Old 16th April 2011, 23:55   #11801  |  Link
wolverine3n8
Originally Posted by Ch3vr0n View Post
Jdobbs, you don't have 37.03 lying arround anymore do you if it won't impact coding to much. so i can rebuilt it anyway. The oldest version i have is exactly 37.04 where you added that code.
Here ya go.
http://www.digital-digest.com/softwa...03703.zip.html
wolverine3n8 is offline   Reply With Quote
Old 17th April 2011, 03:54   #11802  |  Link
jdobbs
Originally Posted by KillingTime View Post
Hello,
Just finished compressing Heartbreak Ridge (BD) to 720P and 1080P. The audio is out of sync on both. I would say by about half a second. Enough to be noticeable. BDRebuilder is set to output 448 AC3.
I'm selecting the DTS HD audio track (English). Tried it 3 times now. Same result.
Played the original BD structure back through the same player and the audio is fine.
[04:08:15] BD Rebuilder v0.37.06 (beta)
- Source: HEARTBREAK_RIDGE
- Input BD size: 30.67 GB
- Approximate total content: [02:09:56.830]
- Target BD size: 7.84 GB
- Windows Version: 5.1 [2600]
- MOVIE-ONLY mode enabled
- RESIZE 1080p to 720p enabled
- Quality: High Quality (Default), Two Pass
- Audio Settings: AC3=1 DTS=1 HD=0 Kbs=448
[04:08:15] PHASE ONE, Encoding
- [04:08:15] Extracting A/V streams [VID_00037]
- [04:35:50] Reencoding: VID_00037 (1 of 1)
- [04:35:50] Collecting video information
- Source Video: VC-1, 1920x1080
- Rate/Length: 23.976fps, 186,937 frames
- Convert: 1280x720, 23.976fps, 186,937 frames
- Bitrate: 7,510 Kbs
- [04:35:50] Reencoding: VID_00037, Pass 1 of 2
- [06:13:08] Reencoding: VID_00037, Pass 2 of 2
- [09:25:02] Video Encode complete
- [09:25:02] Reencoding audio tracks (if req'd)
- [09:29:40] Multiplexing M2TS
[09:34:42]PHASE ONE complete
[09:34:42]PHASE TWO - Rebuild Started
- [09:34:42] Rebuilding AVCHD file Structure
[09:39:49] - Encode and Rebuild complete
- WORKFILES folder removed.
[09:39:49]JOB: HEARTBREAK_RIDGE finished.
[13:00:12] BD Rebuilder v0.37.06 (beta)
- Target BD size: 15.63 GB
[13:00:12] PHASE ONE, Encoding
- [13:00:12] Extracting A/V streams [VID_00037]
- [13:27:28] Reencoding: VID_00037 (1 of 1)
- [13:27:28] Collecting video information
- Bitrate: 15,468 Kbs
- [13:27:28] Reencoding: VID_00037, Pass 1 of 2
- [15:06:49] Reencoding: VID_00037, Pass 2 of 2
- [21:24:50] Video Encode complete
- [21:24:50] Reencoding audio tracks (if req'd)
- [21:29:27] Multiplexing M2TS
[21:38:24]PHASE ONE complete
[21:38:24]PHASE TWO - Rebuild Started
- [21:38:24] Rebuilding BD file Structure
[21:49:23] - Encode and Rebuild complete
[21:49:23]JOB: HEARTBREAK_RIDGE finished.
[Status]
LABEL=HEARTBREAK_RIDGE
VERSION=v0.37.06 (beta)
SOURCE_SIZE=32936103936
SOURCE_VIDEO_SIZE=32936103936
TARGET_SIZE=16777216000
REDUCTION=.509386782134303
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=0
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00037]
AUDIO=10000
PGS=1000000000
M2TS_TARGET=16777216000
RATE=15468
NSTART=27000000
NEND=377900640
NSIZE=15774799872
FLINK=0
MLINK=0
Please run INSPECT.EXE and post your results. If it is out of sync it is very likely some version isn't correct.
Website: www.jdobbs.net
Old 17th April 2011, 04:03   #11803  |  Link
had-z
I found a new bug in the dark knight!, is not related with the encode, everything is ok.
The bug is: when the feature "play movie with focus points" is ON and the disc icon appears on the left corner, after press the enter button (to view the behind the scenes stuff of that scene) is played the BTS of another scene...
ie: when i press the enter button in the movie when the joker detonates the hospital a BTS of how they filmed IMAX scenes will play.
had-z is offline   Reply With Quote
Old 17th April 2011, 08:38   #11804  |  Link
A.Fenderson
I got an unusual undersize on Black Swan backup to BD25: it was 21,880,101,204 bytes, or 87% of a BD25, whereas for quite some time, all my BD25 backups have been consistently 95% +/- 1%, no more deviation than that. I always set the option to retain only the BDMV and CERTIFICATE folders, and these were the only folders retained, but the original rip did have one additional folder, DCOPY, containing 2,089,247,182 bytes of data: adding this to the size of the generated backup gives a sum which is ~96% of BD25 capacity. I suspect the math allocating bitrates to the video streams was done prior to subtracting the room saved by dropping the (unusually large) extraneous content in the original rip.
A.Fenderson is offline   Reply With Quote
Old 17th April 2011, 15:43   #11805  |  Link
Ch3vr0n
@Wolverine: thx for trying but apparantly i cant use 37.03. Beta expired. So i'm stuck with a disc i cant compress
Ch3vr0n is offline   Reply With Quote
Old 17th April 2011, 15:58   #11806  |  Link
jdobbs
Give me a day or two and I'll have v0.37.08 out.
Old 17th April 2011, 16:11   #11807  |  Link
KillingTime
Hello,
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: Ok
- FFDSHOW: 3326, Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- BD Rebuilder v0.37.0.6, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
The versions I installed were found from the links provided on your download page.
All my other movies encode correctly (done 15 now). It's only Heartbreak Ridge.
KillingTime is offline   Reply With Quote
Old 17th April 2011, 17:29   #11808  |  Link
Ch3vr0n
No worries mate, when it comes to backing up discs i'm a patient man. I'm only doing full disc backups so if 37.08 only has movie-only mode i can wait some more. Proof of that is that i have several DTS-Express discs already ripped to my harddrive and ready to be compressed with a DTS-E capable BDRB.
How's it coming on that end by the way ? Any luck ?
Old 17th April 2011, 19:27   #11809  |  Link
Megacubo
Chaplin Blu-ray
15th Anniversary Edition
The encode is ok. but when the traileres start (before movie) don't have sound, and the extras don't have sound to. The movie is ok.
v0.37.07
hope you can look in it
Megacubo is offline   Reply With Quote
Old 17th April 2011, 20:15   #11810  |  Link
jdobbs
Originally Posted by Megacubo View Post
Chaplin Blu-ray
v0.37.07
Are you sure you have sound selected for the language in use? What does BD-RB say in the streams list?
Contents of the Log, INI file, and INF files?
Old 18th April 2011, 09:39   #11811  |  Link
setarip_old
setarip_old's Avatar
@Megacubo
Hi!
I believe that if you are making a BD-9 or BD-5, your problem will be resolved if you click on "Settings" and put a checkmark next to "Do not convert DTS to AC3(Blu-ray only)". The disc has more than one type of DTS (HD and SD) - and otherwise, this seems to cause some confusion...
setarip_old is offline   Reply With Quote
Old 21st April 2011, 18:55   #11812  |  Link
mpiper
Has the ability to convert a European (1080i50) Bluray to a US-spec bluray been added?
If not, any suggested work-arounds?
mpiper is offline   Reply With Quote
Old 22nd April 2011, 08:06   #11813  |  Link
A.Fenderson
I Am Legend: reencode to BD25, @ ~18:10 into the .m2ts of the alternate version of the film (00006.m2ts), video pauses briefly then turns grey, audio continues uninterrupted, video resumes moments later but behind the audio by about the amount of time the video had been frozen and greyed out.
Log shows no problems with encode or muxing for this file:
[02:22:33] BD Rebuilder v0.37.07 (beta)
  - Source:  I_AM_LEGEND
  - Input BD size: 37.56 GB
  - Approximate total content: [05:00:15.005]
  - Target BD size: 22.95 GB
  - Quality: Highest (Very Slow), Two Pass
[02:22:33] PHASE ONE, Encoding
 - [02:22:33] Extracting A/V streams [VID_00000]
 - [02:31:56] Reencoding: VID_00000 (1 of 28)
 - [02:31:56] Collecting video information
   - Rate/Length: 23.976fps, 144,615 frames
   - Bitrate: 9,380 Kbs
 - [02:31:56] Reencoding: VID_00000, Pass 1 of 2
 - [05:59:39] Reencoding: VID_00000, Pass 2 of 2
 - [21:29:21] Video Encode complete
 - [21:29:22] Reencoding audio tracks (if req'd)
 - [21:29:22] Multiplexing M2TS
 - [21:36:35] Extracting A/V streams [VID_00006]
 - [21:46:37] Reencoding: VID_00006 (2 of 28)
 - [21:46:37] Collecting video information
   - Rate/Length: 23.976fps, 149,473 frames
   - Bitrate: 9,770 Kbs
 - [21:46:37] Reencoding: VID_00006, Pass 1 of 2
 - [01:21:47] Reencoding: VID_00006, Pass 2 of 2
 - [17:38:48] Video Encode complete
 - [17:38:49] Reencoding audio tracks (if req'd)
 - [17:38:49] Multiplexing M2TS
 - [17:47:14] Extracting A/V streams [VID_00009]
 - [17:48:24] Reencoding: VID_00009 (3 of 28)
 - [17:48:24] Collecting video information
   - Rate/Length: 23.976fps, 29,760 frames
   - Bitrate: 6,953 Kbs
 - [17:48:24] Reencoding: VID_00009, Pass 1 of 2
 - [18:31:14] Reencoding: VID_00009, Pass 2 of 2
  - Encode failed.  Retrying.
 - [01:12:41] Video Encode complete
 - [01:12:42] Reencoding audio tracks (if req'd)
 - [01:12:42] Multiplexing M2TS
 - [01:13:18] Extracting A/V streams [VID_00010]
 - [01:13:40] Reencoding: VID_00010 (4 of 28)
 - [01:13:40] Collecting video information
   - Source Video: VC-1, 720x480
   - Rate/Length: 29.970fps, 10,460 frames
   - Bitrate: 3,376 Kbs
 - [01:13:40] Reencoding: VID_00010, Pass 1 of 2
 - [01:17:08] Reencoding: VID_00010, Pass 2 of 2
 - [01:31:33] Video Encode complete
 - [01:31:33] Reencoding audio tracks (if req'd)
 - [01:31:33] Multiplexing M2TS
 - [01:31:38] Extracting A/V streams [VID_00011]
 - [01:31:54] Reencoding: VID_00011 (5 of 28)
 - [01:31:54] Collecting video information
   - Rate/Length: 29.970fps, 8,913 frames
   - Bitrate: 3,364 Kbs
 - [01:31:54] Reencoding: VID_00011, Pass 1 of 2
 - [01:34:53] Reencoding: VID_00011, Pass 2 of 2
 - [01:47:45] Video Encode complete
 - [01:47:45] Reencoding audio tracks (if req'd)
 - [01:47:45] Multiplexing M2TS
 - [01:47:49] Extracting A/V streams [VID_00012]
 - [01:47:58] Reencoding: VID_00012 (6 of 28)
 - [01:47:58] Collecting video information
   - Rate/Length: 29.970fps, 5,399 frames
   - Bitrate: 3,346 Kbs
 - [01:47:58] Reencoding: VID_00012, Pass 1 of 2
 - [01:49:42] Reencoding: VID_00012, Pass 2 of 2
 - [01:56:30] Video Encode complete
 - [01:56:30] Reencoding audio tracks (if req'd)
 - [01:56:30] Multiplexing M2TS
 - [01:56:34] Extracting A/V streams [VID_00013]
 - [01:56:41] Reencoding: VID_00013 (7 of 28)
 - [01:56:41] Collecting video information
   - Rate/Length: 29.970fps, 4,314 frames
   - Bitrate: 3,369 Kbs
 - [01:56:41] Reencoding: VID_00013, Pass 1 of 2
 - [01:58:05] Reencoding: VID_00013, Pass 2 of 2
 - [02:03:46] Video Encode complete
 - [02:03:46] Reencoding audio tracks (if req'd)
 - [02:03:46] Multiplexing M2TS
 - [02:03:49] Extracting A/V streams [VID_00014]
 - [02:03:54] Reencoding: VID_00014 (8 of 28)
 - [02:03:54] Collecting video information
   - Rate/Length: 29.970fps, 3,218 frames
   - Bitrate: 3,387 Kbs
 - [02:03:54] Reencoding: VID_00014, Pass 1 of 2
 - [02:04:58] Reencoding: VID_00014, Pass 2 of 2
 - [02:09:29] Video Encode complete
 - [02:09:29] Reencoding audio tracks (if req'd)
 - [02:09:29] Multiplexing M2TS
 - [02:09:32] Extracting A/V streams [VID_00015]
 - [02:09:42] Reencoding: VID_00015 (9 of 28)
 - [02:09:42] Collecting video information
   - Rate/Length: 29.970fps, 6,236 frames
   - Bitrate: 3,355 Kbs
 - [02:09:43] Reencoding: VID_00015, Pass 1 of 2
 - [02:11:44] Reencoding: VID_00015, Pass 2 of 2
 - [02:19:46] Video Encode complete
 - [02:19:46] Reencoding audio tracks (if req'd)
 - [02:19:46] Multiplexing M2TS
 - [02:19:50] Extracting A/V streams [VID_00016]
 - [02:19:55] Reencoding: VID_00016 (10 of 28)
 - [02:19:55] Collecting video information
   - Rate/Length: 29.970fps, 3,321 frames
   - Bitrate: 3,357 Kbs
 - [02:19:55] Reencoding: VID_00016, Pass 1 of 2
 - [02:20:59] Reencoding: VID_00016, Pass 2 of 2
 - [02:25:02] Video Encode complete
 - [02:25:02] Reencoding audio tracks (if req'd)
 - [02:25:02] Multiplexing M2TS
 - [02:25:05] Extracting A/V streams [VID_00017]
 - [02:25:11] Reencoding: VID_00017 (11 of 28)
 - [02:25:11] Collecting video information
   - Rate/Length: 29.970fps, 3,725 frames
   - Bitrate: 3,321 Kbs
 - [02:25:11] Reencoding: VID_00017, Pass 1 of 2
 - [02:26:22] Reencoding: VID_00017, Pass 2 of 2
 - [02:30:46] Video Encode complete
 - [02:30:46] Reencoding audio tracks (if req'd)
 - [02:30:46] Multiplexing M2TS
 - [02:30:49] Extracting A/V streams [VID_00018]
 - [02:30:55] Reencoding: VID_00018 (12 of 28)
 - [02:30:55] Collecting video information
   - Rate/Length: 29.970fps, 4,094 frames
   - Bitrate: 3,370 Kbs
 - [02:30:55] Reencoding: VID_00018, Pass 1 of 2
 - [02:32:18] Reencoding: VID_00018, Pass 2 of 2
 - [02:37:39] Video Encode complete
 - [02:37:39] Reencoding audio tracks (if req'd)
 - [02:37:39] Multiplexing M2TS
 - [02:37:42] Extracting A/V streams [VID_00019]
 - [02:37:45] Reencoding: VID_00019 (13 of 28)
 - [02:37:45] Collecting video information
   - Rate/Length: 29.970fps, 1,986 frames
   - Bitrate: 3,348 Kbs
 - [02:37:45] Reencoding: VID_00019, Pass 1 of 2
 - [02:38:24] Reencoding: VID_00019, Pass 2 of 2
 - [02:40:58] Video Encode complete
 - [02:40:58] Reencoding audio tracks (if req'd)
 - [02:40:58] Multiplexing M2TS
 - [02:40:59] Extracting A/V streams [VID_00020]
 - [02:41:07] Reencoding: VID_00020 (14 of 28)
 - [02:41:07] Collecting video information
   - Rate/Length: 29.970fps, 4,199 frames
   - Bitrate: 3,365 Kbs
 - [02:41:07] Reencoding: VID_00020, Pass 1 of 2
 - [02:42:31] Reencoding: VID_00020, Pass 2 of 2
 - [02:48:02] Video Encode complete
 - [02:48:02] Reencoding audio tracks (if req'd)
 - [02:48:02] Multiplexing M2TS
 - [02:48:05] Extracting A/V streams [VID_00021]
 - [02:48:11] Reencoding: VID_00021 (15 of 28)
 - [02:48:11] Collecting video information
   - Rate/Length: 29.970fps, 3,425 frames
   - Bitrate: 3,373 Kbs
 - [02:48:11] Reencoding: VID_00021, Pass 1 of 2
 - [02:49:18] Reencoding: VID_00021, Pass 2 of 2
 - [02:53:40] Video Encode complete
 - [02:53:40] Reencoding audio tracks (if req'd)
 - [02:53:40] Multiplexing M2TS
 - [02:53:42] Extracting A/V streams [VID_00022]
 - [02:53:46] Reencoding: VID_00022 (16 of 28)
 - [02:53:46] Collecting video information
   - Rate/Length: 29.970fps, 2,883 frames
   - Bitrate: 3,352 Kbs
 - [02:53:47] Reencoding: VID_00022, Pass 1 of 2
 - [02:54:41] Reencoding: VID_00022, Pass 2 of 2
 - [02:58:47] Video Encode complete
 - [02:58:47] Reencoding audio tracks (if req'd)
 - [02:58:47] Multiplexing M2TS
 - [02:58:49] Extracting A/V streams [VID_00023]
 - [02:58:56] Reencoding: VID_00023 (17 of 28)
 - [02:58:56] Collecting video information
   - Rate/Length: 29.970fps, 4,530 frames
   - Bitrate: 3,392 Kbs
 - [02:58:56] Reencoding: VID_00023, Pass 1 of 2
 - [03:00:34] Reencoding: VID_00023, Pass 2 of 2
 - [03:07:26] Video Encode complete
 - [03:07:26] Reencoding audio tracks (if req'd)
 - [03:07:26] Multiplexing M2TS
 - [03:07:29] Extracting A/V streams [VID_00024]
 - [03:07:35] Reencoding: VID_00024 (18 of 28)
 - [03:07:35] Collecting video information
   - Rate/Length: 29.970fps, 3,663 frames
   - Bitrate: 3,360 Kbs
 - [03:07:36] Reencoding: VID_00024, Pass 1 of 2
 - [03:08:57] Reencoding: VID_00024, Pass 2 of 2
 - [03:14:03] Video Encode complete
 - [03:14:03] Reencoding audio tracks (if req'd)
 - [03:14:03] Multiplexing M2TS
 - [03:14:06] Extracting A/V streams [VID_00025]
 - [03:14:12] Reencoding: VID_00025 (19 of 28)
 - [03:14:12] Collecting video information
   - Rate/Length: 29.970fps, 4,128 frames
 - [03:14:13] Reencoding: VID_00025, Pass 1 of 2
 - [03:15:35] Reencoding: VID_00025, Pass 2 of 2
 - [03:21:04] Video Encode complete
 - [03:21:04] Reencoding audio tracks (if req'd)
 - [03:21:04] Multiplexing M2TS
 - [03:21:07] Extracting A/V streams [VID_00026]
 - [03:21:15] Reencoding: VID_00026 (20 of 28)
 - [03:21:15] Collecting video information
   - Rate/Length: 29.970fps, 4,914 frames
   - Bitrate: 3,375 Kbs
 - [03:21:15] Reencoding: VID_00026, Pass 1 of 2
 - [03:22:52] Reencoding: VID_00026, Pass 2 of 2
 - [03:29:37] Video Encode complete
 - [03:29:37] Reencoding audio tracks (if req'd)
 - [03:29:37] Multiplexing M2TS
 - [03:29:40] Extracting A/V streams [VID_00027]
 - [03:29:45] Reencoding: VID_00027 (21 of 28)
 - [03:29:45] Collecting video information
   - Rate/Length: 29.970fps, 3,048 frames
 - [03:29:45] Reencoding: VID_00027, Pass 1 of 2
 - [03:30:47] Reencoding: VID_00027, Pass 2 of 2
 - [03:35:06] Video Encode complete
 - [03:35:06] Reencoding audio tracks (if req'd)
 - [03:35:06] Multiplexing M2TS
 - [03:35:08] Extracting A/V streams [VID_00028]
 - [03:35:15] Reencoding: VID_00028 (22 of 28)
 - [03:35:15] Collecting video information
   - Rate/Length: 29.970fps, 3,797 frames
   - Bitrate: 3,425 Kbs
 - [03:35:15] Reencoding: VID_00028, Pass 1 of 2
 - [03:36:28] Reencoding: VID_00028, Pass 2 of 2
 - [03:41:16] Video Encode complete
 - [03:41:16] Reencoding audio tracks (if req'd)
 - [03:41:16] Multiplexing M2TS
 - [03:41:18] Extracting A/V streams [VID_00029]
 - [03:41:25] Reencoding: VID_00029 (23 of 28)
 - [03:41:25] Collecting video information
   - Rate/Length: 29.970fps, 4,167 frames
   - Bitrate: 3,362 Kbs
 - [03:41:25] Reencoding: VID_00029, Pass 1 of 2
 - [03:42:45] Reencoding: VID_00029, Pass 2 of 2
 - [03:47:58] Video Encode complete
 - [03:47:58] Reencoding audio tracks (if req'd)
 - [03:47:58] Multiplexing M2TS
 - [03:48:01] Extracting A/V streams [VID_00030]
 - [03:48:06] Reencoding: VID_00030 (24 of 28)
 - [03:48:06] Collecting video information
   - Rate/Length: 29.970fps, 3,053 frames
 - [03:48:06] Reencoding: VID_00030, Pass 1 of 2
 - [03:49:05] Reencoding: VID_00030, Pass 2 of 2
 - [03:53:29] Video Encode complete
 - [03:53:29] Reencoding audio tracks (if req'd)
 - [03:53:29] Multiplexing M2TS
 - [03:53:32] Extracting A/V streams [VID_00031]
 - [03:53:41] Reencoding: VID_00031 (25 of 28)
 - [03:53:41] Collecting video information
   - Rate/Length: 23.976fps, 4,388 frames
   - Bitrate: 6,730 Kbs
 - [03:53:41] Reencoding: VID_00031, Pass 1 of 2
 - [03:59:09] Reencoding: VID_00031, Pass 2 of 2
 - [04:20:34] Video Encode complete
 - [04:20:34] Reencoding audio tracks (if req'd)
 - [04:20:34] Multiplexing M2TS
 - [04:20:39] Extracting A/V streams [VID_00032]
 - [04:21:01] Reencoding: VID_00032 (26 of 28)
 - [04:21:01] Collecting video information
   - Rate/Length: 23.976fps, 9,518 frames
   - Bitrate: 6,884 Kbs
 - [04:21:02] Reencoding: VID_00032, Pass 1 of 2
 - [04:34:08] Reencoding: VID_00032, Pass 2 of 2
 - [05:30:17] Video Encode complete
 - [05:30:17] Reencoding audio tracks (if req'd)
 - [05:30:17] Multiplexing M2TS
 - [05:30:27] Extracting A/V streams [VID_00033]
 - [05:30:39] Reencoding: VID_00033 (27 of 28)
 - [05:30:39] Collecting video information
   - Rate/Length: 23.976fps, 5,047 frames
   - Bitrate: 6,658 Kbs
 - [05:30:39] Reencoding: VID_00033, Pass 1 of 2
 - [05:37:05] Reencoding: VID_00033, Pass 2 of 2
 - [06:02:27] Video Encode complete
 - [06:02:27] Reencoding audio tracks (if req'd)
 - [06:02:27] Multiplexing M2TS
 - [06:02:32] Extracting A/V streams [VID_00034]
 - [06:03:01] Reencoding: VID_00034 (28 of 28)
 - [06:03:01] Collecting video information
   - Rate/Length: 23.976fps, 12,476 frames
   - Bitrate: 6,828 Kbs
 - [06:03:02] Reencoding: VID_00034, Pass 1 of 2
 - [06:20:17] Reencoding: VID_00034, Pass 2 of 2
 - [07:26:47] Video Encode complete
 - [07:26:47] Reencoding audio tracks (if req'd)
 - [07:26:47] Multiplexing M2TS
[07:26:59]PHASE ONE complete
[07:26:59]PHASE TWO - Rebuild Started
 - [07:26:59] Rebuilding BD file Structure
[07:27:06] - Encode and Rebuild complete
[07:27:06]JOB: I_AM_LEGEND finished.
Note that while video encoding of 00009.m2ts initially failed, it successfully retried, and the reencoded file shows no problems whatsoever.
Walking Dead, Season 1, Disc 2: reencode to BD25, @ ~33:45 into the .m2ts of the final episode (00101.m2ts), video pauses briefly then turns grey, audio jumps ahead twice quickly, video resumes moments later but behind the audio by about the amount of time the video had been frozen and greyed out. I had unfortunately already deleted the logfile prior to discovering the issue.
I am not overclocked. X264 has crashed and needed to restart during approximately 3 encodes since changing to BD-RB 0.37.07, and rarely if ever prior to that.
Could be a hardware issue on this end, but other than this I've been fairly stable for quite some time on this machine and using it with BD-RB near-constantly for months (two-pass very-slow earns its name on my outdated machine!).
Old 22nd April 2011, 13:40   #11814  |  Link
jdobbs
@A.Fenderson
Are you experimenting with other versions of the software I have linked in the first post of this thread? What you are describing sure sounds like it.
Old 22nd April 2011, 17:43   #11815  |  Link
A.Fenderson
@A.Fenderson
- FFDSHOW: 3326, Ok
- BD Rebuilder v0.37.0.7, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Old 22nd April 2011, 18:28   #11816  |  Link
jdobbs
- FFDSHOW: 3326, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
I suggest you try this recommendation from the setup instructions:
8. Recommended for Windows XP only: Download and install WMV11 from Microsoft, and set VC-1 decoding to "disabled" in FFDSHOW (allowing the WMV11 codec to be used). This seems to be the codec with the fewest problem on VC-1. For Vista or Windows 7 -- select "wmv9"
Old 22nd April 2011, 18:53   #11817  |  Link
A.Fenderson
Wow, I missed that somehow. Thanks, I'll do that.
I'm also running Windows Memory Diagnostic (the tool is a bootable 32-bit program you run from CD, so can test 4GB RAM max, but otherwise it works on any system), in the extended tests mode, and it will run 9+ hours while I'm away, so if there is a RAM problem that should find it--I've had it catch problems with a bad stick in the past. If it's useful for anyone else, Vista (and presumably 7) have a version of this built-in.
Old 22nd April 2011, 21:29   #11818  |  Link
rccland
Failed Video Encode error!
BD-RB System Inspection Results:
- Windows Version: 6.0 [6002]
- FFDSHOW: 3326, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
BD-RB LOG:
[16:47:18] BD Rebuilder v0.37.07 (beta)
- Source: DIEANOTHERDAY
- Input BD size: 36.90 GB
- Approximate total content: [04:35:31.163]
- Quality: High-Speed Option (BD-25), Two Pass
[16:47:24] PHASE ONE, Encoding
- [16:47:24] Extracting A/V streams [VID_00172]
- [16:47:28] Reencoding: VID_00172 (1 of 56)
- [16:47:28] Collecting video information
- Rate/Length: 23.976fps, 772 frames
- Bitrate: 11,839 Kbs
- [16:47:28] Reencoding: VID_00172, Pass 1 of 2
- [16:47:28] Reencoding: VID_00172, Pass 2 of 2
- [16:48:16] Video Encode complete
- [16:48:16] Reencoding audio tracks (if req'd)
- [16:48:16] Multiplexing M2TS
- [16:48:22] Extracting A/V streams [VID_00132]
- [16:48:28] Reencoding: VID_00132 (2 of 56)
- [16:48:28] Collecting video information
[16:48:29] - Failed video encode, aborted
BD-RB Settings:
[Status]
LABEL=DIEANOTHERDAY
VERSION=v0.37.07 (beta)
SOURCE_SIZE=39618241837
SOURCE_VIDEO_SIZE=38822092800
TARGET_SIZE=24641536000
REDUCTION=.614222089619033
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
QUICK=1
ENCODE_STEP=1
COMPLETED=1
[00172]
AUDIO=100111
PGS=10001
M2TS_TARGET=67044985
RATE=11839
NSTART=27000000
NEND=28448640
NSIZE=65040384
FLINK=-1
MLINK=0
[00132]
AUDIO=100111
PGS=10001
M2TS_TARGET=93201366
So I am trying to REBUILD the movie "DIE ANOTHER DAY" so that it would fit on a BD-R. I ran it 6 times and I keep getting the same error as posted in the above error log. I havent changed anything and before this I have been able to successfully backup more than 10 Blu-Rays.
Please Help. Why am I getting the "FAILED VIDEO ENCODE" error.
rccland is offline   Reply With Quote
Old 22nd April 2011, 21:47   #11819  |  Link
jdobbs
@rccland
Completely uninstall AVISYNTH, HAALI, FFDSHOW, and BD-RB. Then install them all from scratch. Sometimes other programs change defaults or intercept CODECs and INSPECT won't catch it. A reinstall will usually fix it.
Old 22nd April 2011, 22:01   #11820  |  Link
rccland
@rccland
Thanks JDOBBS. I will try your suggestion. As for install instruction I will follow the instruction thats posted on the first page of this forum.
Also just for a test I tried to re-build CASINO ROYALE and it worked fine. It worked fine before so I thought if I did mess up the settings then CASINO ROYALE wont work this time but it worked FINE
Just something to think about.
