Old 21st March 2009, 12:29   #2161  |  Link
Furiousflea
Originally Posted by Furiousflea View Post
You might have to sit in naughty corner when jdobbs reads this post This would work most likely as DTS\DSTHD\DTSMA share same tag....TrueHD\AC3 share same tag. LPCM does not share same tag as AC3 which it would be encoded to so that wouldn't work at this time.
I'm posting this just so nobody wastes their time trying it with LPCM and please don't report any problems doing this here.
Your on your own
Just did a thorough check of this method to inject HD audio and it does NOT work. DTS will appear to be playing, but if you check it will only be normal DTS and not MA. TrueHD won't work at all.
Don't try it.
Furiousflea is offline   Reply With Quote
Old 21st March 2009, 12:31   #2162  |  Link
Furiousflea
Originally Posted by datman View Post
for all I know this was a W7 error. Many of my problem are in my setup or just lack of understanding some of the little stuff. Many are just glitches and I have half a mind to go back to XP and see how it does
Vista 64 is good with 4GB+ of ram with a few tweaks applied.
W7 is still in beta. I really don't know why anyone is bothering with it.
Old 21st March 2009, 13:31   #2163  |  Link
tekmobile
Webmaster
Don't try it.
Confirmed here too does not work on my standalone only plays DTS core and the clpi file is wrong although I fixed this (maybe) with clpi editor the mpls also states the audio as DTS tried to fix this with BD edit but the disc would then hang loading the movie best to keep using BD-RB as is this will allow for bugs etc to be fixed quicker.
tekmobile is offline   Reply With Quote
Old 21st March 2009, 14:34   #2164  |  Link
Sharc
BD-Rebuilder v0.20.03 / movie only / resize 720p hangs during muxing, after a warning about an Audio/PGS sizing issue has been acknowledged with <continue>:
- [10:30:15] Reencoding: VID_00000, Pass 2 of 2
- [13:57:49] Video Encode complete
- [13:57:49] Reencoding audio tracks
- [14:07:23] Multiplexing M2TS
- [14:12:21] Extracting audio/subs [VID_00007]
- [14:12:21] Collecting video information [00007]
- Audio/PGS sizing issue. Continued...
- Video: 1920x1080, 23.976fps
- [14:12:40] Reencoding: VID_00007, Pass 1 of 1
- [14:12:40] Reencoding: VID_00007 (2 of 2)
- [14:12:44] Video Encode complete
- [14:12:44] Reencoding audio tracks
- [14:12:44] Multiplexing M2TS
- [14:12:44] DoEncoding() 00009 8
Added:
Muxing of the files in the BD-RB Working Directory manually with tsMuxer 1.8.30(b) went smoothly though.
Old 21st March 2009, 15:36   #2165  |  Link
Furiousflea
Good call.
Old 21st March 2009, 16:54   #2166  |  Link
tekmobile
Webmaster
Added:
I had a problem using 1.8.30(b) where skipping chappters always caused the movie to start from the beginging after I went back to the version included with BD-RB everything was good again im going to try 1.8.34(b) to see if it fixes this issue.
Old 21st March 2009, 17:58   #2167  |  Link
datman
well I have one copy of vista 32 that I use on my play back system. W7 was the chance to use a 64bit OS for free. So far it works pretty good some of the screens are cool.
I guess I could buy a copy of vista 64, but others have said XP 32 will run these programs just as good. Before I buy another copy of windows I'm going to try XP on this computer
datman is offline   Reply With Quote
Old 21st March 2009, 23:31   #2168  |  Link
Elesias
I mentioned my troubles when playing backups with my BD35. By the way, these backups play fine with the new LG BD370.
Elesias is offline   Reply With Quote
Old 22nd March 2009, 00:39   #2169  |  Link
wiggle
Got same problem as Sharc, using version v.0.20.03
I get an error while RB Rebuilder is trying to "Integrating new files into BD structure."
An error popup window shows:
BD Rebuilder experienced an error 4 [00:24:10] DoEncoding() 00076 4
The logfile looks as follows:
[00:56:19] BD Rebuilder v0.20.03 (beta)
- Source: HOLLYWOOD_LAND
- Input BD size: 37,31 GB
- Approximate total content: [02:06:10.145]
- Target BD size: 23,93 GB
[00:56:22] PHASE ONE, Encoding
- [00:56:22] Extracting audio/subs [VID_00084]
- [01:10:28] Reencoding: VID_00084 (1 of 1)
[00:07:52]PHASE ONE complete
[00:07:52]PHASE TWO - Rebuild Started
- [00:07:52] Rebuilding BD file Structure
- [00:24:10] DoEncoding() 00076 4
This was also the first time that my encode was oversized (~380mb).. never had that problem with previous versions of BD Rebuilder.
[edit]
Also unable to close BD Rebuilder after this error.. program doesn't respond to the righttop cross nor the abort button. have to terminate it manually via windows taskmanager
wiggle is offline   Reply With Quote
Old 22nd March 2009, 04:38   #2170  |  Link
datman
Originally Posted by GaPony View Post
That's happened on two or three movies... Pride & Glory, Saw V, and another one, I think. I tried running them again and everything was back to normal. There were no errors in the log, so I don't know what happened. I place them under my normal category for flaws..... Gremlins.
Yep it was a Gremlin. I did it again and it works fine. Thanks for the "heads up" I might not have tried it again.
I have had a couple that had a "failure to encode audio" error and I did try them again and it failed the 2nd time too. I'm waiting for a new version and I'll try them again, might work. So far I have 82 sucessful encodes. I say I'm doing pretty good
Old 22nd March 2009, 04:55   #2171  |  Link
GaPony
That's the way I do things. I will always try a second time. The first failure is always treated as a Gremlin. If it fails again, I set it aside until the next beta comes out. Eventually, I'll get them all done.
GaPony is offline   Reply With Quote
Old 22nd March 2009, 05:07   #2172  |  Link
datman
I think it was this film Changeling that twice I tried processing off the fresh rip and both times I had failure to encode audio errors. So then I did the encoding off the tsmuxer-ed file and it worked, took 2 times but it worked
Old 22nd March 2009, 10:34   #2173  |  Link
robinthehood
Got "DoEncoding() 00009 8" again this time while doing Leon film only to BD25, is it possible for me to rebuild the movie without the troublesome file? BDinfo shows it as 00:00:01 seconds and 24,576 bytes its the final file in the playlist
[16:09:09] BD Rebuilder v0.20.03 (beta)
- Source: LEON
- Input BD size: 31.69 GB
- Approximate total content: [02:12:51.380]
- Target BD size: 23.68 GB
- MOVIE-ONLY mode enabled
[16:09:09] PHASE ONE, Encoding
- [16:09:09] Extracting audio/subs [VID_00005]
- [16:17:56] Reencoding: VID_00005 (1 of 8)
- [21:52:59] Extracting audio/subs [VID_00006]
- [21:52:59] Reencoding: VID_00006 (2 of 8)
- [22:02:11] Extracting audio/subs [VID_00002]
- [22:02:11] Reencoding: VID_00002 (3 of 8)
- [01:09:53] Extracting audio/subs [VID_00008]
- [01:09:53] Reencoding: VID_00008 (4 of 8)
- [03:55:49] Extracting audio/subs [VID_00058]
- [03:55:49] Reencoding: VID_00058 (5 of 8)
- [05:12:02] Extracting audio/subs [VID_00059]
- [05:12:02] Reencoding: VID_00059 (6 of 8)
- [06:05:40] Extracting audio/subs [VID_00062]
- [06:05:40] Reencoding: VID_00062 (7 of 8)
- [09:15:39] Extracting audio/subs [VID_00075]
- [09:15:39] Reencoding: VID_00075 (8 of 8)
- [09:15:45] DoEncoding() 00009 8
robinthehood is offline   Reply With Quote
Old 22nd March 2009, 16:05   #2174  |  Link
Furiousflea
You can upgrade to Vista64 for about 7 mate, worth bearing in mind
Old 23rd March 2009, 15:57   #2175  |  Link
kyoshiro378
vero
[21:36:41] BD Rebuilder v0.20.02 (beta)
- Source: WANTED
- Input BD size: 40.07 GB
- Approximate total content: [04:01:11.098]
- Target BD size: 22.90 GB
- Resuming from previously started job.
[21:36:42] PHASE ONE, Encoding
- [21:36:43] Reencoding: VID_00223 (6 of 32)
- Encode failed. Retrying.
- Reached retry limit. Aborting.
[21:37:14] - Failed video encode, aborted
x264 exits with the runtime error. why this happen? anybody tell me
kyoshiro378 is offline   Reply With Quote
Old 23rd March 2009, 22:37   #2176  |  Link
datman
I have a oem copy and I don't think you can upgrade it
Old 24th March 2009, 00:23   #2177  |  Link
Furiousflea
You are indeed correct. Tight swines at ms lol.
Old 24th March 2009, 10:34   #2178  |  Link
stef73
got my copy of vista 64 for 40 so its not that much and that was a year ago
stef73 is offline   Reply With Quote
Old 24th March 2009, 20:03   #2179  |  Link
turbojet
Is this full backups or movie only that have no problem on LG BD370?
Old 24th March 2009, 23:13   #2180  |  Link
tyau
From my experience, LG players, be it Blu-ray, DVD, or HD-DVD, play everything you throw at them. My LG player is not only capable of playing backup DVD's, it could also play damaged, scrached, or improperly recorded DVD's. Discs that failed to copy half-way due to recorder failure also played fine up to a certain point on the LG player! The same goes for the my Philips and Samsung DVD player.
Although I have no experience with the LG BD370 players, I would not be surprised if the LG BD370 could play different variations of BD backup, be it movie-only or full backup.
tyau is offline   Reply With Quote
