25th June 2010, 17:35 | #1101 | Link |
The Mask Developer of The FilmMachine An easy to use, wizard-like, AVI/MP4/MOV/RMVB/MKV to DVD conversion utility |
27th June 2010, 11:33 | #1102 | Link | |
Oops, I meant that is current as in it doesn't give a '404 page', but the builds are quite old you are right.
Thankyou!, I am grateful for any help |
27th June 2010, 12:34 | #1103 | Link |
In http://code.google.com/p/wavtoac3encoder/downloads/list the aften-git-20091226-icl11_1_054 is the last build I know.
27th July 2010, 22:02 | #1104 | Link |
Version 4.6 and later 4.7 of WAV to AC3 Encoder have been released today:
Changes: - Fixed: Issue 5: Importing .mux files in ANSI not possible - Added support for avisynth in AMD64 (64-bit) builds using http://code.google.com/p/avisynth64/. Downloads: http://code.google.com/p/wavtoac3encoder/downloads/list |
1st August 2010, 07:49 | #1107 | Link | |
All of my audio work is done via the CLI, in scripts that I have written to automate the process of stuff that I do. |
1st August 2010, 08:13 | #1109 | Link | |
- It has optimized aften builds. - Supports Avisynth scripts under Win32 and x64 OS. - Can be used to automate several jobs from command-line using presets. - Has MUX wizard. - Supports unicode file names. - You can access all aften options in one place and tweak quickly. |
18th November 2010, 09:21 | #1112 | Link |
Derek Prestegard IRL
encwavtoac3 5.0 is out now http://www.videohelp.com/tools/EncWAVtoAC3
These are all my personal statements, not those of my employer :) |
18th November 2010, 10:56 | #1114 | Link |
That works in BeHappy and MeGUI (which uses the engine derived from BeHappy).
http://behappy.codeplex.com/ http://forum.doom9.org/showthread.php?t=104686 |
26th August 2011, 14:51 | #1118 | Link |
Does anyone know why AC3 files encoded with Aften are not showing any information in MediaInfo ?
All other AC3 tracks I have, extracted from DVD / BD and samples from this forum, are showing details in MediaInfo like this: Code:
General Complete name : F:\Test\ac3test.ac3 Format : AC-3 Format/Info : Audio Coding 3 File size : 3.20 MiB Duration : 1mn 0s Overall bit rate : 448 Kbps Audio Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Duration : 1mn 0s Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 3.20 MiB (100%) But files encoded with Aften are showing this: Code:
General Complete name : F:\Test\ac3.ac3 File size : 1.57 MiB Code:
-readtoeof 1 -pad 0 -exps 32 -s 1 -b 448 - %d Code:
General Complete name : F:\Test\ac3.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 1.57 MiB Duration : 29s 326ms Overall bit rate : 449 Kbps Encoded date : UTC 2011-08-26 13:31:00 Tagged date : UTC 2011-08-26 13:31:00 Writing application : Yamb 2.1.0.0 [http://yamb.unite-video.com] Audio ID : 1 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : ac-3 Duration : 29s 326ms Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 1.57 MiB (100%) Title : AC-3 Encoded date : UTC 2011-08-26 13:31:00 Tagged date : UTC 2011-08-26 13:31:00 However the files created by Aften are playing fine with Foobar and VLC. Is it an Aften issue or a MediaInfo issue ? Any thoughts ? |
26th August 2011, 15:07 | #1120 | Link | |
Just for kicks, add '-xbsi1 1' to your commandline and see if that changes what MediaInfo prints out. |
