26th May 2009, 13:39 | #2981 | Link | |
So I delete the MultiAVCHD folder and I reinstall it. Then it works again. Thank you very much In a future release will it possible to choose language for audio and subtitles? |
26th May 2009, 15:01 | #2982 | Link |
@deank
Here is script which improves reflections in your SLIDE Menu. http://www.mediafire.com/file/wwjm2u...enu-example.7z
26th May 2009, 17:54 | #2989 | Link |
Next time learn how to use google amigo. It took me 10 seconds to find answer
80029946 - Attempting to play burnt Dual layer NTSC disc on a Pal ps3 (workaround is to transfer files to ps3 via TVersity) (added 24th Sept 2007) http://boardsus.playstation.com/play...158519#M154384
26th May 2009, 21:21 | #2990 | Link | |
27th May 2009, 05:33 | #2991 | Link |
Subtitles dont work
Hello.Well i put 10 media files in multiAVCHD with their subtitles (spanish). Everything went fine, i got my new folder BDMV and CERTIFICATE. My Samsung BDP-1500 plays it ok but the subtitles doesnt appear. What am i doing wrong?. I used carrousel menu style. The movie plays fine and menu plays fine but the subtitles dont. Thanxs in advance and sorry for my english .
27th May 2009, 06:21 | #2993 | Link |
Current version v2.7 b613,
Settings > Delete all files in temp folder UNchecked BUT all files in temp folder(except mediainfo.txt) get deleted. Sometimes I would need to keep for instance the result of the first demux step: D:\_TEMP\avidump.264 D:\_TEMP\avidump.ac3 In general, intermediate result could be quite handy, sometimes. Please make that work again in the next release! |
27th May 2009, 08:44 | #2995 | Link |
Swallowed in the Sea
Deank,
May I suggest you to use Aften instead of FFmpeg to transcode to AC3 format ? Aften is multithreaded... for Stereo Input: Code:
FFmpeg -i input.mkv -vn -acodec pcm_s16le -ac 2 -f wav - | aften.exe -readeof 1 -b 384 - output.ac3 Code:
FFmpeg -i input.mkv -vn -acodec pcm_s16le -ac 6 -f wav - | aften.exe -readeof 1 -b 448 - output.ac3 In addition, is it normal that when I select a specific frame as thumbnail (not frame 0), the preview doesn't use it ? |
27th May 2009, 09:10 | #2998 | Link | |
After change order of folders I get same error on second (ex-first) folder. |
27th May 2009, 10:31 | #2999 | Link |
Programmer (or just 教务长)
Check if all files in the second folder follow the long names format... all should be .clpi/.m2ts/.mpls... you can't have one in 8.3 format and other in long format.
To all: Please be a bit more patient. I'll be ready with the new version soon. A lot of bugs were found in 613 and fixed. Dean |
