Old 16th December 2012, 16:54   #41  |  Link
kasper93
MPC-HC Developer
We use Microsoft filter for online sources File Source (URL) and this is how this filter works. It shouldn't cache all the data, but it does and I think 4GB limit is because you are using FAT32 which doesn't allow larger files.
The best solution for you is using LAV Source Splitter for http. You need to add this to register. Past it to notepad and save as "http.reg" then double click on it and that's all. Note that you need to have LAV installed
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\http]
"Source Filter"="{B98D13E7-55DB-4385-A33D-09FD1BA26338}"
FWIW, you could try using DVB directly in MPC-HC it is not that bad
kasper93 is offline   Reply With Quote
Old 16th December 2012, 17:05   #42  |  Link
Joniii
Originally Posted by vBm View Post
Yeah, Armada has plans to revamp the UI in near future.
Great
As a programmer i've always really enjoyed the usability and UI design, not so much in the important things that I can't see. MPC functionality isn't that good for users who sit on the sofa with a remote, so I made some changes to MPC for my personal use. Could you consider adding some of these features if those are well made, and function as expected to make the user experience better for remote use?
For example I did this today and I think it would be a good add but dunno if it's just me. On fullscreen, if user presses play, pause, rewind, or skip, mpc shows the narrow mpc seekbar for 5 seconds. Also I thought I add also this. With the previous function it would also show local time on right or left corner.
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards
MPC-HC (madVR, LAV Filters, XySubFilter)
Sony Bravia 85X950H/85XH95
Yamaha RX-V685
Yamaha Piano Black NS-777/555/C444/YST-SW315
Joniii is offline   Reply With Quote
Old 16th December 2012, 18:01   #43  |  Link
mrchisholm
hey
thanks alot, i will try it out, no my system is NTFS so that shouldn't be an issue and i tried lav filter splitter but not with that added registry, will try now and report back
mrchisholm is offline   Reply With Quote
Old 16th December 2012, 18:15   #44  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
v1.6.5 is released
After 2 and a half months since the last stable build, we decided to release 1.6.5.
This release has many bugfixes and some new features.
Highlights of this release:
* Some long standing issues for the Internal Subtitle Renderer/VSFilter have been fixed:
- Support UTF-8 subtitles without BOM
- Fix high memory usage with complex subtitles (mostly ASS)
- Fix most cases where subtitles are not correctly positioned
- Allow floating-point values for \fscx and \fscy in ASS subtitles
* Windows 8 is now officially supported and the file association problem has been solved.
  Windows 8 users should click the "Set Default Programs" button after selecting new formats.
* The DVB support has been improved with a better handling of DVB subtitles
  and a clearer display of the Electronic Program Guide information when using live capture.
You can download the new version here. For the complete changes see the changelog.
MPC-HC Links: official nightlies | Trac | GitHub | git log | IRC | Twitter | Facebook
vBm is offline   Reply With Quote
Old 16th December 2012, 18:46   #45  |  Link
mrchisholm
Originally Posted by mrchisholm View Post
hey
it seems to be working
Old 16th December 2012, 19:00   #46  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
Originally Posted by Joniii View Post
Great
As a programmer i've always been really interested in the usability and UI design. MPC functionality isn't that good for users who sit on the sofa with a remote, so I made some changes to MPC for my personal use. Could you consider adding some of these features if those are well made, and function as expected to make the user experience better for remote use?
If you think someone else could benefit from your work, feel free to contribute code via Pull Requests.
Old 17th December 2012, 00:00   #47  |  Link
Superb
This should be fixed as of 0696a331
Yeah, I saw the commit and can verify that 1.6.5.6366 (744df1c; final) indeed fixes the issue. Thx guys.
Superb is offline   Reply With Quote
Old 17th December 2012, 06:10   #48  |  Link
dansrfe
I'm not sure if this is appropriate for MPC-HC but would it be possible to start adding visualizations for music files in MPC-HC? I listen to all of my music in MPC-HC along with my videos and movies and it would increase the appeal of the player as well.
Thanks and awesome job on the new official release!
Old 17th December 2012, 06:26   #49  |  Link
ryrynz
ryrynz's Avatar
Appropriate yes, but I don't see it happening any time soon if ever, use WMP or similar.
Old 17th December 2012, 19:20   #50  |  Link
pirlouy
_
I'm sorry but adding visualizations would lower MPC-HC value.
Old 17th December 2012, 21:25   #51  |  Link
cengizhan
Windows 8 button fails with this: there was a problem loading the set a default program page. error code:80004005.
cengizhan is offline   Reply With Quote
Old 17th December 2012, 21:35   #52  |  Link
Armada
MPC-HC Developer
Have you enabled any formats? (the button should be grayed out if you haven't)
Have you tried pressing the "Modify" button to get elevated privileges before pressing the "Set Default Programs" button? (it worked without elevated privileges for me)
Armada is offline   Reply With Quote
Old 17th December 2012, 22:25   #53  |  Link
Joniii
I made a test version of the fullscreen controls.
This mimics WMC functionality, which I think is pretty well thought so that you'll see where the movie is going when you fwd and can check the playtime by pressing the play during playback:
Play, toolbar 5 sec
Pause, toolbar 5 sec
Stop, toolbar 5 sec
Rewind/Forward toolbar until play,pause or stop, 5sec
This doesn't affect (I think) mouse users. In fullscreen you will only see this functionality when using remote or keyboard shortcuts for play,pause,stop,rew and fwd.
I mapped the remote keys so you shouldn't need to set those when you test this.
http://sdrv.ms/UZ4v7C
Yamaha RX-V685
Old 17th December 2012, 22:38   #54  |  Link
dansrfe
How would it lower it? In my head it's with the same thought process that people have made alternative toolbar skins for MPC-HC. There is obviously no functional value to the toolbar looking different but it just looks nicer.
Plus it appeals to users who are coming from other commercial players and are ready to look for something that is more flexible and better overall. New people count looks as a factor whether most of us here consider it a factor or not.
I myself don't set that much value on the aesthetic design of something that is built with minimalism at the forefront but that doesn't mean MPC-HC has to be devoid of it.
Old 18th December 2012, 00:48   #55  |  Link
pirlouy
_
But I'm just a troll who will cry for bloated application if there are visualizations in a video player !
Old 18th December 2012, 05:05   #56  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Incorrect info at first post : Supports most types of subtitles including BD .sup files - MPC-HC do not support subtitle in .sup files;
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 18th December 2012, 05:46   #57  |  Link
boyumeow
boyumeow's Avatar
Incorrect at the moment , but would be corrected if U ever submit the patch to them ( in advance if U ever did that). Just wonder would U consider to share it to xy-vsfilter if they requested it too.
for your contribution in everything.
boyumeow is offline   Reply With Quote
Old 18th December 2012, 05:52   #58  |  Link
hayan
System response Killer
single click to select Full-HD video file at explorer
Press & Hold the "enter" key
1x-3x number of mpc-hc open from explorer!
options:
association file
Use the same player for each media file
hayan is offline   Reply With Quote
Old 18th December 2012, 05:53   #59  |  Link
wanezhiling
http://pan.baidu.com/share/link?shar...&uk=3558042035
.sup subtitle, BE crashed.
Old 18th December 2012, 10:17   #60  |  Link
Aleksoid1978
Originally Posted by wanezhiling View Post
Thanks - fixed.
http://aleksoid.voserver.net/MPC-BE/mpc-be.exe_SUP.7z
dxva, media player classic, mpc, mpc-hc
