Old 10th April 2011, 18:27   #11741  |  Link
1Bullet
I hate to say it again... but are you overclocked? It sounds like X264 is crashing mid-encode.
No I am not overclocked
I will try stepping back a version of X264.
I have a power supply tester will check it out. I have been stable up till now.
1Bullet is offline   Reply With Quote
Old 10th April 2011, 18:39   #11742  |  Link
jdobbs
Find and run a utility that checks CPU temperature and look at it a couple of hours into the encode. Overclocking is the most common cause of overheating, but not the only one. You might look at your CPU's heatsink for dust buildup.
System issues are much more likely to be the problem than X264. Lots of other people are running the latest versions of BD-RB and X264 without issues.
I start hearing these kinds of reports every year when spring/summer comes around (most from overclocked systems). You'll see another one a little way back in this thread (but he refused to consider that his system might be at fault). Normally when X264 encounters an error, BD-RB will catch it by examining the O/S's returned error code. But when it is related to system instability it is unlikely that an error code will be returned. When that happens, all you end up with is a partial video encode that gets multiplexed into the output stream.
Website: www.jdobbs.net
Old 10th April 2011, 19:15   #11743  |  Link
Sharc
Just a note for those folks who do a lot of resizing to 720p.
I've been looking through the SUP file format and doing some work in resizing (to support subtitle conversion when outputting to DVD and fix the "forced flag" issue). In doing so I've just happened to have stumbled across the cause of the TSMUXER error that causes occasional failures when resizing to 720p. ............
........... I'm going to have to come up with some other way of resizing them.
Just thought it was interesting and wanted to let you know...
That's really exciting news. Would be great to have a solution for the (seldom, but annoying) 720p sups failure of TSMUXER, plus sub support for DVD output
Old 10th April 2011, 19:22   #11744  |  Link
jdobbs
Hey, I just sent you a PM about that one... Not too long ago I was convinced it was a ripping issue.
Old 10th April 2011, 19:32   #11745  |  Link
jdobbs
I have the DVD resizing working and it will be in the next release. There are some limits, though, when converting from a format that allows 256 colors to one that uses 4. But based on my testing it is still pretty good.
Old 10th April 2011, 20:40   #11746  |  Link
Discoboy
The Object_Definition_Segment that includes all the information for actually drawing the subtitle image (stored as run-length encoded data) normally consists of only a single sequence (the graphic image of the text). Good enough, as the graphics for text is fairly small in most circumstances. But the Object_Definition_Segment has a mechanism for handling multiple sequences of graphic data (so large bitmaps can be divided into multiple parts each less than 64K long). It appears TSMUXER doesn't have the capability to handle those multiple sequences and dies when it encounters them (with the error "Unexpected byte").
The good news is that since these sequences are generally used in graphic overlays that aren't related to subtitles -- I can make BD Rebuilder ignore them completely when doing a movie-only encode. For full backups, however, the graphics are needed (usually to handle some type of special feature like pop-up selections etc.) I'm going to have to come up with some other way of resizing them.
Thanks for the update jdobbs
Discoboy is offline   Reply With Quote
Old 10th April 2011, 21:27   #11747  |  Link
had-z
All my problems was solved with clearing the register of the ffdshow!! now i can backup without the fear of bad frames or macroblocks...
If i can help to solve the problem with black hawk down uploading a file (clpi or mpls) i will be even more happy! I'm very curious to see how will look a MPEG2-source encoded with the superior x264. (BHD is the only BD i have with the main movie encoded in MPEG-2)
Thanks Again Jdobbs.
had-z is offline   Reply With Quote
Old 11th April 2011, 00:35   #11748  |  Link
setarip_old
setarip_old's Avatar
@jdobbs
Be careful - The last time you did that you fell off your roof ;>}
setarip_old is offline   Reply With Quote
Old 11th April 2011, 02:19   #11749  |  Link
wolverine3n8
That's good news. I do resizing quite often and have noticed the "english subs for non-english parts" didn't show up in the rebuilt version. This will be a great improvement to an already excellent program. Thanks.
wolverine3n8 is offline   Reply With Quote
Old 11th April 2011, 05:07   #11750  |  Link
jdobbs
Originally Posted by setarip_old View Post
@jdobbs Be careful - The last time you did that you fell off your roof ;>}
Hah! Good point. I haven't had the best luck with the "stumbling" lately. In fact I'm still on crutches.
Old 11th April 2011, 14:19   #11751  |  Link
Ch3vr0n
Any news on my HP5 issue ? See previous post (all eng language streams, that are not all eng)
Ch3vr0n is offline   Reply With Quote
Old 11th April 2011, 16:31   #11752  |  Link
jetli
is there a way to make rebuilder take an mpeg2 1080p file and compress it using x264 and then fit on a bd25???
if so how?
jet
jetli is offline   Reply With Quote
Old 11th April 2011, 23:26   #11753  |  Link
Video Dude
Senior Member
Does anyone experience chapter points that are off by about 0.5 seconds?
The original discs navigate chapter to chapter perfect. But when I play a backup and skip chapter to chapter I get the last couple frames of the previous chapter. It happens with every movie I do and all of them are movie only, no re-encode backups. (PowerDVD & Sony S370)
I examined the BD-RB output using Don Graft's tool to identify the IDR frame numbers and compared that to the chapter time codes displayed in BDEdit. I found that the BD-RB output is correct. The IDR frames match up exact with the chapter time codes.
Does this happen to anyone else? I can't figure out what could be causing this.
Video Dude is offline   Reply With Quote
Old 11th April 2011, 23:44   #11754  |  Link
Capsbackup
if so how?
jet
This is a bug reports thread!
BD-RB is able to work with original Blu-ray rips, not individual files. You could use tsMuxeR to create a Blu-ray with your mpeg2 file if it is compliant, then use BD-RB on that output.
Capsbackup is offline   Reply With Quote
Old 11th April 2011, 23:54   #11755  |  Link
A.Fenderson
So you're essentially just using BD-RB to remux the main-movie playlist, right? Have you checked the IDR and chapter-points on the original rip, and do they exactly match what comes out of BD-RB?
A.Fenderson is offline   Reply With Quote
Old 12th April 2011, 00:30   #11756  |  Link
Video Dude
Senior Member
I went back and checked the last backup I did since I still have the files on my hard drive (Fantasia 2000, movie only, no re-encode).
I extracted the chapters using both tsmuxer and BDedit. Playlist 00800 (I double checked it was the playlist BD-RB used). I noticed that there is a slight difference that could explain why my backups show the last few frames of the previous chapter when I skip chapters.
BDedit (frame number format)
Original   Backup
0              0
1833        1809
5958        5934
8070        8046
22785      22761
24120      24096
42163      42139
43989      43965
54763      54739
55804      55780
58548      58524
60816      60791
74627      74603
76046      76022
85089      85065
85660      85636
98928      98904
107232    107207
BDedit (PTS format)
Original       Backup
        0           0
  3397143     3397140
 11139253    11139210
 15103213    15103169
 42721428    42721425
 45225180    45225180
 79091512    79091505
 82518686    82518660
102740137   102740130
104693964   104693940
109844109   109844100
114098985   114098940
140022382   140022360
142685668   142685640
159658248   159658245
160729944   160729920
185630445   185630445
201216015   201215970
tsMuxer
Original         Backup
00:00:00.000    00:00:00.000
00:01:16.493    00:01:15.492
00:04:08.539    00:04:07.538
00:05:36.627    00:05:35.625
00:15:50.366    00:15:49.365
00:16:46.004    00:16:45.004
00:29:18.590    00:29:17.588
00:30:34.749    00:30:33.748
00:38:04.115    00:38:03.114
00:38:47.533    00:38:46.532
00:40:41.981    00:40:40.980
00:42:16.534    00:42:15.532
00:51:52.609    00:51:51.608
00:52:51.793    00:52:50.791
00:59:08.962    00:59:07.960
00:59:32.777    00:59:31.775
01:08:46.122    01:08:45.121
01:14:32.467    01:14:31.466
Log:
[21:10:27] BD Rebuilder v0.37.05 (beta)
  - Source:  FANTASIA_2000
  - Input BD size: 21.12 GB
  - Approximate total content: [01:14:32.718]
  - Target BD size: 22.95 GB
  - Windows Version: 5.1 [2600]
  - MOVIE-ONLY mode enabled
  - Quality: High Quality (Default), Two Pass
  - Audio [1] set to default.
[21:10:27] PHASE ONE, Encoding
 - [21:10:27] Extracting A/V streams [VID_00800]
 - [21:21:57] Reencoding: VID_00800 (1 of 1)
 - [21:21:57] Collecting video information
 - [21:21:57] Keeping original video (no reencode)
 - [21:21:57] Reencoding audio tracks (if req'd)
 - [21:21:57] Multiplexing M2TS
[21:29:49]PHASE ONE complete
[21:29:49]PHASE TWO - Rebuild Started
 - [21:29:49] Rebuilding BD file Structure
[21:40:23] - Encode and Rebuild complete
[21:40:23]JOB: FANTASIA_2000 finished.
INI
[Status]
LABEL=FANTASIA_2000
VERSION=v0.37.05 (beta)
SOURCE_SIZE=22681344000
SOURCE_VIDEO_SIZE=22681344000
TARGET_SIZE=24641536000
REDUCTION=1.08642309732615
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=-1
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00800]
USE_ORIGINAL=1
AUDIO=10000
PGS=1000000000
M2TS_TARGET=24641536000
NSTART=27000000
NEND=228272160
NSIZE=17532819456
FLINK=0
MLINK=0
Old 12th April 2011, 13:49   #11757  |  Link
jdobbs
Not to me... my movie-only encodes are frame-accurate to the chapter point.
Old 12th April 2011, 15:25   #11758  |  Link
jdobbs
Well, I got my HP5 disc back -- but it is cracked and unplayable (a good reason not to loan my originals). All I have is a movie-only backup of it... so I guess I'm going to have to buy it again to test it.
[Edit] Ok. It's on its way. It was only $10 at Amazon. I should get it Thursday.
Old 12th April 2011, 17:32   #11759  |  Link
KillingTime
Backing up the extras on Batman Darknight (alternate movie only selection) to a BD5.
I don't know what the error message means.
I looked in the workfiles folder, and the m2ts was playable, but no audio.
[12:32:21] BD Rebuilder v0.37.06 (beta)
- Source: BATMAN_THEDARKKNIGHT_BD
- Input BD size: 5.28 GB
- Approximate total content: [01:04:10.880]
- Target BD size: 4.36 GB
- RESIZE 1080p to 720p enabled
- Audio Settings: AC3=1 DTS=1 HD=0 Kbs=448
[12:32:21] PHASE ONE, Encoding
- [12:32:21] Extracting A/V streams [VID_00009]
- [12:36:48] Reencoding: VID_00009 (1 of 1)
- [12:36:48] Collecting video information
- Source Video: VC-1, 1920x1080
- Rate/Length: 29.970fps, 115,411 frames
- Convert: 1280x720, 59.940fps, 230,822 frames
- Bitrate: 8,752 Kbs
- [12:36:48] Reencoding: VID_00009, Pass 1 of 2
- [13:40:13] Reencoding: VID_00009, Pass 2 of 2
- [15:45:40] Video Encode complete
- [15:45:40] Reencoding audio tracks (if req'd)
- [15:46:00] Multiplexing M2TS
[15:48:17]PHASE ONE complete
[15:48:17]PHASE TWO - Rebuild Started
- [15:48:17] Rebuilding AVCHD file Structure
- Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta
- Non standart fps value do not supported for PGS streams
[15:48:18] - Failed to REBUILD
[Status]
LABEL=BATMAN_THEDARKKNIGHT_BD
VERSION=v0.37.06 (beta)
SOURCE_SIZE=5673154560
SOURCE_VIDEO_SIZE=5673154560
TARGET_SIZE=4686086144
REDUCTION=.826010660284214
RESIZE_1080=-1
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=0
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=0
[00009]
AUDIO=1
PGS=01000000000000
M2TS_TARGET=4686086144
RATE=8752
NSTART=27000000
NEND=200288862
NSIZE=4435556352
FLINK=0
MLINK=0
KillingTime is offline   Reply With Quote
Old 12th April 2011, 17:48   #11760  |  Link
jdobbs
@KillingTime
Are you working from an original disc? I tried both of the Region 1 "Dark Knight" discs and there is no playlist that contains only 00009.m2ts. I did, however find one on Disc 1 that is 0008.m2ts and is the exact same length as yours. I'm running it now.
