlugin("C:\HDConvertToX\filters\RemoveGrainS.dll") LoadPlugin("C:\HDConvertToX\filters\RepairS.dll") LoadPlugin("C:\HDConvertToX\filters\SangNom.dll") LoadPlugin("C:\HDConvertToX\filters\SoundOut.dll") LoadPlugin("C:\HDConvertToX\filters\TBilateral.dll") LoadPlugin("C:\HDConvertToX\filters\TDeint.dll") LoadPlugin("C:\HDConvertToX\filters\TIVTC.dll") LoadPlugin("C:\HDConvertToX\filters\TTempSmooth.dll") LoadPlugin("C:\HDConvertToX\filters\UnDot.dll") LoadPlugin("C:\HDConvertToX\filters\UnFilter.dll") LoadPlugin("C:\HDConvertToX\filters\VSFilter.dll") LoadPlugin("C:\HDConvertToX\filters\yadifmod.dll") Import("C:\HDConvertToX\filters\BlindDeHalo3_mt2.avsi") Import("C:\HDConvertToX\filters\Deblock_QED_MT2.avsi") Import("C:\HDConvertToX\filters\GradFun2DBmod.v1.3.avsi") Import("C:\HDConvertToX\filters\Lem.avsi") Import("C:\HDConvertToX\filters\LSFmod.v1.8.avsi") Import("C:\HDConvertToX\filters\MCTemporalDenoise.v1.3.00.avsi") Import("C:\HDConvertToX\filters\MCTemporalDenoise.v1.3.09.avsi") Import("C:\HDConvertToX\filters\QMLF_3_motions.avsi") Import("C:\HDConvertToX\filters\QMLF_5_motions.avsi") Import("C:\HDConvertToX\filters\QMLF_7_motions.avsi") Import("C:\HDConvertToX\filters\QMLF_9_motions.avsi") Import("C:\HDConvertToX\filters\seesaw.avsi") Import("C:\HDConvertToX\filters\SoftSharpen.avsi") Import("C:\HDConvertToX\filters\spresso.avsi") Import("C:\HDConvertToX\filters\Srestore.avsi") #Source File AVCSource("C:\HDConvertToX\job0\movie.dga") #Applying Resizing LanczosResize(1280,544,0,88,-0,-88) #Insert Filters As Requested hqdn3d(1) AddBorders(0,88,0,88) Code:
eac3to v3.16 command line: "C:\HDConvertToX\applications\eac3to.exe" "z:\--= films hd =--\star wars episode1.mkv" 2: "C:\HDConvertToX\job0\hdencodertox-pid2.ac3" -normalize -down6 -slowdown -640 ------------------------------------------------------------------------------ MKV, 1 video track, 2 audio tracks, 2 subtitle tracks, 2:10:44, 25p 1: h264/AVC, English, 720p25 2: AC3, French, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB 3: AC3, English, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB 4: Subtitle (ASS), French, "forcé" 5: Subtitle (ASS), French [a02] The Nero decoder doesn't seem to work, will use libav instead. [a02] Extracting audio track number 2... [a02] Removing AC3 dialog normalization... [a02] Decoding with libav/ffmpeg... [a02] Remapping channels... [a02] Changing FPS from 25.000 to 23.976... [a02] Writing WAV... [a02] Creating file "C:\HDConvertToX\job0\hdencodertox-pid2.ac3.pass1.wav"... [a02] Clipping detected, a 2nd pass will be necessary. <WARNING> [a02] Caution: The WAV file is bigger than 4GB. <WARNING> [a02] Some WAV readers might not be able to handle this file correctly. <WARNING> [a02] Starting 2nd pass... [a02] Reading WAV... [a02] Encoding AC3 <640kbps> with libAften... [a02] Creating file "C:\HDConvertToX\job0\hdencodertox-pid2.ac3"... [a02] The original audio track has a constant bit depth of 64 bits. [a02] The processed audio track has a constant bit depth of 64 bits. Video track 1 contains 195834 frames. eac3to processing took 16 minutes, 32 seconds. Done. #An i check "put chapters every 5 minutes" and doesnt work in bluray players. i check it but not has worked. Version of HDC is the latest 2.2.492.3692 Thanks for your help.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
5th October 2009, 07:42 | #2202 | Link |
HDConvertToX author
your avs script don't have the convertfps.. (video is keep at 25fps, audio is slowed to 23.976)
also .. please post the make report BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
6th October 2009, 04:15 | #2206 | Link |
Funny story: After reinstalling Windows 7, I discovered Ripbot's Job1.avs from a couple pages ago
Here it is Code:
#MT #VideoSource LoadPlugin("E:\Programs\RipBot264\Tools\dgindex\DGDecode.dll") video=MPEG2Source("E:\temp\RipBot264temp\job1\job1.d2v") #Deinterlace LoadCplugin("E:\Programs\RipBot264\Tools\AviSynth plugins\Yadif\Yadif.dll") video=yadif(video,mode=0,order=1) #Decimate #Crop #Resize #Colors #Denoise #Subtitles #AudioSource LoadPlugin("E:\Programs\RipBot264\tools\AviSynth plugins\NicAudio\NicAudio.dll") audio=NicAC3Source("E:\temp\RipBot264temp\job1\job1 T80 2_0ch 192Kbps DELAY -16ms.ac3") audio=ResampleAudio(audio,48000) #DownMix #Delay audio=DelayAudio(audio,-0.016) #Tempo #Normalize audio=Normalize(audio,1) #AudioDub audio=ConvertAudioTo16bit(audio) AudioDub(video,audio) #Triming #AVSameLength Trim(0,165210) #ColorSpace |
6th October 2009, 07:31 | #2207 | Link |
HDConvertToX author
@whipdancer
"could" be a problem of audio.. look here http://forum.doom9.org/showthread.ph...423#post990423 this settings " -a_setting 440_48_6_16" seems to not fit.. you could try change to "-a_setting 440_48_6_24" or different values @Crono141 the ripbot log don't report anything strange, the audio lag seems introduced by eac3to process ... you could try forcing audio to use dss BHH
6th October 2009, 13:18 | #2208 | Link |
Did another encoding test with the same movie, preset Faster:
HdConvertoX with CRF 19, Preset Extreme Quality: Bitrate 1900 HdConvertoX with CRF 19, Preset Fast: Bitrate 2300 HdConvertoX with CRF 19, Preset Faster: Bitrate 3700 HdConvertoX with CRF 19, Preset Very Fast: Bitrate 6400 AutoMKV with CRF 20: Bitrate 3900 Preset Faster onwards have mb-tree disabled, which makes the bitrate and therefore filesize go much higher. I compared a few scenes and could not really see a difference between the different encodes. mb-tree really seems to be a massive step forward in video compression, couldn't believe that you get the same results with so much less bitrate... |
7th October 2009, 01:33 | #2209 | Link | |
I've tried several 6 channel variations, none of which seem to be working. 2 channel variations seem ok. i'm going to go through the list of settings and see what I can find. |
7th October 2009, 09:04 | #2210 | Link |
I have an issue with aspect ratio, encoding the movie Iron Man.
It has a format of 1920*800, so I checked anamorphic and the size to 1280*528 which is the same format. Preview within HDC also looks fine. The result has 1280*528 but MediaInfo shows an aspect ratio of 16/9 and the format is indeed wrong, black bars at top and bottom are way less, looks wrong. So what went wrong, someone have an idea? |
7th October 2009, 10:35 | #2211 | Link |
HDConvertToX author
post a make report, and image capped with mediaplayer classic
BHH
7th October 2009, 13:25 | #2212 | Link |
Hm, in MPC it looks fine:
But in VLC, while the source looks fine, this encode is wrong, and also MediaInfo displays a format of 16/9... Code:
HDConvertToX v.2.2.492.3692 report Input File: d:\downloaded stuff\hd-filme\iron.man-003.mkv ( D:\Downloaded Stuff\HD-Filme\Iron.Man-003.mkv ) Codec Video: avc Width / Heigh : 1920 / 800 Framerate / Framecount: 23.976 / 1459 Duration(hh:mm:ss): 0:1:1 Aspect Ratio: 1.846154 Resized resolution: 1280 / 528 Crop Values : 0:0:0:0 Activate: Crop Obey to AR Activate: Anamorphic Resize Start Video Configuration -> Encoding Settings: X264 Extreme Quality ; Quality= 19 NMT Compatibility: On Encoding Preset: X264 Extreme Quality ; Quality= 19 Final Size: 19 Denoise Level: Super Light Video Handling: Use Best Decoder -> End Video Configuration Start Audio Configuration -> Audio Codec: No Audio Audio Bitrate/Quality: 128 Audio Channels: 2 Normalize: On Audio handling: Use Eac3to as demuxer Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 2: ac3, german, 5.1 channels, 384kbps, 48khz 3: ac3, english, 5.1 channels, 384kbps, 48khz, dialnorm: -24db -> End Full Audio List Full Subtitle List-> (*** mean selected) *** NONE -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> ColorMatrix: On Resizer: Spline36Resize -> End Advanced AviSynth Start Muxing Options -> <- End Muxing Options Start Queue -> prompt $d $t $_$P$G "D:\HDConvertToX_2.1.458.3528\applications\eac3to.exe" "d:\downloaded stuff\hd-filme\iron.man-003.mkv" 1:"D:\HDConvertToX_2.1.458.3528\job6\hdconverttox.h264" "D:\HDConvertToX_2.1.458.3528\applications\DGAVCIndex.exe" -i "D:\HDConvertToX_2.1.458.3528\job6\hdconverttox.h264" -o "D:\HDConvertToX_2.1.458.3528\job6\movie.dga" -f 0 -e "D:\HDConvertToX_2.1.458.3528\applications\x264.exe" --crf 19 --preset medium --trellis 0 --ref 3 --deblock -1,-1 --subme 9 --direct auto --me umh --b-adapt 1 --no-chroma-me --sar 1013760:1024000 --output "D:\HDConvertToX_2.1.458.3528\job6\hdconverttox_iron.man-003.h264" "D:\HDConvertToX_2.1.458.3528\job6\hdconverttox_iron.man-003.avs" --level 4.0 "D:\HDConvertToX_2.1.458.3528\applications\mkvmerge.exe" -o "D:\Downloaded Stuff\HD-Filme\zzz\19IronExtreme.MKV" --default-duration 0:23.976fps --aspect-ratio -1:1.846154 "D:\HDConvertToX_2.1.458.3528\job6\hdconverttox_iron.man-003.h264" --title "Done with HDConvertToX v.2.2.492.3692" -> End Queue AviSynth Script -> Working with files: D:\HDConvertToX_2.1.458.3528\job6\hdconverttox_iron.man-003.avs AVCSource("D:\HDConvertToX_2.1.458.3528\job6\movie.dga") Spline36Resize(1280,528,0,0,-0,-0) hqdn3d(1) -> End AviSynth Script |
7th October 2009, 19:37 | #2214 | Link |
HDConvertToX author
@CYBERSONIC
sorry pal, no support for RULE 6 material BHH
7th October 2009, 19:55 | #2216 | Link |
HDConvertToX author
i suggest you to reread the rules and the sticky in newby section
i want help you but not breaking the rules BHH
10th October 2009, 20:40 | #2219 | Link |
Hdconvertox 2.2. If I have selected and added to query multiple files at once with auto shutdown option in ini, query looks like
......... "d:\tools\HDC\applications\mp4box.exe" -add "E:\temp\job1\hdconverttox_dscf0508.h264" -fps 30.000 -add "E:\temp\job1\hdencodertox-pid1.mp3" "_DSCF0508.mp4" shutdown -s -t 2 -f ........ "d:\tools\HDC\applications\mp4box.exe" -add "E:\temp\job1\hdconverttox_dscf0586.h264" -fps 30.000 -add "E:\temp\job1\hdencodertox-pid1.mp3" "_DSCF0586.mp4" shutdown -s -t 2 -f |
10th October 2009, 20:48 | #2220 | Link | |
HDConvertToX author
i'll check , thanks BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
