3rd September 2008, 18:18 | #6041 | Link | |
(6) Just one command line is sufficient for merging feature_1.EVO+feature_2.EVO. Last edited by rica; 3rd September 2008 at 18:20. |
3rd September 2008, 18:29 | #6043 | Link |
It repeats last part of the audio or fills with silence depending on how long the gap is. Not sure though (madshi correct me if i'm wrong). Good thing is that there's no movie with gaps till now..
3rd September 2008, 18:36 | #6045 | Link |
Blu-ray allows E-AC3 only for tracks with more than 5.1 channels (7.1). And these tracks are 5.1 AC3 core with E-AC3 extensions for the additional channels.
3rd September 2008, 19:05 | #6046 | Link | |
This is a old post but now I understand your comment about the surround channel. Now I have ArcSoft DTS decoder and don't work fine with these atypical channel configuration. My question is: to decode this dts ma 3/1 sample do you use Sonic or ArcSoft decoder? With -libav the surround channel is present, try: eac3to yoursample31.dtshd output.wav -libav -1,2,0,3,4,5 With ArcSoft: eac3to yoursample31.dtshd wrong_output.wav the surround channel is empty, and is empty also with dts core: eac3to yoursample31.dtshd core31.dts -core eac3to core31.dts wrong_output.wav |
3rd September 2008, 20:51 | #6048 | Link |
With the help of Elektra999 I have dts samples with atypical channel map.
The samples was encoded with DTS PRO SERIES SURROUND ENCODER. Only 3/2.0 and 3/2.1 was encoded with Surcode. Code:
AMODE Ch Arrangement+lfe Mask and MS channels order Detect-MaskCh eac3to libav remap ArcSoft problems -------- - --------------- -------------------------- -------------------- ----------- ---------------- 0b000010 2 L R 0x0003 FL FR 2.0 0x000B (1) not needed ok 0b000110 3 L R S 0x0103 FL FR BC 2/1 0x0103 ok not needed BC ch empty 4 L R S LFE 0x010B FL FR LF BC 2/1.1 0x010B (2) -0,1,3,2,4,5 BC ch empty (3) 0b001000 4 L R Ls Rs 0x0033 FL FR BL BR 2/2 0x0033 ok not needed BL+BR ch's empty 5 L R Ls Rs LFE 0x003B FL FR LF BL BR 2/2.1 0x003B (2) -0,1,4,2,3,5 LF ch empty 0b000101 3 C L R 0x0007 FL FR FC 3/0 0x000F (1)(2) -1,2,0,3,4,5 ok 4 C L R LFE 0x000F FL FR FC LF 3.1 0x000F (2) -1,2,0,3,4,5 ok 0b000111 4 C L R S 0x0107 FL FR FC BC 3/1 0x0107 (2) -1,2,0,3,4,5 BC ch empty 5 C L R S LFE 0x010F FL FR FC LF BC 3/1.1 0x010F (2) -1,2,0,4,3,5 LF same than BC 0b001001 5 C L R Ls Rs 0x0037 FL FR FC BL BR 5.0 0x003F (1)(2) -1,2,0,3,4,5 ok 6 C L R Ls Rs LFE 0x003F FL FR FC LF BL BR 5.1 0x003F ok already done ok (1) Wrong mask, the correct mask can be easyly put based in detection (2) When decoded with libav need remapping channels. (3) Same remap than libav needed. |
3rd September 2008, 20:54 | #6049 | Link |
Well, tebashuna51 you're right. There's something really strange with this track.
My findings: * ArcSoft and Sonic decode the DTS-HD MA track bit perfect * ArcSoft decode the DTS core "similar" to the above * Sonic decode the DTS core with lower volume * In the above cases the surround channel is empty * With Libav the surround channel is not empty * With Libav channels needs remapping * With Libav L,R,C channels are similar to ArcSoft core decoding I re-uploaded a sample of this track. Last edited by nautilus7; 3rd September 2008 at 21:24. |
4th September 2008, 01:25 | #6051 | Link | |
http://forum.doom9.org/showthread.ph...18#post1177618 _ _ _ _ __ |
4th September 2008, 01:44 | #6052 | Link | |
BTW, I tried the export function in supread (png format), which tsmuxer accepted, but subtitles didn't show up in the output (TMT said they were there however). |
4th September 2008, 01:49 | #6053 | Link |
I think you didn't read well what i said.
You will never read the subtitles without MPC-HC for the time being...(Zoom player?: just forget it.) Edit: sorry; except image + daemontools method....or burning to disc method... Last edited by rica; 4th September 2008 at 02:05. |
4th September 2008, 02:27 | #6054 | Link | |
Madshi, thanks for the recent update. I was able to complete operations on the NIN BD. However, the video pixelates heavily. I am not sure what is going on. Do you want another sample? Thanks
4th September 2008, 02:30 | #6055 | Link |
@rica,
Sorry, I'm not sure I follow. I am trying to convert HD-DVD to Bluray, iso if need be. TMT can play both HD-DVD and Bluray from hdd or from .iso files. I'm not sure that TMT will always continue to play HD-DVD however, so I want to convert my HD-DVD rips to Bluray, taking advantage of eac3to's new truehd conversion functionality. I thought that if you demux'd a bluray and hddvd with eac, the subtitles both end up with a .sup extension. I'm pretty sure I tried this, but it was pretty late. Won't tsmuxer accept a bluray .sup, but not a hddvd .sup? If so, I am hoping there is a way to change the from an hddvd formatted .sup to a bluray one. Does that make more sense? Thanks for the help! |
4th September 2008, 02:31 | #6056 | Link | |
2.0, 3.0, 3.1, 3/2 and 3/2.1 But don't work with: 2/1, 2/1.1, 2/2, 2/2.1, 3/1 and 3/1.1 Please, can you test Sonic with my samples_dts? Thanks. |
4th September 2008, 05:21 | #6057 | Link |
too much lurking
If you want your HD DVD .sup's to be BD .sup's just convert them to BD with supread. Load it up and tell it to output a BD file. There is plenty about this in the subtitle forum in threads with indicative names like "converting Blueray disk subtitles" and "HD subtitle ripping".
At any rate this discussion should continue down there. |
4th September 2008, 05:41 | #6058 | Link | |
- the sample (from Q-tec Demo Disc): http://forum.doom9.org/showthread.ph...02#post1153102 - the problem discussion with madshi: http://forum.doom9.org/showthread.ph...03#post1153303 http://forum.doom9.org/showthread.ph...71#post1153571 http://forum.doom9.org/showthread.ph...88#post1153688 my idea then was to patch the DTS-HD MA header and change the channel order, so Arcsoft can decode the track correctly and then rearrange the right order in the WAV: http://forum.doom9.org/showthread.ph...92#post1153692 but then we both with madshi agreed that it wasn't worth the effort for a single sample from a demo disc: http://forum.doom9.org/showthread.ph...00#post1153700 http://forum.doom9.org/showthread.ph...11#post1153711 now, we have sample from a real movie disc ("Edward Scissorhands" BD), not a demo disc. so, maybe we should look again at the problem. it should be very easy to patch the channel order byte in the header, but then there is CRC involved and i personally know nothing about how DTS(-HD MA) CRC is calculated and where is stored in the DTS(-HD MA) header. Last edited by xkodi; 4th September 2008 at 06:04. |
4th September 2008, 06:33 | #6059 | Link |
Here you go madshi
Those 2 are uploading to mediafire right now. When done (around midnight pacific time Wednesday night) they'll be here. Done, now and here are the correct links http://www.mediafire.com/file/wvj4shszfkv/00011.m2ts http://www.mediafire.com/file/wxufltmfgfa/00130.m2ts thanks Last edited by deacon crusher; 4th September 2008 at 07:42. Reason: link was bad |
4th September 2008, 08:04 | #6060 | Link |
Madshi, excellent application. Many Thanks.
I am using your tool to convert TrueHD to PCM and then mux audio and video together using tsMuxeR from ripped Blu-Rays. This works perfectly. I have read so much in this thread and just to make certain that the quality and command is OK. Am i doing it correct, if for instance the truehd audio track is 2 in the 0001.m2ts file: Convertion from TrueHD to PCM with no loss: C:\eac3to 0001.m2ts 2: out.pcm Do i need to use the -blu-ray switch? What is it exactly for? I have search this thread and could not find answers to these questions. Is this switch removed for a reason when only executing eac3to to obtain some help? Thanks again. |
eac3to |
