24th August 2010, 10:17 | #263 | Link | |
Software Developer
(BTW: Looking forward for any speed-optimization in NNEDI3)
24th August 2010, 17:45 | #264 | Link |
I did try SSIM, but it's hard to effectively use it within the online gradient descent training scheme because the derivative for a single pixel depends on all of the other pixels within the gaussian weighted window around it. That means I can't calculate a single pixel result and then do gradient descent on the model weights unless I assume a value for all of the missing pixels (those which need to be interpolated by the network) and pre-compute the necessary statistics beforehand (so that during training I only have to modify a few values based on the current result to compute the gradient). What I tried was assuming all of the missing values were perfect... that gave results very close to mse training. The one idea I didn't try was starting by assuming all of the missing values were interpolated using cubic interpolation, and after each iteration (after presenting all of the training cases to the network) recalculating all of the ssim statistics that depend on the missing pixels based on the current state of the network. Like a lot of things I plan to try that in the future.
Now if you're not using online gradient descent (say CMA-ES or a fitness function based optimization) you could just run through the training set, interpolate all the necessary pixels, compute ssim for everything at the end. I actually tried that as well, but it takes A LOT more cpu time. Using online gradient descent I can train the 6x48x256 network on 60 million pixels in only a few days on my quadcore desktop. For nnedi2 I was using separable CMA-ES for training (using the scheme I just described) and to train on 1/5 the pixels was taking about 3x longer while using about 4x the cpu power. And nnedi2 is basically equivalent to 4x12x32 in nnedi3 terms. Those are rough numbers of course. Last edited by tritical; 24th August 2010 at 17:56. |
24th August 2010, 19:15 | #265 | Link |
Software Developer
Time to start a nnedi@home project
25th August 2010, 11:04 | #266 | Link | ||
x264 developer
25th August 2010, 16:14 | #267 | Link | ||
EDIT: The partial of ssim with respect to the network output is only for ssim of the 11x11 gaussian weighted window centered on the current pixel. I'm not explicitly taking into account other ssim windows that depend on the network output at this point. Quote:
26th August 2010, 12:17 | #268 | Link |
x264 developer
BTW, modes with more weights than fit in L1d cache are bottlenecked by cache misses, not arithmetic throughput. I didn't rectify this (except insofar as int16 reduces cache footprint too), but you probably want to if you're tuning for nsize>8x6.
28th August 2010, 13:20 | #269 | Link |
Herr
@tritical: Could you please make a comparison of NNEDI3, with the same source as these:
http://forum.doom9.org/showthread.ph...68#post1343668 Thanks |
29th August 2010, 11:42 | #270 | Link | |
5th September 2010, 15:03 | #272 | Link |
I can't get EEDI3 to work with this AA-function:
o=last AssumeBFF().SeparateFields() dbl = mt_Average(SelectEven().EEDI3(field=0),SelectOdd().EEDI3(field=1),U=3,V=3) dblD = mt_MakeDiff(o,dbl,U=3,V=3) shrpD = mt_MakeDiff(dbl,dbl.RemoveGrain(11),U=3,V=3) DD = shrpD.Repair(dblD,13) dbl.mt_AddDiff(DD,U=3,V=3) Last edited by Skauneboy; 5th September 2010 at 15:15. |
5th September 2010, 16:33 | #273 | Link |
Oops, I don't have eedi3.dll at hand ... give a try if it works with the following change?
dbl = mt_Average(SelectEven().EEDI3(field=0),SelectOdd().EEDI3(field=1),U=3,V=3).AssumeFrameBased()
5th September 2010, 19:43 | #275 | Link |
Ah, reading documentation helps. EEDI3 works framebased like NNEDIx, not fieldbased like EEDI2. Try like so:
o=last AssumeBFF() # should not be needed ... EEDI3(field=-2) dbl = merge( selecteven(), selectodd() ) dblD = mt_MakeDiff(o,dbl,U=3,V=3) shrpD = mt_MakeDiff(dbl,dbl.RemoveGrain(11),U=3,V=3) DD = shrpD.Repair(dblD,13) dbl.mt_AddDiff(DD,U=3,V=3)
12th September 2010, 20:34 | #277 | Link |
Huh?
I did some more comparisons using Gabriel Knight's "Making Of" video:
eedi3_rpow2(rfactor=2,cshift="spline36resize",hp=false) nnedi3_rpow2(rfactor=2,nsize=3,nns=4,qual=2,cshift="spline36resize") eedi3_rpow2(alpha=0.3,beta=0,rfactor=2,cshift="spline36resize",hp=true,vcheck=3) Original screen batch here. In my opinion, on the particular filterchain used for this particular source, the first version of EEDI3 gives the more pleasing results.
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. |
13th September 2010, 13:57 | #279 | Link |
lurkster
Thanks also Chainmax. I couldn't choose between them though. Each is good on different areas (parts of mic, side of face), but struggle on others. They are pretty much equal imho, in as far as weighing up the positives and negatives effects.
21st September 2010, 03:10 | #280 | Link |
So I finally got back to working on this, and almost have the next nnedi3 release ready... but one question first. Does anyone using this not have an SSE2 capable processor? I'm considering dropping support for SSE/MMX since it's a pain to keep around and test.
