4th May 2013, 10:49 | #2981 | Link |
Huba Huba
If I queue a folder via one click encoder, the queue stops on the first error encountered. Is there an option to make MeGUI just skip to the next file in this case and not stop processing completely?
If I queue files manually one by one is skips errors and imho this is the sound behavior :-o ... sorry if I'm overlooking the obvious here.
"The innocent have nothing to fear" :stupid: |
4th May 2013, 18:41 | #2984 | Link |
I mean the space in which i can set the chapter file. There is one of it in OneClick Encoder->Andvances Config ("Chapter file" field) but not in the preset
I would like to have the same field in the OneClick Preset. When i encode serials (serial tv, cartoon, anime) that have the same duration, I use the same chapter file for each episode. Sorry if my english is not clear but i'm italian Btw great software |
4th May 2013, 20:49 | #2985 | Link |
Huba Huba
The last one I encountered was when converting an wmv file (other similar wmv worked, but this seems to be broken), but megui also stopped the queue when failing to demux the audio from mp4 and various other reasons I don't quite remember anymore - basically for me whenever some tool exits with an errorlevel the whole queue is stopped instead of jumping to the next file to process.
[Information] [04.05.2013 13:59:11] Job commandline: "C\meGUI\tools\ffms\ffmsindex.exe" -t -1 -f "completely_legal_file.wmv" "C:\TEMP\qehrms1o.wvn\completely_legal_file.ffindex" [Information] [04.05.2013 13:59:11] Indexing started [Error] [04.05.2013 13:59:14] Process exits with error: 1 UPDATE: I think there's something wrong with ffmsindex.exe handling: If I run the above command in an own batch file it doesn't return an errorlevel and works just fine - only megui fails when trying to run it with the above not very verbose error description.
"The innocent have nothing to fear" :stupid: Last edited by Marsu42; 9th May 2013 at 09:57. |
6th May 2013, 19:40 | #2986 | Link |
Hi. I am using MeGUI 2341 and it works great its greatest tool of all time. So what I basically do is do some .mp4 encodes and then mux together with audio via MP4 Muxer. Now this one video has -200ms delay and when I set that delay in the muxer it gives me output of same movie, but shrinked in quality by double and merged together twice. So what I mean is that if I don't touch the delay option I get 1.44GB size movie of duration 1h 33mn and if I add -200 to Delay field I get same 1.44GB, but shrinked in quality and merged twice and total length is over 3 hours! This sounds ridicilous, but I tried that already ten times and I get same result. How's that even possible? I just want to sync my video with audio and mux it.
I am using Windows 8 x64, but x32 MeGUI and its tools. The audio is encoded as AAC in .mp4 format, the video file is also in .mp4 encoded using x264. |
13th May 2013, 13:33 | #2990 | Link |
You would usually click the "Queue" buttons in the related areas (e.g. "Video encoding" or "Audio" part of the "Input" tab, or finishing one of the Muxer dialogs) after filling the fields with all required input files and options. Then a job is added to the job queue. They are executed sequentially after you press the "Start" button in the "Queue" tab.
13th May 2013, 15:01 | #2994 | Link |
More details please. What kind of sources do you want to convert to which target formats? Do you already have prepared AviSynth scripts?
_ Do not try to create a "New worker" in the "Queue" tab; this is not what you want! |
13th May 2013, 15:11 | #2995 | Link |
I want to convert Remux to mkv format and add script then config like crop or something else,but when i finish my config "Queue" tab is empty.Which button should i click ? when i click Auto encode start encode or click Queue then start encode.
13th May 2013, 15:28 | #2996 | Link | |
Sorry, my english is very bad. But yours is even worse |
19th May 2013, 17:20 | #2998 | Link | |||||||
@ Zathor:
I now asked IanB what he thinks about it: Quote:
And this is his answer: Quote:
So please update to AviSynth 2.6.0 in MeGUI . |
19th May 2013, 17:51 | #2999 | Link |
Maybe I wait untill the RC1. I do not have time to make any tests at the moment. But thanks for the information.
EDIT: Btw even if MeGUI provides 2.6 it will only be used when no AviSynth is installed at all on the system. Therefore it will be used by the more inexperienced users and the AviSynth build must work. |
22nd May 2013, 04:01 | #3000 | Link |
Zathor
Hello I am using MeGUI_2341_x86, during use, encounter some problems regarding the x264 presets, would like to ask you. 1, this MeGUI_2341_x86 default after installation only "* scratchpad *", but my level is relatively low, the setting of these parameters is more difficult, so I want to use profiles. So, I "http://forum.doom9.org/showthread.php?t=139765" downloaded "MeGUI-x264_generic_profiles_v85.zip", my question is: the V85 and 2341 (MeGUI and x264) matches ? If not, could you please help us to sort out a matching profiles version? 2, on the x264 "Encoding Mode". If you do not use the "profiles_v85", where the default using "Const.Quality"; if you use the "profiles_v85", the corresponding parameter is "- bitrate". I would like to ask: What are two ways in actual use what is the difference? Specific use which way, can you please tell me about your experience? 3, this "2pass" and "3pass" in actual use What is the difference? I watched "profiles_v85", seems to be no use "3pass". Very much like to get your help. Thank you! |
