12th March 2014, 18:12 | #12622 | Link | |
Work fine for stereo audio but the are problems preserving the phase between channels with 5.1. Or you can use TimeFactory for $499.00
12th March 2014, 19:17 | #12623 | Link |
BeSweet (probably related to BeHappy) can do the pitch correction. Use the Tempo setting at -4.096 to slow the audio without altering the pitch for PAL to NTSC, and +4.2709376043 for NTSC to PAL.
Sony SoundForge can do this to, but I believe it works in cents... and don't ask me what those numbers are. |
12th March 2014, 20:08 | #12625 | Link | |
Also other sw for do this can be Audacity, Sox, mencoder (ffmpeg seems to have only atempo), ecc... -4.096 and +4.2709376043 come out from 100*((24/1.001)/25)-100 and 100*(25/(24/1.001))-100 @tebasuna51 so no way neither to have an implementation in future? Last edited by Motenai Yoda; 12th March 2014 at 20:42. |
13th March 2014, 10:00 | #12626 | Link | |
Maybe this is true with english tracks but not always with other languaje/translation. BTW you can always 'pipe' eac3to output to sox.
22nd March 2014, 15:50 | #12627 | Link |
I'm lost with Arcsoft 1.1.0.0 to 1.1.0.8 versions when I read posts from eac3to or LAV filter topics, or from differents sites
None of 1.1.0.0 to 1.1.0.8 versions can decode properly all types of streams (5.1, 6.0, 6.1, 7.1...) ? I would like to simply convert DTS/DTS-HD to AC3 because one of my device doesn't support DTS decoding (but I don't know if it supports TrueHD AC3 core or if I must extract it)... |
22nd March 2014, 15:54 | #12628 | Link |
Pig on the wing
AFAIK, the safest bet is to use v1.1.0.0. There are at least two different builds around, I think the CRC comparisons (and instructions which one to use) is buried somewhere in this thread.
22nd March 2014, 15:58 | #12629 | Link | |
It's this:
22nd March 2014, 16:38 | #12630 | Link |
I've searched CRC on the thread without result, if you have more informations about it I'm interested
Edit : I've found this link http://forum.doom9.org/showthread.ph...75#post1167775 but is 113 or 120 the best version to use ? Last edited by Nico8583; 22nd March 2014 at 16:40. |
22nd March 2014, 21:53 | #12631 | Link |
I have this one:
dtsdecoderdll.dll version 1.1.0.0 (from the latest TMT build 120) MD5 644aa3ade7742079533dcde2abf153e2 and work fine for me also decoding non-standard 7.1
28th March 2014, 23:37 | #12637 | Link | ||
Makemkv doesn't have this problem. This is what the makemkv developper has to say about this: Quote:
So, if you want to make sure you are having a perfect DTS-HD to flac converstion as done by the reference DTS decoder, without needing to worry about the decoder dll version, process your MKV or bluray/iso with Makemkv. (if you want maximum flac compression with Makemkv set it to 12 in flac.mmcp.xml). edit: also, with makemkv you only need to copy the "dtsdecoderdll.dll" to the program directory. It doesn't need the other files and doesn't need the checkactivate, etc... no need to register the dll as it reads the DTS decoder contained within the file directly. |
29th March 2014, 04:56 | #12639 | Link |
SuperVirus
Another big to Bigmango,
BTW, that useful info was originally written @ http://makemkv.com/forum2/viewtopic....&t=7201#p30255 |
29th March 2014, 17:47 | #12640 | Link | |
BTW let me say than the conversion of DTS-HD 7.1 strange setup is not perfect because the channels Ls-Rs from DTS are converted to SL-SR channels in flac/wavex, when the channels SL-SR are the DTS channels Lss-Rss from the standard 7.1 setup.
eac3to |
