13th February 2012, 04:42 | #9041 | Link | |
13th February 2012, 06:13 | #9042 | Link |
Still having issues with CUVID. It will play a video fine for a good 20 minutes then suddenly start dropping frames like crazy. If I go back I still get the dropped frames. It's weird. It only seems to do it on some files (Mostly anime).
13th February 2012, 07:57 | #9043 | Link | |||
Unless i managed to implement some new bugs, it should be more reliable then before, though.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 13th February 2012 at 08:05. |
13th February 2012, 08:51 | #9045 | Link | |
Can of course always just disable CUVID and use DXVA2 or software decoding, that should in theory resolve those issues.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 13th February 2012 at 08:53. |
13th February 2012, 10:31 | #9046 | Link |
CPU:
Renderer: Enhanced Video Renderer (DirectShow) Decoder: Elecard MPEG-2 Video Decoder HD Decoder Device: - Processor Device: - Time: 00:38.814 Average FPS: 249,652 Min/Max FPS: 235 / 259 CPU Usage (%): Avg: 91 Min: 82 Max: 96 Renderer: Enhanced Video Renderer (DirectShow) Decoder: LAV Video Decoder Decoder Device: - Processor Device: - Time: 00:35.739 Average FPS: 271,132 Min/Max FPS: 259 / 284 CPU Usage (%): Avg: 50 Min: 43 Max: 59 Renderer: Enhanced Video Renderer (DirectShow) Decoder: MainConcept MPEG Video Decoder Decoder Device: - Processor Device: - Time: 00:20.826 Average FPS: 465,284 Min/Max FPS: 432 / 484 CPU Usage (%): Avg: 84 Min: 78 Max: 88 Renderer: Enhanced Video Renderer (DirectShow) Decoder: Microsoft DTV-DVD Video Decoder Decoder Device: - Processor Device: - Time: 00:42.881 Average FPS: 225,974 Min/Max FPS: 211 / 239 CPU Usage (%): Avg: 37 Min: 32 Max: 40 Renderer: Enhanced Video Renderer (DirectShow) Decoder: ffdshow Video Decoder Libavcodec Decoder Device: - Processor Device: - Time: 00:35.027 Average FPS: 276,615 Min/Max FPS: 263 / 290 CPU Usage (%): Avg: 54 Min: 45 Max: 63 Renderer: Enhanced Video Renderer (DirectShow) Decoder: ffdshow Video Decoder Libmpeg2 Decoder Device: - Processor Device: - Time: 00:53.579 Average FPS: 180,817 Min/Max FPS: 165 / 200 CPU Usage (%): Avg: 25 Min: 25 Max: 28 Quicksync: Renderer: Enhanced Video Renderer (DirectShow) Decoder: Intel® Media SDK MPEG-2 Decoder Decoder Device: - Processor Device: - Time: 00:11.617 Average FPS: 834,122 Min/Max FPS: 801 / 853 CPU Usage (%): Avg: 21 Min: 18 Max: 25 Renderer: Enhanced Video Renderer (DirectShow) Decoder: ffdshow Video Decoder Decoder Device: ModeMPEG2_VLD Processor Device: - Time: 00:51.235 Average FPS: 189,129 Min/Max FPS: 175 / 195 CPU Usage (%): Avg: 43 Min: 31 Max: 51 Renderer: Enhanced Video Renderer (DirectShow) Decoder: LAV Video Decoder Decoder Device: ModeMPEG2_VLD Processor Device: - Time: 00:44.674 Average FPS: 216,905 Min/Max FPS: 189 / 225 CPU Usage (%): Avg: 47 Min: 40 Max: 53 DXVA2 Copy Back: Renderer: Enhanced Video Renderer (DirectShow) Decoder: LAV Video Decoder Decoder Device: ModeMPEG2_VLD Processor Device: - Time: 00:38.976 Average FPS: 248,615 Min/Max FPS: 243 / 252 CPU Usage (%): Avg: 25 Min: 25 Max: 29 Im not sure about these results (they seem legit but on the other side especially the Quicksync Decoder results make me wonder, though DXVA2 Copy back fits it seems more balanced out for Playback Efficiency then Decoding and it's clearly visible in any Benchmark it is more Power Consumption Efficient though Copy back shouldn't be used for Playback purpose most of the times anyways ) also i couldn't benchmark Mainconcepts Mpeg-2 Decoder this way it crashes DxvaChecker and returns very odd results back with Graphstudio (Next, no real bench is doable it just returns some crazy numbers) most probably the same issue as with the Lav Splitter crashes (though im not sure which splitter is even used as DXVAChecker has no enumeration chose dialog for the splitter anymore it seems) but i find the Intel Decoder Result quiet interesting according to DXVA Checker its ~3x more efficient then either FFdshow quicksync or Lav Video Quicksyn and ~2 more Efficient then Mainconcepts CPU only Decoder Core (with over 50% less utilization) ?
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 13th February 2012 at 10:58. |
13th February 2012, 10:47 | #9047 | Link |
Quick question, I have a i3 2120 using MPC-HC w Lav Filters/EVR custom renderer. Under Lav Video settings - hardware decoder to use, I have 2 available options, Intel Quicksync or DXVA2 (copy) which option would be best? For BD and Remux playback ?
13th February 2012, 11:07 | #9048 | Link |
If your CPU supports it, use QuickSync. A i3 2120 should be fine with it.
13th February 2012, 11:13 | #9049 | Link | |
I've noticed that the CPU usage is around 3-5% when benchmarking after installing 0.46 and with 0.45 it's at 7-11% and yeilding 3x the result which is interesting. Whether it's highlighting a real issue or not I don't know, if everyone else's system is fine then don't waste any time on it, thanks. |
13th February 2012, 12:04 | #9050 | Link | |
@Nev Do you know why the Performance of YV12 in Lav Video is lower as the one in FFdshow aren't both the same ?
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 13th February 2012 at 14:06. |
13th February 2012, 14:45 | #9052 | Link |
Hi, Nevcairiel !
LAV Video Decoder not always switch to hardware mode (for ex.: when using DVB Viewer with H.264 streams). In this case, the decoder reports that hardware acceleration is "Available", but not "Active". It happens not quite often, but still... Maybe 'Pure Hardware Mode' option for LAV Video Decoder will solve it? Intel P4@4GHz, GTX560Ti |
13th February 2012, 14:50 | #9053 | Link |
There is always a reason when it decides to switch to software mode, if it wouldn't do it, it would potentially mean that playback would fail.
Its certainly possible there is somewhere a small issue that makes it fail when it wouldn't need to, but then that should be fixed and not some mode added that bypasses the checks.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 13th February 2012 at 14:59. |
13th February 2012, 15:59 | #9055 | Link |
Alexey are you sure the Stream isn't 4:2:2 ? a pure hardware mode wouldn't help in that case as you would only see Garbage
@ Nev DXVA2 Copy back does really well https://forum.doom9.org/showpost.php...&postcount=754 though Intel got the Kernel pressure nicely under control or is this a bug ?
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 13th February 2012 at 16:08. |
13th February 2012, 16:37 | #9057 | Link | |
In short, not it shouldn't have any impact, unless i start using new functions.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 13th February 2012 at 16:48. |
13th February 2012, 17:19 | #9059 | Link | |
There is GPU Compute capability, which tops out at 2.1 right now, and specifys which features are supported by the GPU. The CUDA SDK version is just the software version to match, and support only depends on drivers.
13th February 2012, 17:33 | #9060 | Link |
Strange issue: using any nVidia GeForce driver since 285.62 and later, cause the problem - image crumbles, tearing into squares, etc. But if I use any earlier driver - there is no problem.
The situation repeating with every new driver release! Any version of LAV Video with CUVID acceleration faces the problem. With CoreAVC Decoder, which uses CUDA too, the same thing! With decoders that uses DXVA everything OK with any driver... Can someone experienced and knows how to fix? Last edited by Alexey1975; 13th February 2012 at 17:42. |
