28th October 2017, 19:39 | #46902 | Link |
Is there some sort of trick to get madTestPatternSource working? I've installed it, and 'The DirectShow filter "madTestPatternSource.ax" was registered successfully.' pops up, but it doesn't show up under External Filters in MPC-HC. If I try to open any of the *.ytp files I just get "Cannot render the file".
I'm sure there is something obvious I'm missing. |
28th October 2017, 19:44 | #46903 | Link | ||
Also, I just wanted to report that it turns out that even with the updated PSU, I started getting the frame drop issue I mentioned before once again, but I was finally able to determine that it was caused by my anti-virus, BitDefender 2018. I have no idea why it does this, or why it causes frame drops only after playing something perfectly smooth for several minutes, but I was able to fix it by whitelisting the directories for PotPlayer, madVR, and LAV filters. Hope this helps someone. |
28th October 2017, 22:10 | #46904 | Link | ||
it's not easy to make UHD picture for comparison they are usually to huge for image hoster. here some screens: native: https://abload.de/img/title06.mkv_snapshot_1eue5.png NGU sharp high: https://abload.de/img/ngusharp71uf0.png NGU AA: https://abload.de/img/nguaajau63.png lanczos3: https://abload.de/img/lanczosnuuja.png NGU sharp does some wonders on the background tiny blue red flags and half side of the white helmet(and way more) but it highlights compression artefacts and it is quite odd that some image parts are not sharp at all and some look pretty ok. NGU sharp is known to work best with good source this source has nothing todo with good. every other used scaler is significantly less sharp but has a more balanced image. is NGU sharp sharper than the source image maybe? if not every other scaler makes it less sharp than the source. scaling an image like this is at best a trade. i used NGU high, let madVR decide except for downscaling i used SSIM 1D100 AR. madVR 0.92.7 RCA 2 is effect on this image but it is not used because this is about scaling. |
28th October 2017, 22:33 | #46905 | Link | |
Audio speaking. Since XP audio only got worst on new windows os. And windows 8.1 probably has the best desktop composition of them all. I think windows 10 was made for centennials. Z people love to see their desktops full of flying windows or notes or photos. Videos coming from right to the left. I cant stand it. I like to control EVERYTHING on my machine. With windows 10 thats IMPOSSIBLE. Anyways, madshi keep up the good work. We all love you. Its something to praise what you do for free. |
29th October 2017, 00:03 | #46906 | Link | |
_
I'm quite confident your reason is justified, but as a basic user, I would need a really good reason not to use last Windows version. And it's certainly not xabregas's nonsenses which will make me change my mind. For now, I have 0 problem with MPC+madVR or mpv. |
29th October 2017, 07:50 | #46908 | Link |
Madshi,
Is RCA applied before IVTC, right? I wonder if you can let RCA be applied AFTER IVTC, since IVTC is really useful when playing back videos with 59.976 or 60 fps, in which case the original video can be decimated, to save limited GPU power to more crucial tasks. Best Regards, Anima123 |
29th October 2017, 11:35 | #46911 | Link |
I bought a very nice expanded color range 4K monitor, which arrived Saturday. It's going back Monday because my GTX 1060 6GB couldn't handle Blu-ray doubling without major frame drops.
I'll try again next time I upgrade the video card. Madshi was right, the picture was gorgeous. EDIT: Just noticed the GTX 1080 11GB has come down in price. I assume that would do the job, but does anyone here know for sure? Last edited by jkauff; 29th October 2017 at 11:55. |
29th October 2017, 11:58 | #46912 | Link |
my 1060 can do ngu sharp very high with normal chroma when upscaling 1080p23 to UHD.
so are you sure you didn't forget to change the nvidia power setting to adaptive? and if you want tell people want you want to do no one can tell you if a 1080 can do X. |
29th October 2017, 13:01 | #46913 | Link | |
All I want to do is simple doubling with NGU. And yes, I'm on Adaptive power setting. |
29th October 2017, 17:05 | #46918 | Link | |
(I'll go have a look on AVS, thanks for the link) |
29th October 2017, 18:18 | #46919 | Link | ||||
I've one problem with your post: It's a comparison of NGU AA vs NGU Sharp vs NGU Lanczos. But it's *not* a comparison of NGU vs unscaled. Some users might think it is, because you provided the original untouched source image, but it's not. Why? Because in order to compare 2 images, both images need to have the same *viewing angle*. If you compare 2 images where one image covers a much smaller angle of your view than the other, then the one with the smaller viewing angle will almost always look sharper and less artifacty. But it's not a fair comparison, because we're not discussing watching 1080p content on a 25" 1080p display, compared to watching 1080p content on a 50" 4K display! What we're discussing is watching 1080p content on a 50" 1080p display, compared to watching 1080 content on a 50" 4K display. Do you agree? The 1080p and 4K displays will have the same viewing angle. So in order to do a fair comparison we also need to compare "screenshots" with the same viewing angle. So how can we do a fair comparison? It's actually simple: We use a digicam/DSLR to shoot an image of the unscaled source, and we shoot it in such a way that the unscaled source covers the whole digicam frame. Then we shoot an image of the upscaled image, again in such a way that the upscaled image covers the whole frame. This way we get a relatively fair comparison how the upscaled vs unscaled images look like, when seen at the same viewing angle. Unfortunately there's a catch here: Your unscaled DVD image has a distorted aspect ratio, so I had no choice but to correct the aspect ratio by upscaling. I've used the same algos for AR correction, and for upscaling. Here are the results, straight out of the digicam, no processing other than simple cropping: digiCamNativeRes.png - | - digiCamUpscaled.png Please make sure your browser doesn't zoom these! Due to technical limitations (physical resolution of my monitor) it's a relatively small upscaling factor, but I'm pretty sure the results would have been identical (or even more in favor of the upscaled version) with a bigger upscaling factor. Please feel free to repeat this test yourself! Quote:
FWIW, there is more to this than just the question whether upscaling is useful or not. E.g. if the 1080p display has better native contrast, overall you might still be better off with the 1080p display than with the 4K display. So 4K isn't always better than 1080p. Last edited by madshi; 29th October 2017 at 18:21. |
29th October 2017, 18:43 | #46920 | Link | ||
https://abload.de/img/stardewm6u3m.png Quote:
the image i post you looks odd with NGU sharp because some parts get sharp after scaling and other don't and this results in a odd look just look at the ship the "mast" they are super sharp compared to the rest of the image which is odd because it is clearly not in focus. |
