Old 23rd December 2014, 05:24   #27881  |  Link
Arm3nian
Does Image Doubling work in both horizontal and vertical directions? For example watching a 1080 source on a 4k screen, and doubling luma resolution it will go from 1920 > 3840 and 1080 > 2160. Thanks
Arm3nian is offline   Reply With Quote
Old 23rd December 2014, 08:13   #27882  |  Link
nevcairiel
Yes, it'll double in both directions.
Old 23rd December 2014, 18:01   #27883  |  Link
digitech
recommended neddi settings for sd content
Anyone have recommended settings for sd content using neddi, i have no clue what combination to use, 90% of my sd content is animation and i love to use SVP with it, im on nvidia gtx 760, Intel i5 4670k, 16 gb ram, win7
digitech is offline   Reply With Quote
Old 23rd December 2014, 22:14   #27884  |  Link
Plutotype
Hi folks,
It looks like my brand new R9 285 doesnt like the old driver 13.12 (NNEDI best ). The drive itself installs fine, but HDMI audio driver fails. I tried to install it on top using 14.12, but failed again.
Does anyone have R9 285 and is successfully installed 13.12 driver? Maybe there is a problem within my setup.
Thanks
System: Intel Core i5-6500, 8GB RAM, GTX960/GTX1060, 55" Sony Bravia KDL-55HX850 @ 1920x1080 24p, Yamaha YSR-1100 surround bar
Setup: Win7/Win10 Pro, madvr/JRiver 24
Plutotype is offline   Reply With Quote
Old 23rd December 2014, 23:43   #27885  |  Link
flashmozzg
Originally Posted by Plutotype View Post
Hi folks,
Thanks
285 came out after 13.12 so it wouldn't be the best choice.
flashmozzg is offline   Reply With Quote
Old 24th December 2014, 17:47   #27886  |  Link
a8213711
I have a problem: my tv (Samsung) doesn't set the appropriate refresh rate (25Hz) even if supports it.
I have in MadVR
http://i58.tinypic.com/dqr89e.jpg
and I tryied with 2 different files:
http://i60.tinypic.com/n4ws4i.jpg
http://i59.tinypic.com/28ujwbm.jpg
- one put the tag Display on 59.94, infact the tv goes on 59Hz
- the other shows Display on 50, tv on 50Hz.
in control panel there are:
http://i61.tinypic.com/259lg1l.jpg
http://i59.tinypic.com/10ifk8w.jpg
Any tips?
Also in the last image it isn't shown I support 25 29 30 (int) too, should I add in MadVR all the modes my PC can support and rely to its decision?
After I took these screen I added in MadVr 1080p29 and 1080p30 too, and then tried 2 files:
- 30fps -> 60Hz
- 29.9fps -> 59.9Hz
a8213711 is offline   Reply With Quote
Old 25th December 2014, 03:23   #27887  |  Link
seiyafan
Is MPDN an alternative to madVR? What's the difference between the two?
seiyafan is offline   Reply With Quote
Old 25th December 2014, 19:56   #27888  |  Link
Asmodian
MPDN is a .NET based video player. It is similar to madVR only in that it uses the GPU to do high quality video rendering. It is not DirectShow based and its renderer cannot be used outside MPDN.
There are technological similarities so ideas implemented in MPDN can probably be implemented in madVR if they interest madshi. Recently Zachs has implemented an impressive but complex "Render Script" system for advanced shaders which hopefully can help inform more advanced shaders in madVR.
madshi also gave Zachs hints during development.
Old 25th December 2014, 21:38   #27889  |  Link
zerowalker
What settings should i change to make it as fast as possible when seeking?
That's the only thing that frustrates me, EVR is perfect except for some things that's useful (smooth motion for example).
I understand there is no way to make it as EVR without taking away everything, but you get the idea
Tried some things myself, buffer, frames, queue. But can't seem to find any difference.
zerowalker is offline   Reply With Quote
Old 25th December 2014, 22:13   #27890  |  Link
Asmodian
Simply turn off "delay playback start after seeking, too" under "delay playback start until render queue is full". With that off madVR is as fast as EVR when seeking, at least on my systems.
Old 25th December 2014, 22:20   #27891  |  Link
zerowalker
None of those "delay" has been checked.
The difference is huge on my System, and i got a pretty fast one, i5 760 4ghz.
EVR is super fast, i can click anywhere and it will play there imediatly on Audio, whgile Video get's delayed depending on Decoding.
MadVR everything get's delayed, and by a much larger margin, it depends on the scenes though.
Old 25th December 2014, 22:21   #27892  |  Link
e-t172
Try reducing the number of frames to be presented in advance, and the queue sizes as well.
e-t172 is offline   Reply With Quote
Old 25th December 2014, 22:26   #27893  |  Link
zerowalker
Done that before (and now), i am guessing this is as fast as it goes.
Old 25th December 2014, 23:24   #27894  |  Link
Asmodian
Without the "delay" options checked the queue sizes have no effect on seeking delays. madVR does not wait for them to fill but presents the first frame as soon as it is available.
madVR mostly runs on the GPU not the CPU. Which GPU do you have? What is your maximum rendering time? I assume you are not using hardware decoders, DXVA deinterlacing, or DXVA resizing?
I have a fast GPU+CPU (Titan+5960X) and seeking while using madVR feels as instant as EVR does.
Old 26th December 2014, 03:19   #27895  |  Link
zerowalker
Indeed not using DXVA, though did try, not much of a difference if any.
AMD 6970 is the GPU.
Old 27th December 2014, 04:48   #27896  |  Link
Ceremony
I'm in the process of setting up my htpc for madVR. Instead of sticking to a regular player such as mpc, I'd love to switch to a more mediacenter like alternative, such as xbmc/kodi. however, do any of these even work with madVR?
Ceremony is offline   Reply With Quote
Old 27th December 2014, 05:30   #27897  |  Link
baii
Jriver can use madvr, xbmc calling mpc for playback can too?
Sent from my 306SH
baii is offline   Reply With Quote
Old 27th December 2014, 08:01   #27898  |  Link
romulous
Indeed, as far as I know, XBMC's internal player does not support madVR, but you can set XBMC to use an external player for media files, and it will be up to that player to work out what to use (so if you set it to use MPC and you have MPC set to use madVR, madVR will be used).
romulous is offline   Reply With Quote
Old 27th December 2014, 16:32   #27899  |  Link
Ceremony
doesnt really work for me, as im looking for a more remote controlled all in one solution. seeking for example would not be possible when doing things like that unfortunately.
Old 27th December 2014, 16:40   #27900  |  Link
jdl
I use MPC-HC as an external player in Kodi and my remote controls both with no problem.
jdl is offline   Reply With Quote
