10th May 2014, 14:09 | #20241 | Link | |
I'll do some testing and see what I can find. [Edit] Yes. I can confirm it is a TSMUXER error. I just tried to remux from a commercial disc that uses in-mux MVC (e.g. AVATAR 3D, playlist 00003) and TSMUXER fails there as well. TSMUXER issues are beyond my control. There is no issue, however, when using BD Rebuilder. BD-RB uses the M2TS directly and it applies all MPLS characteristics (such as chapters) during the rebuild. So, since BD-Rebuilder processes the MPLS itself, the TSMUXER error doesn't affect the its functioning. If you want to create a movie-only version of an in-mux 3D, just select that playlist from within BD-RB and let it run. No problems. The bottom line is that while your report is accurate -- it has no impact on, nor is it a bug within BD Rebuilder. Last edited by jdobbs; 10th May 2014 at 14:55. |
10th May 2014, 15:33 | #20242 | Link |
Hi jdobbs,
I have problems with full 3D backup of the movie Cloudy with a Chance of Meatballs 2 3D. The movie has multi-view/ multi-angle with multiple playlists. If I mount the iso, rebuilding stops at the end by converting SSIF file references (see log). If I rip the movie to an HDD folder, rebuilding finish but the movie hangs between 7.30 - 7,50min. and crashes. Same result with xVxFab. But a movie only rip or 3D SBS full 3D backup works! I try to make a full 3D 25GB backup of this movie since end of February with diffrent programs but no one can handle this movie. At the moment the only thing is to burn the movie to a BD 50GB or make a movie only backup to BD 25GB. ---------------------- [05.07.14] BD Rebuilder v0.47.06 (beta) [04:21:27] Source: CLOUDY_2 - Input BD size: 31,57 GB - Approximate total content: [02:05:56.170] - Target BD size: 22,95 GB - Windows Version: 6.1 [7601] - Quality: Good (Very Fast), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [04:21:27] PHASE ONE, Encoding - [04:21:27] Processing: VID_00102 (1 of 5) - [04:21:27] Extracting A/V streams [VID_00102] - [04:21:42] Reencoding video [VID_00102] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 6.887 frames - Bitrate: 5.999 Kbs - [04:21:42] Reencoding: VID_00102, Pass 1 of 1 - [04:23:30] Video Encode complete - [04:23:30] Processing audio tracks - [04:23:30] Multiplexing M2TS - [04:23:41] Processing: VID_00341 (2 of 5) - [04:23:41] Extracting A/V streams [VID_00341] - [04:23:55] Reencoding video [VID_00341] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2.051 frames - Bitrate: 17.094 Kbs - Using FRIMEncoder for MVC encoding - [04:23:55] Reencoding: VID_00341, Pass 1 of 1 - [04:31:26] Video Encode complete - [04:31:26] Processing audio tracks - Track 4352 (eng): Keeping original audio - [04:31:26] Multiplexing M2TS - [04:31:36] Scanning for 3D CLPI info... - [04:31:40] Processing: VID_00344 (3 of 5) - [04:31:40] Extracting A/V streams [VID_00344] - [04:33:42] Reencoding video [VID_00344] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 10.903 frames - Bitrate: 25.167 Kbs - Using FRIMEncoder for MVC encoding - [04:33:42] Reencoding: VID_00344, Pass 1 of 1 - [05:13:09] Video Encode complete - [05:13:09] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (deu): Keeping original audio - Track 4355 (eng): Keeping original audio - [05:13:09] Multiplexing M2TS - [05:15:12] Scanning for 3D CLPI info... - [05:15:43] Processing: VID_00345 (4 of 5) - [05:15:43] Extracting A/V streams [VID_00345] - [05:15:55] Reencoding video [VID_00345] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 425 frames - Bitrate: 22.232 Kbs - Using FRIMEncoder for MVC encoding - [05:15:55] Reencoding: VID_00345, Pass 1 of 1 - [05:17:30] Video Encode complete - [05:17:30] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (deu): Keeping original audio - Track 4355 (eng): Keeping original audio - [05:17:30] Multiplexing M2TS - [05:17:36] Scanning for 3D CLPI info... - [05:17:37] Processing: VID_00346 (5 of 5) - [05:17:37] Extracting A/V streams [VID_00346] - [05:35:09] Reencoding video [VID_00346] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 125.112 frames - Bitrate: 24.366 Kbs - Using FRIMEncoder for MVC encoding - [05:35:09] Reencoding: VID_00346, Pass 1 of 1 - [13:00:18] Video Encode complete - [13:00:19] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (deu): Keeping original audio - Track 4355 (eng): Keeping original audio - [13:00:19] Multiplexing M2TS - [13:16:24] Scanning for 3D CLPI info... [13:22:23]PHASE ONE complete [13:22:23]PHASE TWO - Rebuild Started - [13:22:23] Converting SSIF file references - ERROR: 3D remuxing failed. Aborted. - Failed to rebuild BD file(s). Aborted. ---------------------- [05.07.14] BD Rebuilder v0.47.06 (beta) [13:25:01] Source: CLOUDY_2 - Input BD size: 31,57 GB - Approximate total content: [02:05:56.170] - Target BD size: 22,95 GB - Windows Version: 6.1 [7601] - Quality: Good (Very Fast), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [13:25:09] PHASE ONE, Encoding [13:25:09]PHASE ONE complete [13:25:09]PHASE TWO - Rebuild Started - [13:25:09] Converting SSIF file references - ERROR: 3D remuxing failed. Aborted. - Failed to rebuild BD file(s). Aborted. ---------------------- Last edited by andref4; 10th May 2014 at 15:41. |
10th May 2014, 16:01 | #20243 | Link |
@andref4
I don't have that disc so I ordered it. This will be my first time ordering a used disc through Amazon, so I'm not sure about the delivery date... I just have to try and keep my personal costs down so it is limited to no more than my donation totals -- I just can't justify (to myself) going in the hole financially to maintain freeware. Last edited by jdobbs; 10th May 2014 at 16:25. |
11th May 2014, 20:00 | #20244 | Link |
Error opening disc structure: Lord of the rings - Return of the king special edition
I just noticed that BD rebuilder versions starting with 0.47.xx cannot open "Lord of the rings - return of the king extended edition (disc2)"
Error 2501 (20:58:56) SourceCheck() 00055 2501 appears in V00.47.05 All versions prior to 00.47.xx have no problems. Last edited by Patrick; 11th May 2014 at 20:53. |
11th May 2014, 21:26 | #20245 | Link | |
13th May 2014, 19:45 | #20248 | Link |
Making 3D BD25 of Marvels The Avengers
Hi jdobbs
I would first like to thank you for the fantastic software you have provided us all with it is truly phenomenal thanks. The reason for my post today is to ask for your feedback on my recent attempt to make a Movie only 3D BD25 of Marvels the Avengers (Avengers Assemble). The Source for my movie is USA Retail Blu-ray. I used AnyDVD HD 7.4.6.0 for decrypting the movie then set up BD Rebuilder v0.47.06 (beta) as follows. My INI File and Log along with BDInfo and Media Info for comparison are as follows. Code:
LOG: ---------------------- [05/08/14] BD Rebuilder v0.47.06 (beta) [21:16:12] Source: MARVELS_THE_AVENGERS_3D_00800 - Input BD size: 40.19 GB - Approximate total content: [02:22:54.899] - Target BD size: 23.83 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: Highest (Very Slow), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [21:16:12] PHASE ONE, Encoding - [21:16:12] Processing: VID_00800 (1 of 1) - [21:16:12] Extracting A/V streams [VID_00800] - [21:18:50] Reencoding video [VID_00800] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 205,592 frames - Bitrate: 16,090 Kbs - Using FRIMEncoder for MVC encoding - [21:18:50] Reencoding: VID_00800, Pass 1 of 1 - [07:15:14] Video Encode complete - [07:15:14] Processing audio tracks - Track 4352 (eng): Keeping original audio [07:15:14]PHASE ONE complete [07:15:14]PHASE TWO - Rebuild Started - [07:15:15] Rebuilding BD-3D file Structure [07:19:54] - Encode and Rebuild complete [07:19:54] JOB: MARVELS_THE_AVENGERS_3D finished. ---------------------- Code:
INI [Status] LABEL=MARVELS_THE_AVENGERS_3D VERSION=v0.47.06 (beta) SOURCE_SIZE=43156592640 SOURCE_VIDEO_SIZE=43156592640 TARGET_SIZE=25585254400 REDUCTION=.592846951876505 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=all BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=0 DGDECIM=0 FRIMSOURCE=0 SSIF_MODE=-1 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00800] AUDIO=100 PGS=1011111111111000 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=25585254400 RATE=16090 NSIZE=0 FLINK=0 MLINK=0 Code:
DISC INFO: Disc Title: MARVELS_THE_AVENGERS_3D Disc Size: 24,302,338,296 bytes Protection: AACS BD-Java: No BDInfo: 0.5.8 PLAYLIST REPORT: Name: 00001.MPLS Length: 2:22:54.899 (h:m:s.ms) Size: 24,302,125,056 bytes Total Bitrate: 22.67 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 8776 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 5217 kbps 7.1 / 48 kHz / 5217 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 36.579 kbps Presentation Graphics Russian 30.633 kbps Presentation Graphics Ukrainian 31.781 kbps Presentation Graphics Swedish 25.619 kbps Presentation Graphics Norwegian 24.535 kbps Presentation Graphics Danish 30.107 kbps Presentation Graphics Finnish 26.513 kbps Presentation Graphics Greek 32.475 kbps Presentation Graphics Bulgarian 31.138 kbps Presentation Graphics Latvian 26.197 kbps Presentation Graphics Lithuanian 30.866 kbps Presentation Graphics Estonian 30.008 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00000.M2TS 0:00:00.000 2:22:54.899 24,302,125,056 22,673 Code:
General Complete name : F:\\BDMV\PLAYLIST\00001.mpls Format : Blu-ray Playlist File size : 714 Bytes Duration : 2h 22mn Overall bit rate mode : Variable Overall bit rate : 1 bps Video #1 ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : 27 Duration : 2h 22mn Bit rate mode : Variable Maximum bit rate : 19.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive format_identifier : HDMV Source : 00000.m2ts / 00000.m2ts Video #2 ID : 4114 (0x1012) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : Stereo High@L4.1 MultiView_Count : 2 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : 32 Duration : 2h 22mn Bit rate mode : Variable Maximum bit rate : 15.9 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive format_identifier : HDMV Source : 00000.m2ts / 00000.m2ts Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Mode : 16 Format settings, Endianness : Big Muxing mode : Stream extension Codec ID : 134 Duration : 2h 22mn Bit rate mode : Variable Bit rate : Unknown / 1 509 Kbps Channel(s) : 8 channels / 6 channels Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossless / Lossy Language : English Source : 00000.m2ts / 00000.m2ts Code:
General Complete name : F:\\BDMV\PLAYLIST\00800.mpls Format : Blu-ray Playlist File size : 878 Bytes Duration : 2h 22mn Overall bit rate mode : Variable Overall bit rate : 1 bps Video ID : 4114 (0x1012) / 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : Stereo High@L4.1 / High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : 27 Duration : 2h 22mn Bit rate mode : Variable Maximum bit rate : 35.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive format_identifier : HDMV Source : 00872.m2ts / 00800.m2ts Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Mode : 16 Format settings, Endianness : Big Muxing mode : Stream extension Codec ID : 134 Duration : 2h 22mn Bit rate mode : Variable Bit rate : Unknown / 1 509 Kbps Channel(s) : 8 channels / 6 channels Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossless / Lossy Language : English Source : 00800.m2ts Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 2h 22mn Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 654 MiB (2%) Language : Russian bsid : 6 dialnorm : -31 dialnorm/String : -31 dB compr : 3.52 compr/String : 3.52 dB dynrng : 3.52 dynrng/String : 3.52 dB acmod : 7 lfeon : 1 dialnorm_Average : -31 dialnorm_Average/String : -31 dB dialnorm_Minimum : -31 dialnorm_Minimum/String : -31 dB dialnorm_Maximum : -31 dialnorm_Maximum/String : -31 dB dialnorm_Count : 560 compr_Average : 3.44 compr_Average/String : 3.44 dB compr_Minimum : -0.28 compr_Minimum/String : -0.28 dB compr_Maximum : 6.02 compr_Maximum/String : 6.02 dB compr_Count : 560 dynrng_Average : 3.49 dynrng_Average/String : 3.49 dB dynrng_Minimum : 0.00 dynrng_Minimum/String : 0.00 dB dynrng_Maximum : 6.02 dynrng_Maximum/String : 6.02 dB dynrng_Count : 560 format_identifier : AC-3 Source : 00800.m2ts Audio #3 ID : 4354 (0x1102) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 2h 22mn Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 654 MiB (2%) Language : Ukrainian bsid : 6 dialnorm : -31 dialnorm/String : -31 dB compr : 5.74 compr/String : 5.74 dB dynrng : 5.60 dynrng/String : 5.60 dB acmod : 7 lfeon : 1 dialnorm_Average : -31 dialnorm_Average/String : -31 dB dialnorm_Minimum : -31 dialnorm_Minimum/String : -31 dB dialnorm_Maximum : -31 dialnorm_Maximum/String : -31 dB dialnorm_Count : 560 compr_Average : 3.68 compr_Average/String : 3.68 dB compr_Minimum : -0.28 compr_Minimum/String : -0.28 dB compr_Maximum : 6.02 compr_Maximum/String : 6.02 dB compr_Count : 560 dynrng_Average : 3.74 dynrng_Average/String : 3.74 dB dynrng_Minimum : 0.00 dynrng_Minimum/String : 0.00 dB dynrng_Maximum : 6.02 dynrng_Maximum/String : 6.02 dB dynrng_Count : 560 format_identifier : AC-3 Source : 00800.m2ts Last edited by jdobbs; 14th May 2014 at 14:47. |
13th May 2014, 22:37 | #20249 | Link | |||
Here the INI file :
Thanks |
14th May 2014, 01:16 | #20250 | Link |
hi, i have a problem with version 47.04.
i was compressing main movie only of DELIVERY MAN. RB completed as always, video ok, audio ok, 1 eng sub NOT ok. playlist 100 is what it selected and it contains 4 min of 6.m2ts and 140 min of 7.m2ts. after the 1st 4 minutes the subtitles do NOT track, the 1st 4 min is fine. i've never really had a problem before using your tools. what i did to solve this is use tsmuxer to extract the subs from playlist 100 in the same source used by RB and mux out your result and mux in the extracted result. that works, the subs are fine throughout the movie, but i have 3 extra minutes of NOTHING at the end of the video playtime, which i then cut and i have a workable disk. i am just curious as to why this would happen now. below is my RB system inspection ... - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, not recommended version - HAALI Splitter: Isn't recommended version - FFDSHOW: 3882, not recommended version - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok the above versions have always worked before, no issues. please respond, thanks or your attention to this matter. |
14th May 2014, 01:31 | #20251 | Link |
There is only 1 solution to that problem. Use the recommended versions of the helper tools. Jdobbs has repeatedly stated that bug reports will NOT be accepted if you're using unsupported versions. Fix that guest p first, then come back
Verstuurd vanaf mijn Nexus 7 met Tapatalk |
14th May 2014, 15:35 | #20254 | Link | |
I'd leave the settings as-is, that's you best course of action. The minimum M2TS size is there to save you unnecessary reencoding time. But if you are determined to reencode 25 additional small files... you can always add a smaller MIN_M2TS_SIZE to your INI file (see HIDDENOPTS.TXT). |
14th May 2014, 15:36 | #20255 | Link |
@jdobbs
How do you check in BDRB if Avisynth is installed? I didn't use the installer but Avisynth is certainly working and the registry entries for the plugin dir are there. Still, I get an error message when I start BDRB that Avisynth is not installed. |
14th May 2014, 15:37 | #20256 | Link | |
I'd like to know if there are issues in the movie-only playback. If not, then BD-RB made the right decision. I just don't want to waste time chasing something that was supposed to happen. Last edited by jdobbs; 14th May 2014 at 16:04. |
14th May 2014, 15:44 | #20257 | Link | |
At startup BD-RB checks the registry for one of these two keys to see if it is installed: HKLM\Software\AviSynth HKLM\Software\Wow6432Node\AviSynth Last edited by jdobbs; 14th May 2014 at 16:15. |
14th May 2014, 16:41 | #20260 | Link | |
What's the reason for the restriction to that directory? When I load avisynth I use something like this: Code:
HINSTANCE hDLL = ::LoadLibrary("avisynth"); if (!hDLL) { sMsg = "Failed to load avisynth.dll"; return FALSE; } |
