9th August 2017, 00:09 | #44581 | Link |
The comparison booklets I have for each of the major brands shows nothing to do with 3D. The only model I know that does is the Panasonic EX750, every other major brand has dropped it completely. LG may possibly add an option to future TVs.. but with fewer sets playing 3D there will be less content as a result, so the future is grim.
9th August 2017, 07:38 | #44582 | Link | |
9th August 2017, 10:42 | #44583 | Link | |
BTW the Questions i must unswerd every time to post a reply are soo dammmmn anoing!! -.- Last edited by Gee; 9th August 2017 at 10:58. |
10th August 2017, 01:32 | #44584 | Link |
Yes, but it harms the audio quality, at least theoretically if not audibly. Resampling is definitely a bad thing if it can be avoided.
madVR options explained |
10th August 2017, 08:33 | #44585 | Link | |
Colorimeter has arrived. I would have a quick question: (madVR 3D LUT / TV Movie preset) Before I start a measuring, do I need to use the “Interactive Measuring Tool”? or do not i need RGB correction in the TV menu, just start measuring? I hope I was clear Last edited by hajosattila; 10th August 2017 at 08:39. |
10th August 2017, 09:50 | #44587 | Link |
X Cinema Projectionist NZ
I seem to have a bit of a scaling problem and Im not sure what to do, can someone point me in the right direction please?
Its a bit complicated so I'll try to be as brief as possible. I have the JVC X9500 in my 12 seat home cinema, I also have a 4K monitor in the cinema foyer which allows me to monitor what and where we are up to in the prog. when I use my cinema for a private film club I run once a week. I run madvr with the 1080 Ti card and upscale all content to 4K, mostly BDs. Plus I have a Lumagen Pro, set to passthrough 4K from the PC. To get the same image in the cinema and the foyer, I setup the gear like this. PC 4K > Lumagen input, Lumagen output 1 > AVR audio only, Lumagen output 2 > input 4K Gefen 1x2 HDMI splitter > Splitter Output 1 > JVC X9500, Splitter Output 2 > 4K foyer monitor. This is my result on the madvr menu, Scale 1920, 1080 > 0.0. 3291, 1851, I have this result for all content, 4:3, 16:9, scope However the odd thing is my Lumagen menu states 3840 x 2160 in and 3840 x 2160 out. Why am I getting 3291 x 1851 in the madvr menu for all content when it should read 3840 x 2160? Is it anything to do with the foyer 4K Dell monitor even though the specs state 3840 x 2160? I have all zoom in madvr off. https://www.elive.co.nz/dell-profess...SABEgIuUvD_BwE Ive just run out of things to test in madvr so Im not sure where else to look... Sorry for the long post, but I wanted to provide as must information as possible. Last edited by 70MM; 10th August 2017 at 09:54. |
10th August 2017, 09:55 | #44588 | Link |
On High DPI setups one has to be careful that OS DPI scaling is not involved. The safest route is to just disable DPI scaling in the OS (ie. setting it to 100%). Otherwise, you would have to make sure your players work properly, or perhaps your Lumagen is sending odd DPI values because its connected to two screens.
10th August 2017, 10:22 | #44590 | Link | |
Is this where I have Windows set to 175% for scaling? If I set it to 100% the image is too large, thats how I used to have it set in the days I used 1080p. BTW I dont use any players, its just the PC with madvr @ 4K. |
10th August 2017, 10:33 | #44591 | Link | ||
@hajosattila attachments can take a long time before other user like me can see them so please use a image host not the forum function. calibration is a complicated process that needs properly setup screen to work. you have to disable vivid mode and stuff like this the list is long. and the general nature of some screen makes problems too. like ABL on plasma/OLED and even stuff like local dimming on LCD screens. a good place to talk about calibration is here: http://www.avsforum.com/forum/139-di...llcms-154.html or you could make a new thread here on the forum there are some skilled calibrators on this forum too. calibration in general is not madVR related. |
10th August 2017, 10:44 | #44592 | Link | |
But I cant set Windows to 100% as I mentioned before as the image is way too big for 4K, I have it set to 175%, but my scaling looks all wrong on madvr. madvr scales to 3291 x 1851 for all content when it should read 3840 x 2160. Last edited by 70MM; 10th August 2017 at 10:46. |
10th August 2017, 13:26 | #44596 | Link |
No. madVR can't use more then one GPU.
10th August 2017, 13:47 | #44597 | Link |
sooo someone has a GTX 1080TI for less than 100€ 4 me? XD
Just a joke.. madVR now to my real Problem.. i have bad performance issues using D3D11 Exclusiv mode.. by the way i need 10Bit Output.. in D3D9 windowd mode everything works fine but i only get 8Bit Output.. Its not possible to get 10Bit in other ways? And another question to nevcairiel too, why i have so bad paerformance usign lav CUVID and HEVC decoding? H264 works fine under CUVID My GFX Card is a GTX 950 Last edited by Gee; 10th August 2017 at 14:04. |
