Old 24th May 2006, 13:21   #201  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
check the CPU load before encoding and during encoding.
the first should be close to 0 the second should be 100%.
Old 24th May 2006, 13:40   #202  |  Link
rhys87
yeah its at 98% when encoding, i have restarted comp as well, really starting to confusing me.
rhys87 is offline   Reply With Quote
Old 24th May 2006, 18:54   #203  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Is this 1080i? That requires way more power than dvd-res.
Old 26th May 2006, 06:47   #204  |  Link
rhys87
here is the log
--pass 1 --bitrate 1000 --stats "C:\Program Files\WebScheduler\capture\rhys2.stats" --bframes 3 --b-pyramid --direct auto --filter -2,-1 --subme 1 --analyse none --me dia --progress --no-psnr --output NUL "C:\Program Files\WebScheduler\capture\rhys2.avs"
successfully started encoding
the first pass only goes at about 8-9fps when with StaxRip goes at about 25-30fps, does deinterlacing decrease the speed that much?
Old 26th May 2006, 07:20   #205  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
LanczosResize(512,288)
Wait, why not just toss a field away? EEDI2+Tdeint is a performance hog, you could just use SeparateFields().SelectEven().LanczosResize(512,288) and get practically the exact same result, since you're halving the vertical resolution anyway.
Old 26th May 2006, 08:17   #206  |  Link
rhys87
thanks alot, foxyshadis problem fixed.
Old 26th May 2006, 16:48   #207  |  Link
Xin-Hong
I discover MeGUI with the x264 VideoProfiles, very usefull for noobs like me so I wonder if there is VideoProfiles for XviD
Xin-Hong is offline   Reply With Quote
Old 26th May 2006, 18:19   #208  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Teegedeck is working on them, iirc.
Old 27th May 2006, 03:42   #209  |  Link
markrb
Old fart
markrb's Avatar
Should I still be getting the warning popup about the bitrate calc not being updated with the latest version of Megui?
I have been using autoupdate since 2148 so maybe I need something that autoupdate doesn't update if this has been fixed?
I remember seeing something about the warning was going to be removed in an earlier thread.
I am running 2155, currently.
Mark
Oh no Mr. Bill!
markrb is offline   Reply With Quote
Old 27th May 2006, 04:05   #210  |  Link
berrinam
berrinam's Avatar
I thought I had fixed it, but it still seems to be quite buggy, so the warning message does apply.
berrinam is offline   Reply With Quote
Old 27th May 2006, 07:56   #211  |  Link
Carpo
Carpo's Avatar
no so much buggy - as completly broke
The Internet: where men are men, women are men, and children are FBI Agents
Carpo is offline   Reply With Quote
Old 27th May 2006, 11:38   #212  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
No bitrate calculator working fine just need little tweaking
shon3i is offline   Reply With Quote
Old 27th May 2006, 13:22   #213  |  Link
Carpo
Carpo's Avatar
2155 bitrate calc dont work here - 5587 for a single cd backup - bit much me thinks
on a diff topic if i wanted to do .ts to hd-dvd (well that qual anyway prob be a 2 cd poss 1/2 dvd) is it a simple step of selecting size (original is 1920x1080i) my pc can do 1280x720 nicely, and selcting the hd-dvd profile from within megui or is there other things i need to concider, im still new to this area of backup so please excuse and old n00b
Old 27th May 2006, 14:50   #214  |  Link
Morte66
Flying Skull
Morte66's Avatar
Here are my experiences, such as they are:
1. If your TS is a movie, proceed much as normal. One catch: DGIndex often refuses to read TS files, it complains about missing "PIDs" whatever those are. So I process the .ts to .mpg with a program called "HDTV to MPEG" first, and run DGIndex on the results. Then AviSynth can chew the D2V file and serve it to MeGUI.
2. If it's a TV show with multiple sections including interlaced video, telecined film, archive footage rezzed up to 1080 etc, MeGUI seems to have a hard time choosing a deinterlacer that gives decent results. It's usually better to write your own Avisynth script using DirectShowSource() to get the video stream into the encoder and let DirectShow deinterlace it. [The docs say AviSynth tries to disable DirectShow deinterlacing, but fortunately I've never seen it succeed.]
3. On my usual settings, I get about 7fps for 720x576 PAL DVD backups done in single pass constant quality mode and I don't worry about how many files fit to a DVD. For 1080p/24 I want one movie per DVD so I have to do 2 pass, and I get about 1.2 to 1.4fps on each pass. It takes me 3 or 4 days to encode a movie (A64 X2 3800+). If I didn't like the ColorMatrix() filter in Avisynth so much (my backups look better than the originals), I'd just burn the TS files to two or three DVDs. Some time I'll check out how Xvid does with one HD movie on a DVD9.
4. Many a transport stream has a negative audio delay and a few hundred bytes of junk on the front of the sound. MeGUI may refuse to open these for encode using its standard NicAc3Source filters. MkvMerge doesn't particularly like muxing them straight back onto the encoded video without audio compression, either. DirectShowSource will get the sound into the encoder, and then the encode will synch/mux OK.
Morte66 is offline   Reply With Quote
Old 27th May 2006, 15:21   #215  |  Link
MajinNinja
Hi All,
I'm using MeGui v0.2.3.2116, DGMPGDec v1.4.6, TIVTC v1 RC4 and I'm having the following problem. Whenever I attempt to perform the deinterlace analysis an error window pops up stating that TIVTC.dll cannot be found and that 'tfm' is not a recognised command. I have TIVTC.dll in my avisynth dir and using it in scripts without issue. Any ideas what may be happening?
Cheers
MajinNinja is offline   Reply With Quote
Old 27th May 2006, 15:24   #216  |  Link
Carpo
Carpo's Avatar
sounds like it might be a right pain in the arse, although latest dgindex (1.4.7b12) had no issues with it
guess its a case of trial and error to see what resssults will look like
thanks for the advice
edit: found NullPacketStripper_v013beta it seems to join the ts files together ok with no apparent sync issues
Old 29th May 2006, 01:11   #217  |  Link
wacco
Excuse me, but how do i create profiles for the one click encoder? i need to encode dvd rip>avi. Megui says i need to select audio/video profiles, but there dont seem to be any of them?
wacco is offline   Reply With Quote
Old 29th May 2006, 06:52   #218  |  Link
berrinam
berrinam's Avatar
Get a new version of MeGUI from http://x264.nl and it should be clear.
Old 29th May 2006, 16:13   #219  |  Link
sillKotscha
what's this for?
sillKotscha's Avatar
just a question...
for minimal denoising of a video_clip shouldn't Undot() be replaced by RemoveGrain()?
advantage (IMHO):
- RemoveGrain(mode=1) is identical with trbarry's Undot (even the speed of the SSE version is nearly identical to that of Undot, but the SSE2 and especially the SSE3 versions are significantly faster)... = from the readme
- the denoising algo is considered to be more complex
what do you think...
latest mix sets: http://soundcloud.com/sill
sillKotscha is offline   Reply With Quote
Old 29th May 2006, 16:50   #220  |  Link
sillKotscha
what's this for?
when using the avisynth script creator I have noticed a difference between d2v source and directshow source...
my guess is that it could be an avisynth failure because detection via d2v source is correct... see attached pictures.
megui
