Old 26th May 2013, 11:31   #18881  |  Link
ryrynz
ryrynz's Avatar
Use Niyawa's guide. Pick a combination that doesn't drop frames on the content you typically watch, I also recommend enabling Smooth Motion.
Old 26th May 2013, 11:46   #18882  |  Link
nekromantik
Thanks
SM is already on but I seem to get a lot more delay in rendering times in old path exclusive mode. In windowed mode FS I get around 25 - 30 ms rendering time using Softcubic 75 and Jinc3 but in exclusive mode it jumps to 115ms!
Mostly watch 720P H264 on a 1080P TV non anime.
nekromantik is offline   Reply With Quote
Old 26th May 2013, 12:01   #18883  |  Link
XRyche
Originally Posted by Portioli View Post
@6233638 (and any other scaling maniac :P)
I just assembled an htpc for a friend that has the most awfull collection of avi & divx ever seen.
Right now i use MN for chroma, Softcubic80 for luma.
Any better recommendation for such material.
My main goal is to hide compression artifacts.
I'm not a "scaling maniac" and this doesn't really relate to madVR, but try some of the "sharpen complex, deband and denoise" custom pixel shaders from janwillem32's (http://forum.doom9.org/showthread.php?t=157634) "Video pixel shader pack". I use them myself with madVR for old TV rips and such and they do a stand-up job paired up with madVR.
XRyche is offline   Reply With Quote
Old 26th May 2013, 14:51   #18884  |  Link
andybkma
On Windows 7 64 bit does having Aero turned on or off effect the playback quality of mVR? I mean does it effect it (better or worse) with stuttering/delayed/dropped frames etc? Reason being I have always have had aero turned off now I am wondering if I am missing out on something. Thanks...
andybkma is offline   Reply With Quote
Old 26th May 2013, 19:37   #18885  |  Link
petran79
OK, sounds good! and what about the old rendering path? the new one randomly hiccups for me when OTOH the old one has always worked flawlessly
Sorry, i am not familiar with that term.
petran79 is offline   Reply With Quote
Old 26th May 2013, 23:12   #18886  |  Link
maco07
On the other hand?
maco07 is offline   Reply With Quote
Old 26th May 2013, 23:16   #18887  |  Link
kiccolsd
Originally Posted by rahzel View Post
Previous driver should work.
Thx man for your help with drivers, i found you setting for Rendering-->Exclusive Mode and I'm going to copy those. One question the last one Flush & Wait, sleep and loop are the same?
kiccolsd is offline   Reply With Quote
Old 26th May 2013, 23:55   #18888  |  Link
leeperry
Kid for Today
In order to revert to the old rendering path, you need to uncheck "present several frames in advance" in the /rendering/exclusive mode settings/ tab and it would also help to check "use managed upload textures (XP only)" in the /rendering/general settings/ tab as that latter option would smoothen windowed/FS changes IME. I've tried the new rendering path on several occasion but it would very often hiccup right after skipping when OTOH the old one has always worked perfectly for me.
you also seem to imply that CUVID hardware acceleration in LAV would be part of the issue, so how about software decoding then?
some additional feedback would be greatly appreciated please if you got time to run more tests.
Old 27th May 2013, 00:23   #18889  |  Link
nekromantik
Im kinda annoyed lol
This is a new laptop with Radeon 8730M but cant use that card for MadVR as in exclusive mode I get 5 times slower rendering then windowed mode! As its switchable graphivs only solution is to use HD4000 but with that I can only use Lanz3 and BiCubic 75 and I get around 30 - 35ms render for 720P to 1080P.
Old 27th May 2013, 12:33   #18890  |  Link
yok833
I am about to commit a bad thing ... But I have to do it... :
Madshi, are you close to release a new update or is there nothing to expect in the next couple of weeks ??
yok833 is offline   Reply With Quote
Old 28th May 2013, 07:14   #18891  |  Link
artios
There is an option
enable windowed overlay (Windows 7 and newer)
I noticed that with this option enabled, in some particular videos (many videos) when I press the Alt+Enter to enter full screen, the picture starts flashing and I need to close the player to stop the flashes.
This is the only thing that I noticed regarding Aero that has negative effect on playback.
artios is offline   Reply With Quote
Old 29th May 2013, 09:51   #18892  |  Link
TheElix
more feedback when it'll be sitting on my desk. As an additional appetizer, I can also state that it comes with 360Hz PWM flicker so motion blur shouldn't much of an issue in 60Hz
Tell us already! Or else
TheElix is offline   Reply With Quote
Old 29th May 2013, 12:36   #18893  |  Link
Incriminated
Blanked for my stupity, sry.
Incriminated is offline   Reply With Quote
Old 29th May 2013, 12:46   #18894  |  Link
namaiki
I believe that is version 9 vs the current version 86.1...
namaiki is offline   Reply With Quote
Old 29th May 2013, 12:54   #18895  |  Link
Incriminated
What do you mean. The install.bat only registeres one single file either 0.86.1 or 0.9: madVR.ax
So hitting uninstall.bat, extracting 0.9 over the 0.86.1, then hit install.bat is no "Vs".
PS: The bad thing that 0.9 doesn't work properly for me. The MadVR icon does no more appear in systray plus any video i try to watch via registered output module madVR is at extreme low framerate (1 frame every 6-7 seconds!!!). Made sure i un-/installed correctly with admin-rights and rebooted.
Switching back to 0.86.1 instantly works tough.
SO there's a reason this update is not officially announced.
Old 29th May 2013, 13:10   #18896  |  Link
Incriminated
Lol im stupid, now i know what you mean.
It is 0.9 (0.09) not v0.90. OMG, ignore me
Old 29th May 2013, 14:16   #18897  |  Link
LigH
LigH's Avatar
You are not the first user who got caught by this trap; the same issue has been discussed a few times in the german doom9/Gleitz board too...
New German Gleitz board
Old 29th May 2013, 14:45   #18898  |  Link
paradoxical
Posts: n/a
It's not 0.09 either. Version numbers are not arithmetic decimal numbers. And that can make it confusing if you don't understand the versioning scheme being used.
Old 29th May 2013, 14:53   #18899  |  Link
DragonQ
There's no reason to not use arithmetic decimal numbers though. Makes things simpler to use fixed version numbering in terms of how many digits there are.
HTPC Hardware: Intel Celeron G530; nVidia GT 430
HTPC Software: Windows 7; MediaPortal 1.19.0; Kodi DSPlayer 17.6; LAV Filters (DXVA2); MadVR
TV Setup: LG OLED55B7V; Onkyo TX-NR515; Minix U9-H
Old 29th May 2013, 15:01   #18900  |  Link
paradoxical
Posts: n/a
Sure there is. Versions numbers are not for doing arithmetic with. They are simply a way to show that you have made major/minor version changes. So simply going from counting from 1 to whatever is much better than having to format all your numbers with multiple padded out zeros just so it looks like a decimal number. Say for example I know I will possibly have 100 revisions between an alpha release and my 1.0. Why should I go 0.001, 0.002, 0.003, 0.004, 0.005, 0.006, 0.007, 0.008, 0.009, 0.010 instead of simply 0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 0.10, etc. The former way just seems silly to me since it's simply an incremented number showing your version as major.minor. It is not a decimal to do arithmetic with.
