Old 26th September 2017, 22:10   #21  |  Link
Groucho2004
Originally Posted by george84 View Post
As I said in the beginning everything works fine in AVS+. Only AVSMeter and VDub Crash. AVSPmod does also good preview.
I just wanted to help you track the crash in AVSMeter.
As I also said it is not all important for me. So let it die.
I think there is some misunderstanding here. The exception occured in shibatch.dll, not VDub or AVSMeter:
Exception 0xC0000005 [STATUS_ACCESS_VIOLATION]
Module: C:\Users\Walter\Downloads\AvisynthUniversalInstaller_2017-09-02\AvisynthRepository\AVSPLUS_x86\plugins\Shibatch.dll
Address: 0x6570A393
Just because Avspmod or its preview doesn't have the exception handling that is needed to catch those errors doesn't mean that there is no problem. You should check the output of that script thoroughly, audio and video.
Groucho's Avisynth Stuff
Old 28th September 2017, 11:12   #22  |  Link
Groucho2004
v2.6.6
  • Detailed external function enumeration and duplicate report are still not working properly, removed for now
Old 16th November 2017, 19:36   #23  |  Link
Groucho2004
v2.6.7
  • Minor fixes, refactoring and cosmetics
Old 18th November 2017, 10:07   #24  |  Link
Groucho2004
v2.6.8
  • Fixed a bug in plugin type enumeration (regression)
Old 1st December 2017, 10:58   #25  |  Link
Groucho2004
v2.6.9
  • avsinfo: If the version info is missing in (auto-load) plugins/files, the UTC timestamp is printed instead
  • Simplified 'ESC' key handling
Old 1st December 2017, 22:32   #26  |  Link
Thanxs, my hero,
Old 14th December 2017, 18:51   #27  |  Link
Groucho2004
v2.7.0
  • Warnings and errors are reported in separate sections
  • Updated list of exception messages
  • Cosmetics
Old 14th December 2017, 19:55   #28  |  Link
GMJCZP
GMJCZP's Avatar
Thanks. In this repository http://www.iol.ie/~schubert/gas/gas.html still remains the 2.69 version.
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 14th December 2017, 19:58   #29  |  Link
Groucho2004
Click refresh.
Old 4th January 2018, 16:01   #30  |  Link
Music Fan
where is the ini file located ?
I put AVSMeter.exe (x86) in C:\Program Files (x86)\AVSMeter, I opened an avs file with AVSMeter, I cancelled the process and the window disappeared.
To let the window opened, a setting could be changed in the ini that appeared after the first utilisation, but it doesn't appear anymore.
I didn't used AVSMeter for a while.
Music Fan is offline   Reply With Quote
Old 4th January 2018, 16:34   #31  |  Link
For me, ini file is created (after I deleted original) in the same directory as AvsMeter.
(I run AvsMeter from "C:\BIN" which has an entry in my %PATH%, and run from command prompt)
EDIT:AvsMeter v2.67.
Old 4th January 2018, 16:42   #32  |  Link
Music Fan
It used to be the case too on my pc, but not anymore (v2.70).
Old 4th January 2018, 16:54   #33  |  Link
EDIT: Updated to avsmeter v2.7
Same again for me, in C:\BIN\ directory.
Are you calling from Programs menu, or drag and drop ?
You could try root of C:\, or your equivalet to "Documents and Setting\UserName"
EDIT: Just seen this
INI file settings
AVSMeter checks if a settings file ("AVSMeter.ini") exists in the directory from where it is started. If not, it will be created with the default settings.
Note: If applicable, command line switches override INI settings.
Old 4th January 2018, 17:06   #34  |  Link
Groucho2004
AVSMeter.ini is always created in the same directory as AVSMeter.exe (given that it has write privileges to that directory).
Old 4th January 2018, 17:21   #35  |  Link
Maybe why.
Old 4th January 2018, 17:55   #36  |  Link
Music Fan
That was the problem : I ran AVSMeter.exe as administrator and the ini was created. But when I wanted to change the settings, it was refused (I don't know why, I am the administrator and only user of this pc).
Thus I put AVSMeter in C:\AVSMeter and now I can save the changes in the ini.
edit : But now I can't open avs files with AVSMeter with right click
I select AVSMeter.exe but it doesn't appear in the list of the programs that can open this type of files
I will try with send to.
Old 4th January 2018, 17:58   #37  |  Link
Groucho2004
Maybe why.
Pretty much the first thing AVSMeter does is parsing the .ini file (or creating one if it does not exist). If it can't create it, an error message is displayed which of course is difficult to see if it's not run from an already open console.
Maybe I should set the "PauseBeforeExit" option to true by default...
Old 4th January 2018, 17:59   #38  |  Link
lansing
Text files inside C:\program files\ will need administrator-right-opened textfile editor in order to edit it.
Old 16th January 2018, 12:16   #39  |  Link
Groucho2004
v2.7.1
  • When using the switch "-avsinfo" in combination with "-log", a "Save as..." dialog will open enabling the user to save the log file
  • Minor fixes and refactoring
  • Cosmetics
Some users seemed to have trouble finding the log file created with the switches "-avsinfo -log", mainly when not operating directly from the console. The "Save as..." prompt should cure this.
Old 16th January 2018, 19:56   #40  |  Link
Music Fan
Great, thanks.
