13th April 2012, 15:40 | #10361 | Link | |
If you have LAV filters installed, unreg LAV-video and see if it still crashes. If it still crashes, then unreg Lav-audio and check again. Let us know the results from this small test. note: don't manually unreg the splitter, it will never work if you do so. Use always un-install to remove the splitter ! |
13th April 2012, 15:46 | #10362 | Link | |
But with this sample the VPU is used with my VP4: http://videos.rockstargames.com/stre...4-1280.wmv.zip Does this sample work with VP2 and DXVA? If not, does it work with driver 275.33? Then I could try to report it. |
13th April 2012, 16:08 | #10363 | Link | |
It complains there is no media inside. And no, there is no chance that LAV will handle RARs. Mostly because i think its stupid to keep your files packed in rar archives.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 13th April 2012 at 16:15. |
13th April 2012, 16:46 | #10364 | Link |
I wonder if you can help me to troubleshoot an issue I am having?
I want to use LAV with CUVID hardware acceleration, and i bought a GT430 passive for the purpose. I run Mediaportal in single seat and also a second client. I use LAV for movies, and PDVD12 for live tv. If I play a movie in the living room (single seat) using LAV codec, then the live tv stream to the client, and any tv recordings on the single seat break up and pixellate. I did some troubleshooting and determined that the problem only exists if I have CUVID hardware acceleration switched on. Not sure why this could be? Any idea how to troubleshoot this? I'm using Windows 7 and the tesla (276.52 I think) drivers, although have also tried the latest normal Nvidia drivers and have the same problem. It's baffling me! |
13th April 2012, 16:47 | #10365 | Link |
Crossposting is not allowed per forum rule 8:
http://forum.doom9.org/forum-rules.htm Your second post was deleted. |
13th April 2012, 19:00 | #10367 | Link | |
I unreg LAV-video and LAV-audio trough BSPlayer and now works fine. In fact,Lav-video decoder cant unreg in BSPlayer,i put that on black list. |
13th April 2012, 19:32 | #10368 | Link | |
I have taken note of the sections of the clip that show distortions / blockyness with vc-1 vp2, which are fine with non cuda decoders (and fine with older drivers < 285 release). Heres the details of drivers where I found it worked, and after which it didn't work. Nvidia Driver - Cuda dll version - Status 285.62 - 8.17.12.8562 - broken 285.38 - 8.17.12.8538 - broken 285.27 - 8.17.12.8527 - broken 280.36 - 8.17.12.8036 - working 280.26 - 8.17.12.8026 - working Last edited by mark0077; 13th April 2012 at 19:38. |
14th April 2012, 01:09 | #10369 | Link | |
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
14th April 2012, 01:18 | #10370 | Link |
Yeah I tried that a while back when testing. No luck unfortunately. My machine didn't behave very well when mixin old dlls. I guess some people might not even notice the issue. It can be subtle.
14th April 2012, 05:12 | #10371 | Link | |
MS VC-1 decoder seems to (only) support partial acceleration? |
14th April 2012, 06:12 | #10372 | Link |
http://pan.baidu.com/netdisk/singlepublic?fid=78324
http://i.imgur.com/ZvnJf.png no deinterlacing with CUVID http://i.imgur.com/rh3I6.png ok when madVR took over the job PS: MS renderers also failed.. MPC-HC's MPEG-2 Video Decoder(SW) seems ok. Last edited by wanezhiling; 15th April 2012 at 09:09. |
14th April 2012, 10:10 | #10373 | Link | |
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
14th April 2012, 11:24 | #10374 | Link |
Does anyone know if LAV DXVA2 Native works with EVR on an AMD E-350 (Brazos)? If so, what can it handle? 1080i with decent deinterlacing?
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
14th April 2012, 11:43 | #10375 | Link | |
14th April 2012, 14:05 | #10376 | Link | |
http://www.mediafire.com/file/v9nahl...Knight-001.mkv |
14th April 2012, 15:16 | #10377 | Link |
http://pan.baidu.com/netdisk/singlepublic?fid=79994
Mediainfo indicates its AC3 but actually DTS. haali and MPC's splitter can correctly recognize it as DTS, would LAV do some workaround? Last edited by wanezhiling; 15th April 2012 at 09:13. |
14th April 2012, 16:02 | #10378 | Link | |
14th April 2012, 16:20 | #10379 | Link | |
Try this:http://www.mediafire.com/?c7pco795rtrot5m PS:Mediafire(or most other foreign hosts) is not available until I crossed the "government firewall", so the uploading speed is very slow to me.. That's the reason why I always using a Chinese local host as my premier choice. Sad to hear you say that new host is too slow for you. Last edited by wanezhiling; 14th April 2012 at 16:38. |
14th April 2012, 16:24 | #10380 | Link | ||
I used this feedback form. Quote:
