29th September 2003, 09:49 | #61 | Link |
Life's clearer in 4K UHD
Hey Joe! (sorry I could'nt resist)
I'm so glad you wrote this. I took pen to paper myself trying to come up with an 'easy to understand' version of how resolution was measured in the old days.... but my version ran to quite a few hundred words and was still not as simple to understand as your post! I think I really should have paid more attention in my English lessons at school. But it was a long time ago. And was also at a time when 'typing' was considered a 'girly' thing to do.... And look at me now! My, how times have changed! Cheers
29th September 2003, 12:51 | #62 | Link |
Very good explanation, Jeo Fenton.
Is there some research about how human perception sees vertical lines on progressive scan monitors? I think that it should be little better case (more %). Btw. that about bandwith, and sine form by higher freq. stays for VGA monitors and cards too. Therefore are so high freq. of RAMDAC's and high bandwiths of monitors.
Informational value of an advert is in inverted proportion to beauty of playing model(s)/actress(es) |
29th September 2003, 13:32 | #63 | Link | |
Hi ppera2,
Todays TV and PC monitors are totally different pieces of equipment. So much so infact, I would probably be right in thinking that there's not a single TV or PC monitor that does not process the video digitally at some stage! Personally I hate 100Hz (digital) processing on modern TV's. As to me, the presented image looks like a 'water colour painting'. It just does'nt look real! My parents have just been conned into buying a 100Hz 32" widescreen Panasonic 100Hz TV. And to me, the picture looks crap! Cheers
29th September 2003, 13:36 | #64 | Link | |
Turn this Features of, and the picture might be much more look natural. |
29th September 2003, 14:13 | #65 | Link |
Thanks Kika,
I did actually try 'all' the different Panasonic settings. And the picture still looked crap! At the time my father was watching a live golf broadcast. And it's the first time I've seen grass without individual blades. I even thought of visiting a garden centre to find out if this 'new' type of grass was available to buy. As it would be far easier to maintain! Seriously though, the only decent 100Hz processing TV's I've seen have been by Philips! Oh, and another bad thing about the Panasonic. Why does it always want to alter the aspect ratio of a 4:3 image to fit the 16:9 screen. You just can't turn this function 'off' either! Cheers
29th September 2003, 16:18 | #66 | Link |
Graphite mod
Tool to measure horizontal resolution
Hi guys,
I though you might me interested in this. Trying different frame sizes on my TV I found that using 480x480 (SVCD) only revealed enough detail pertaining to CVD (352x480). Only if using non standard frame sizes like 528x480 or 544x480 I could see the detail a typical SVCD frame size was encoding. This has to do with something similiar to what @Joe Fenton explained about vertical resolution on a previous post, but horizontally. I built a small tool to measure the horizontal resolution which may be of use to you. Please check it out at: http://forum.doom9.org/showthread.ph...891#post378891
MPEG4 quality with MPEG2? - Try the Poor Man's DVD. FACAR - As seen on TV! - The Complete Idiot's Guide to a good DVD Conversion. Time is money. Try D2Sroba for DVD2SVCD (FAQ) and save both. All electricity bills supported! Do you know how much overscan and which resolution your TV has? Find out if NTSC. Moderator: 1: one who arbitrates 2: one who presides over an assembly, meeting, or discussion 3: a substance (as graphite) used for slowing down neutrons in a nuclear reactor (Webster) |
29th September 2003, 16:35 | #67 | Link | |
Re: Tool to measure horizontal resolution
Then report back which one looks best! For some reason you can only do this with PAL pixel frame sizes. 854x480 NTSC pixel frame sizes (or it's near 16 pixel equivalent) just don't work! Cheers
29th September 2003, 16:57 | #68 | Link | |
Graphite mod
Re: Re: Tool to measure horizontal resolution
29th September 2003, 17:04 | #69 | Link | |
I forgot to mention that this 'trick' it also works with low bitrate Mpeg1 encodes too (never tried with Mpeg2)! Cheers
29th September 2003, 17:55 | #70 | Link | |
Video can be processed digitally, but it still wont change that final stage amplifier, which goes to pic tube is analogue. So, all about bandwith stays. Just to say, that I work as servicer of TV's and monitors, and I know how them are built.
29th September 2003, 18:14 | #71 | Link | |
Cheers
29th September 2003, 21:07 | #72 | Link | |
I worked one summer as a TV repairman back when TVs were moving from transistors to ICs. Quasars and RCA were our bane, while Sylvania and Philco were a joy to work on.
Unless you have a pulse-width-modulated LCD or plasma display panel, all displays eventually have to convert the signal back to analog before reaching the CRT. The problem with properly displaying a squarewave is exactly why computer monitors have such a high bandwidth. Consider a monitor trying to display 640 pixels horizontally at 60Hz vertical refresh rate. 640 pixels displays 320 lines, but we want them to be crisp pixels, not barely discernable lines, so we need to allow for a seventh harmonic. So 320 / 80 X 2 X 7 = 56 MHz. As to progressive vs. interlaced, there are more studies being performed now that prgressive scan monitors of decent size are available. I was able to find this: Quote:
29th September 2003, 21:15 | #73 | Link |
Hi Joe,
I think you must be as old as I am! I'll show you mine. If you show me yours! Cheers
29th September 2003, 21:15 | #74 | Link | |
29th September 2003, 21:31 | #75 | Link |
ppera2
I'm sorry if I have upset or confused you or even become confused myself! I'm not a big fan of digital technology because of it's 'big brother' abilities. My biggest fear is that when CRT screens disappear altogether in favour of flat plasma, LCD etc screens, there will be no need to have any analog element at all. When this happens. And it will! Even the screens themselves could be used as encryption tools. As it's very easy for a chip to be programmed and then instruct which pixel goes/appears where! Cheers
30th September 2003, 05:08 | #76 | Link | |
Analog displays still have quite a bit of life yet. As far as flat screens go, cold cathode emission displays can still take back the crown from LCD and plasma display, especially considering the short life span on those two technologies. Plasma displays in particular start to lose cells in as little as five years. They will get better, but analog display technologies will only get cheaper as time passes. Why should I buy a 17" LCD display for $330 when I can get a 17" CRT for $110? I just noticed, 15" LCDs now under $200. Boy, they've come a long way from when they were first released. |
30th September 2003, 11:35 | #77 | Link | |
I have first hand experience with regard to plasma cell degradation as we have 2no 42" screens, at the moment. I have to admit we did not feel the need to spend large amounts of money on them because they are used at exhibitions, seminars or presentations. And as such are moved around quite a bit! It is good to see the prices of LCD and plasmas fall. But as usual the manufactureres have started tempting us with new, high definition 'XGA' models. And boy do these look good! Well out of my price range though.... at the moment! Cheers
30th September 2003, 15:51 | #78 | Link | |
I don't think that they will implement some heavy protections in displays soon - it must have first some standard to be worldwide etc...
30th September 2003, 16:45 | #80 | Link |
I wonder if Doom9 will ever reveal his (or maybe her) age?
Maybe Doom9 isn't a person at all. Could be a supercomputer. A digital super spy! How about a "League of Extraordinary (old) Farts" Cheers
