29th September 2007, 16:19 | #2043 | Link |
Angel of Night
Can you hook onblur() from the filter menu or one of the other teardown messages, to pop up a 'save me?' box? I haven't worked with the side menu at all, I have no idea what's possible.
29th September 2007, 16:46 | #2044 | Link | |
ffdshow/AviSynth wrangler
And TBH, if you're editing a bigger script you'll probably be happier with doing it in an external text editor anyway. Or just don't forget to hit "Apply" after changing or pasting in the script. np: Burnt Friedman - Machine In The Ghost (ft. Barbara Panther) (First Night Forever)
now playing: [artist] - [track] ([album]) |
29th September 2007, 19:53 | #2045 | Link | |
Example: ColorMatrix(mode="Rec.709->Rec.601").SeparateFields().fft3dfilter().LanczosResize(640,480).Weave() |
30th September 2007, 12:51 | #2051 | Link |
More than just the PC vs rec levels, less than the custom matrix.
Black cutoff, white cutoff, chroma cutoff as well as ITUR-BT.601/701 are configurable. Last edited by haruhiko_yamagata; 30th September 2007 at 12:58. |
30th September 2007, 15:23 | #2055 | Link | |
I've played a lot of multichannel flacs in mkv containers and had ffdshow transcode them to ac3 and everything, all without issues. (32bit build). I might digg one up and try it with 64bit and see what happens. edit: ok I can confirm decoding works for flac in 64bit, as long as they are in a container. Last edited by SBeaver; 30th September 2007 at 15:29. |
30th September 2007, 16:15 | #2056 | Link |
One interesting observation: With Vista, 8600GT, 163.69driver, latest ffdshow from clsid and EVR-Renderer: I can sharpen with the sharpening of the drivers and can sharpen in parallel ffdshow. To my eyes it looks extremely good, potentially even better than limitedsharpening (I watch at 1920*1080 on a 4.2m wide and 2.2 high screen with a sony ruby)...less artifacts than anything else I tried...
...interesting: as soon as I enable lanzos resizing, the sharpening through the nvidia-drivers is broken...if I let the card do the resizing, sharpening works in ffdshow and in the card. Before I started with limitedshaprening, I used to use lanzos resizing with some sharpening in ffdshow. I have tested this against the current resizing and sharpning of nvidia. In this case nvidia looks better than ffdshow...quite impressive. |
30th September 2007, 16:34 | #2057 | Link |
@haruhiko_yamagata:
The font size is not compatible with vsfilter, at least horizontal scale after rev1482. I've got a NON-Square pixel AVC encode, when subtitle with ffdshow(after rev1482), the renderer automatic adjust the font size for the subtitle. but with vsfilter, it won't. Great feature, though not compatible with vsfilter(opposite to the changelog), I like it. Last edited by Valeron; 30th September 2007 at 17:00. |
30th September 2007, 16:49 | #2058 | Link |
HuffVUV encoding seems to be broken in some current "tryout" builds. I used ffdshow with HuffYUV-YV12 and different settings to capture a desktop area with some screen recorder. Resolution: 1016x680 pixel, or similar dimensions.
The screen recorder used to crash after a while. Watching a shorter video I completed before a crash, I saw that the bottom of the video contains some completely garbled lines with "fantastic colors", they grew upwards over the time the video played. A thread in the german doom9/Gleitz board with a screenshot |
30th September 2007, 22:36 | #2059 | Link | |
Also I'd like to repeat my very big feature request. It's letterboxing for DVD. Or at least it would be nice, if I could move the subtitles. Is someone willing to have a look at it? We've been already discussing this before, unfortunately this is still not implemented. I think with some work on VobSub, this might be implemented. Also on the codecs tab under MPEG-2 it still says DVD Decoding (not working yet). Why? Are there any known problems? It works fine for me already for a long time (except for the letterboxing ;-) ). And I think MPEG-2/DVD support should be turned on by default. |
1st October 2007, 08:00 | #2060 | Link |
ffdshow user
PAFF:
http://lists.mplayerhq.hu/pipermail/...er/035591.html Multithreaded H.264 decoder for all x264 encodes: http://lists.mplayerhq.hu/pipermail/...er/035877.html |
