5th June 2004, 13:42 | #2202 | Link | |
I'm afraid we've to stop
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ |
5th June 2004, 13:47 | #2203 | Link | |
5th June 2004, 15:25 | #2204 | Link |
@Taurus
Yes, in fact I did 2 runs, one at 1/3 CD and one specifying 233 megs. Both came out the same size, 142 megs. I used default settings, Auto width, Xvid, Auto audio, no subs. Please see the log here Thanks for your help. Last edited by PanthraxBW; 5th June 2004 at 15:28. |
5th June 2004, 21:10 | #2205 | Link | |
6th June 2004, 09:05 | #2206 | Link | |
You might want to start saying 'Make sure your Web Browser can send the REFERER field.' or something similar. Otherwise the download managers/firewalls thing leads you on a wild goosechase. I had problems downloading until I finally figured it out that TabBrowserExtensions installed with Mozilla Firefox was turning the Send Referer field off. I installed the PrefButtons plugin and put a 'Send Referer' checkbox on my browser whenever I need to download files on sites that check for that. |
6th June 2004, 09:48 | #2207 | Link |
@lenOx
I admire your patience on this wrong xvid installs thing. Should have come to my mind after so many inqires on bad file sizes. Anyway, your experience is awesome. Thanks! @PanthraxBW The powerunite on my video pc has just crashed yesterday with smoke and lightning. The only difference in your settings I can recall from my memory is, I have the Mod32 fix mark ticked. And you don't have to put VobSub in 'Overrides' on MPC. If there are any subtitles in a movie, they are shown. On burned in subtitles you will not see the filter dialog, only on external subtitles there will be a green arrow icon in your systray, indicating that Vobsub is working. So for the next days, I can't help until the Powerunite is repaired (living up in the country). Try and experiment on your own. Cheers Taurus |
6th June 2004, 12:47 | #2209 | Link | |
Re: Jawor's CVS Build
6th June 2004, 12:55 | #2210 | Link | |
6th June 2004, 16:44 | #2211 | Link | |
That was it. However, I did take a quick look through the FAQ, and didn't realize that not uninstalling Xvid was problematic. You might want to change Q6.3 or add a generic line that says "I'm getting wierd file sizes". I'm sure I'm not the only one who has had this problem, looked at the FAQ, and still didn't know how to fix the problem. Otherwise, thanks for pointing that out. |
6th June 2004, 18:00 | #2212 | Link | |
20=Cuts a little bit off 18=Cuts a little bit off 17=OK 16=OK 15=OK 14=Show both top + buttom 10=Show both top + buttom So, I guess 16 is good for me - but probably not for all! "samples=5" is most likely too low a value for clips with subs. Perhaps no crop (can top crop be done alone?) is the best solution? Last edited by Nikse555; 6th June 2004 at 18:03. |
6th June 2004, 18:45 | #2213 | Link |
@ Lenox:
Have you ever thoght of doing a second first pass when the expected quality of first pass size is far away from the predicted comptest value? I'm asking, because I encoded some short music videos and the compressibility test was very inaccurately! Thanks anyway |
6th June 2004, 20:40 | #2214 | Link | |
6th June 2004, 20:46 | #2215 | Link | |
7th June 2004, 00:33 | #2216 | Link | |
noise is all around us...
((( atom ))) |
7th June 2004, 10:43 | #2217 | Link |
Custom size 1.4 Gb
The following "feature" has bugged me for some time:
When running AutoGK with 1.4GB custom size I get what I ask for but also a "two-cd-split" automatically. Is this intentional? If you want the split files you can choose the "predefined 2 CD option" instead. Thanks for a great program! |
7th June 2004, 10:52 | #2218 | Link | |
Re: Custom size 1.4 Gb
7th June 2004, 10:55 | #2219 | Link | |
7th June 2004, 11:24 | #2220 | Link |
version 1.35 beta is up
I've re-written resolution choosing algorithm completely, so please give it a good testing. Also TS support if finally officially there.
