Old 28th January 2017, 21:49   #2921  |  Link
ajp_anton
ajp_anton's Avatar
Bug in overlay?
background = blankclip(width=400,height=400,length=1,pixel_type="y8").mt_lut("255")
box = blankclip(width=100,height=100,length=1,pixel_type="y8").mt_lut("0")
mask = box.mt_lut("255")
#overlay(background, box, x=150, y=150, mask=mask)  # black box value is 0
overlay(background, box, x=150, y=150)             # black box value is 1
scriptclip("""
subtitle(string(yplanemax)+"\n"+string(yplanemin),lsp=0)
Also when reversing the black and white, using a "maximum" mask (instead of no mask) results in a white box balue of 254 instead of 255.
ajp_anton is offline
Old 28th January 2017, 23:04   #2922  |  Link
real.finder
Originally Posted by ajp_anton View Post
Bug in overlay?
scriptclip("""
I think this is known thing, even in masktools https://github.com/tp7/masktools/issues/12
edit: in original avisynth
#overlay(background, box, x=150, y=150, mask=mask)  # black box value is 1
overlay(background, box, x=150, y=150)             # black box value is 0
and there are another thing, if I overlay 2 rgb32 then I get all alpha in zero in normal avs, but in last avs+ it all 255
See My Avisynth Stuff
real.finder is offline
Old 29th January 2017, 09:52   #2923  |  Link
pinterf
The original blending formula is something like that, where an ideal mask is 0..1.0:
new_value = orig*(1-mask) + overlay*mask
This is equivalent to (only one multiplication, faster):
new_value = orig+(overlay-orig)*mask
As mask is coming from a clip, its value is 0..255
The approximation in overlay core:
new_value = ((orig * 256 + 128)+(overlay-orig)*mask) / 256
When orig=255, overlay=0, mask=255 (overlay is fully visible), we would expect 0 (=overlay)
Unfortunately the approximation above results in:
new_value = ((orig * 256 + 128)+(overlay-orig)*mask) / 256:
(255*256+128) + (0-255)*255) / 256 = 383/256 =
(65408 - 65025) / 256 =
383/256 = 1
which is obviously incorrect
For orig=0, overlay=255, mask=255 the result is 254 instead of 255.
pinterf is offline
Old 29th January 2017, 11:04   #2924  |  Link
ajp_anton
ajp_anton's Avatar
So can it be fixed? I guess it's a bit complicated if you need
0 -> 0%
128 -> 50%
255 -> 100%
Do you need two separate linear scales on both sides of 128, a non-linear scale, or a special case for 255? Or treat both 0 and 1 as 0%?
Old 29th January 2017, 14:30   #2925  |  Link
real.finder
0 -> 0%
128 -> 50%
255 -> 100%
in 16 bit you will get better result, and I think there is no problem at all in float point
but if you need it in 8 bit there are RMerge with mode=256
@pinterf
but there are difference between normal avs and avs+ like I mention
Old 29th January 2017, 16:58   #2926  |  Link
ajp_anton
ajp_anton's Avatar
@pinterf
That's not a solution, it's a workaround. RMerge doesn't have arguments for x and y offsets, so that's not even a workaround. Float probably works while 16 bit still has this problem (though it's less noticeable).
Old 29th January 2017, 18:01   #2927  |  Link
pinterf
What is the use case when you rely on having the output alpha is filled by zeros?
On the other hand in classic avisynth the alpha channel of an RGB32 after an Overlay is undefined.
At least after having a quick look at the source, it is not filled up by any defaults. There is always an RGB->444->RGB conversion sequence, and the final conversion back from internal 444 to rgb32 fills only r, g and b channels.
Avisynth+ Overlay may use ConvertToRGB32 (which fills up alpha with 255; full transparency).
Or it just simply preserves source clip's alpha info if it works in conversionless mode (no RGB->444->RGB conversion, blend works in RGB natively)
pinterf is offline
Old 29th January 2017, 18:05   #2928  |  Link
pinterf
0 -> 0%
128 -> 50%
255 -> 100%
Mask value of 255 (and in general the maximum pixel value for a given bit depth) is definitely a special case that we have to handle.
It really should work as maximum transparency.
Much more special, I think than 128 / 50%
pinterf is offline
Old 29th January 2017, 23:30   #2929  |  Link
real.finder
background = blankclip(width=400,height=400,length=1, color=$FFFFFF,pixel_type="rgb32")
box = blankclip(width=100,height=100,length=1,pixel_type="rgb32")
you can test it with mask too, but anyway it's not important
but I say something else
here in avs+ as ajp_anton say
and here what I get with normal avs
edit and here another test without mask in normal avs
overlay(background.invert, box.invert, x=150, y=150)             #white box value is 255, background is 0
Old 30th January 2017, 05:45   #2930  |  Link
real.finder
let's back to grun
SetFilterMTMode("GScriptClip", 3)
SetFilterMTMode("RequestLinear", 1) #or 3, mode 2 will make avs+ freeze and not respond (with real clip not ColorBars, ColorBars seems ok even with RequestLinear in mode 2 here)
ColorBars(width=640, height=480, pixel_type="yv12").AddGrainC(10000, 10000, seed=1)
#~ srestore() #seems ok
admfilter() #show error on screen
Prefetch(6)
Old 30th January 2017, 11:12   #2931  |  Link
pinterf
I think ajp_anton exchanged the comments of 0 and 1 values
My experience is:
scriptclip("""
return last
pinterf is offline
Old 30th January 2017, 11:13   #2932  |  Link
ajp_anton
ajp_anton's Avatar
Yes, sorry, looks like I got the 0 and 1 wrong there.
How is 8(or higher)bit to float handled? Shouldn't it also be
0 -> .0
128 -> .5
255 -> 1.0 ?
Using "averageluma", 128 is converted to 0.501961 (128/255).
Using "yplanemax"/"-min", 128 is converted to 32896 (is this a bug? should be a float number, not a 16bit int)
Also, y=128 in 8bit -> float is different from 8bit -> 16bit -> float.
Old 30th January 2017, 11:20   #2933  |  Link
pinterf
let's back to grun
Prefetch(6)
I have not continued the investigation on grunt freeze, I have spent three day on it in December, and it is still beyond my knowledge, I am not an avisynth expert. All I have seen that it gets deadlocked on an internal mutex. Scriptclip invoke runs under a different thread id and sometimes that conflicts with the internal cache mechanism. The problem can occur when a runtime function e.g. YPlaneMin requests the child frame and that frame should retreived from the cache. So I put aside this problem a bit until I have more time/knowledge on the topic.
pinterf is offline
Old 30th January 2017, 14:36   #2934  |  Link
jpsdr
When i'm creating an ouput like this :
PVideoFrame dst = env->NewVideoFrame(vi);
Is there something i can do to force an alignment value ?
(If i want aligned on 32 or 64 bits for exemple)
jpsdr is offline
Old 30th January 2017, 16:34   #2935  |  Link
pinterf
PVideoFrame dst = env->NewVideoFrame(vi, 64);
pinterf is offline
Old 30th January 2017, 17:33   #2936  |  Link
jpsdr
Easy, lol ! Thanks.
Euh... Of course, i wanted to say 32 or 64 bytes... (YMM registers.... )
jpsdr is offline
Old 30th January 2017, 17:38   #2937  |  Link
pinterf
Avs+ default is 32
pinterf is offline
Old 30th January 2017, 23:01   #2938  |  Link
real.finder
0 -> .0
128 -> .5
255 -> 1.0 ?
yes, I think there are bugs in Runtime Functions, AverageChromaU and AverageChromaV in float too
Old 31st January 2017, 02:39   #2939  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
For now, what plugins support the new 16-bit format? RgTools; anything else?
MysteryX is offline
Old 31st January 2017, 02:53   #2940  |  Link
Reel.Deel
RgTools, Average, NNEDI3, DCTFilter, YadifMod2, FFMS2, RawSourcePlus, VapourSource, AVSResize, FQPlus, ModPlus, and MovePlus all support 10-16 bit and 32 bit float.
Edit: also pinterf's MVTools, MDepan, and DepanEstimate support 10-16 bit.
There's also VirtualDubFilterMod, avs2pipemod, and Avs2Yuv which support some of the new HBD colorspaces.
Reel.Deel is online now
