16th March 2012, 16:36 | #9921 | Link |
nvidia user
Hmm...
I'm trying to say that I have no problems with the «LAV Video Configuration» (and «LAV Splitter Configuration») windows. The my problem only with the «LAV Audio Configuration» window. Last edited by zmaster; 16th March 2012 at 16:42. |
16th March 2012, 17:39 | #9922 | Link | |
P.S. At work with Russian Windows 7 all is OK. Last edited by MasterNobody; 16th March 2012 at 17:41. |
16th March 2012, 19:31 | #9923 | Link |
Here is a new build that requires some testing to ensure there are no regressions:
http://files.1f0.de/lavf/LAVFilters-...5-g7a6833a.zip The big change is that i moved all the actual decoding onto a worker thread. This has the advantage that the decoder can continue working while another thread is performing the final changes to the image (like RGB conversion and whatnot). For now, only the WMV DMO decoder and DXVA2-CB take full advantage of this (and may have gotten a bit more faster again) The reason only the these decoder uses this properly is because it was much simpler for them because i can freely manage the memory buffers. The important part is that the behavior should not have changed from 0.49 release to this version. If something is broken that worked in the release version, i need to fix it, so let me know.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 16th March 2012 at 19:48. |
16th March 2012, 20:58 | #9924 | Link |
There is a major difference
MPC-HC trunk (using SPP fast to pressure 1 core fully) Lav Video DXVA-CB LAVFilters-0.49-yadifmt2.zip = http://img21.imageshack.us/img21/341...bevrbasicn.png Lav Video DXVA-CB LAVFilters-0.49-15-g7a6833a.zip = http://img24.imageshack.us/img24/341...bevrbasicn.png also the peaking in the non cb decoder avcodec is still their, and the extreme stucks , heavy decoding drop outs and unsync not such issues in this setup http://img40.imageshack.us/img40/852...tester4075.png
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 16th March 2012 at 21:18. |
16th March 2012, 21:22 | #9926 | Link |
Seeking will always set the queues to zero, thats just how seeking works.
16th March 2012, 21:29 | #9927 | Link |
Nev is there a "Pan-scan" feature in FFmpeg that you didn't implemented yet in LAVVideo, but exist in FFD ?
[vc1 @ 24383a00] Pan-scan not implemented. Update your FFmpeg version to the new est one from Git. If the problem still occurs, it means that your file has a fea ture which has not been implemented. [vc1 @ 24383a00] get_buffer() failed (-1 0 00000000)
Intel UHD Graphics 750; Win 10 22H2 |
16th March 2012, 21:32 | #9928 | Link |
The DXVA-CB decoding overhead is @ 50% now before it was @ 25% something is wrong it doubled @ decoding
native DXVA2 @ Mpeg-2 Decoding is still awesome though still the 720p MTV stream crashes
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 16th March 2012 at 21:36. |
16th March 2012, 21:42 | #9930 | Link |
aufkrawall wouldn't surprise with the higher overhead + the load @ the seek it goes boom
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 16th March 2012 at 21:45. |
16th March 2012, 21:55 | #9931 | Link |
I meant it stays at 0 and doesn't play. I thought it might be related to the "Delay playback until render queue is full" option being enabled but it isn't. Trying to seek more or stopping doesn't start playback in MPC-HC.
16th March 2012, 21:56 | #9932 | Link | |
Personally, i have never seen a file that used Pan-Scan, so its more likely that the frame header is broken.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 16th March 2012 at 21:59. |
16th March 2012, 22:09 | #9933 | Link |
Here is a new build that fixes the extra cpu load, had one wait condition the wrong way around =p
http://files.1f0.de/lavf/LAVFilters-...7-gd8878bb.zip
16th March 2012, 22:23 | #9934 | Link |
Thats normal, the splitter creates one thread for every pin, and all other filters sit on that thread by default. If ffdshow uses a very expensive filter, it should create a worker thread for that, if it doesn't do that, it'll possibly bottle-neck the decoder.
16th March 2012, 22:30 | #9935 | Link |
yep just saw it thouhg it doesn't seem to affect Gabest Decoder @ all @ least there are no massive drop outs though the strangest is that it keeps sync to the audio which lav video is losing also the FPS isn't changing @ the ffdshow osd with lav video but stays @ 23.999 fps with Gabest Decoder it changes continuously (Render FPS) see screenshots
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 16th March 2012 at 22:33. |
16th March 2012, 22:36 | #9936 | Link |
The Gabest decoder implements IQualityControl, with which the renderer can tell the decoder to drop frames to keep sync.
I didn't bother to implement that, because if your system is too slow, you're screwed anyway.
16th March 2012, 22:38 | #9938 | Link |
There is a bug with madVR and DXVA2-CB that causes playback to break sometimes in the test build, but i don't know why. Suddenly madVR stops accepting frames. I put the question to madshi, see what he can figure out.
Edit: Nevermind, found the bug, was my fault afterall.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 16th March 2012 at 23:06. |
16th March 2012, 23:09 | #9939 | Link |
I am having seeking issues with LAVFilters-0.49-17-gd8878bb. Win7 x64 but using all x86 versions. Latest MPC-HC 1.6.1.4150 (happened with slightly older version also). Tested with 3 MKVs all V_MPEG4/ISO/AVC at 23.976 with bitrates from 8-32Mb/sec and DTS/AC3 audio. Using MPC-HC with LAV Splitter/Video/Audio and madVR in Windowed mode with ATI 5670.
Seeking mostly works fine however playback will hang intermittently. Seems to happen more often on 60 sec jumps and not so often on Chapter jumps. It may work fine 10 times in a row but it does hang/freeze. I have no problems with the proper 0.49 version. Playback just stops/freezes, MPC-HC still responsive though, I can click on menu commands. CPU is idle, disk is fine. |
16th March 2012, 23:11 | #9940 | Link |
Last for today, this fixes seeking with madVR again:
http://files.1f0.de/lavf/LAVFilters-...9-gd92f96a.zip Should now hopefully be back to 0.49 behavior, if not better sometimes.
