30th September 2012, 11:27 | #15881 | Link |
To Wakko79
I have noticed you get this behaviour if you copy the new version of BD Rebuilder over the old one, you need to completely delete the old version first, then put the new version in the directory (folder), this works for me, I get exactly the same error as you if I copy the new one over the old one. Hope that makes sense to you.
30th September 2012, 19:03 | #15882 | Link | |
30th September 2012, 21:12 | #15883 | Link |
I use BD-RB from the Desktop, and once I confirm the contents are the same (Giggling at jdobbs for a moment), I then extract the archive replacing the older. Then I move the archive to an archival directory until no longer needed. There should not be a challenge with replacing the older files unless a program/directory are "locked" from being used in some way. I've never deleted the older files or directories first; if the system is functioning correctly with respect to updating, it'll go smooth.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
2nd October 2012, 02:15 | #15884 | Link |
When using the new "Import" feature, and subsequently fully processing, will a video be "uncropped" to restore the compliant resolution (by adding black boarders) if necessary, or simply vertically stretched?
Win7x64...I had to... RIP WinXP Last edited by abbadon; 2nd October 2012 at 02:21. |
2nd October 2012, 10:07 | #15886 | Link |
hmmm, that's what I figured was SUPPOSED to happen, but for some reason I keep getting stretch video instead of borders . It's just import and process, right? No extra/hidden options? I'm sure I'm missing something...
Win7x64...I had to... RIP WinXP |
2nd October 2012, 12:30 | #15887 | Link |
Borders are added to make it compliant. But it isn't done during the import, it is done when processing the imported source. If you look in the BDMV/STREAM folder of the import (the pseudo-BD source) you'll see a file with the extension .ADJ. This holds any adjustments that needs to be made to the source. It is a text file and is made up of AVISYNTH functions (like AddBorders()).
2nd October 2012, 23:53 | #15888 | Link |
Just noticed that the newest BD Rebuilder (0.42.03) seems not to process what I have selected to blank or not to blank in Edit Mode when I save it in a batch queue; the BLANKED variable seems to have the correct 1's and 0's for what I'm editing, but BD Rebuilder uses the default auto-selected streams instead. Normal 'non-batch' mode works fine, however; wonder if anyone else has this problem or not.
3rd October 2012, 00:33 | #15889 | Link |
Hi Jdobbs,
How to properly process this unusual title? Bd Rebuilder does not accept the inclusion of the line "--bff". Code:
[09/28/12] BD Rebuilder v0.42.03 (beta) [11:02:17] Source: SUPER_SPEEDWAY_PLAYLIST_00000 - Input BD size: 12,45 GB - Approximate total content: [00:49:41.978] - Target BD size: 4,38 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: Better (Faster), Two Pass - X264 Tweak(s) enabled - Decoding/Frame serving: DGDecNV [2-way] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 - Subtitle [1] is defaulted ON. [11:02:20] PHASE ONE, Encoding - [11:02:20] Processing: VID_00000 (1 of 1) - [11:02:20] Extracting A/V streams [VID_00000] - [11:05:03] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 89.370 frames - Bitrate: 11.189 Kbs - [11:05:03] Reencoding: VID_00000, Pass 1 of 2 - [11:26:05] Reencoding: VID_00000, Pass 2 of 2 - Encode failed. Aborting. - BD-Rebuilder v0.42.03 (beta) - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: Isn't recommended version - FFDSHOW: 4422, not recommended version - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok Code:
General ID : 0 (0x0) Complete name : D:\BLU_RAY\SUPER_SPEEDWAY\BDMV\STREAM\00000.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 12.5 GiB Duration : 49mn 42s Overall bit rate mode : Variable Overall bit rate : 35.9 Mbps Maximum Overall bit rate : 48.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Format settings, GOP : M=3, N=18 Codec ID : 27 Duration : 49mn 41s Bit rate mode : Variable Bit rate : 31.4 Mbps Maximum bit rate : 35.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Bottom Field First Bits/(Pixel*Frame) : 0.505 Stream size : 10.9 GiB (87%) Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Muxing mode : Stream extension Codec ID : 134 Duration : 49mn 41s Bit rate mode : Variable Bit rate : 1 765 Kbps / 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossless / Lossy Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 49mn 41s Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 228 MiB (2%) Audio #3 ID : 4354 (0x1102) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 49mn 41s Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 228 MiB (2%) Text ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 |
3rd October 2012, 00:51 | #15890 | Link | |
Just a reminder... I don't accept bug reports that don't use the recommended versions of the helper software. Last edited by jdobbs; 3rd October 2012 at 00:55. |
3rd October 2012, 04:03 | #15891 | Link |
Ok, I'll do some more tests and figure out what's going on.
It is difficult to harmonize the only software that I always use. BD Rebuilder vs. RipBot264 As I recall, I never had problems because of that. But it can happen... |
3rd October 2012, 04:24 | #15892 | Link |
I figured it out. there is a conflict with the MULTIPROCESS option
my config had MULTIPROCESS=1 but once removed no problem. tried changing it to 2 but no luck separate, unless the source is oversized or FORCE_ENCODE is used, it doesn't process
Win7x64...I had to... RIP WinXP Last edited by abbadon; 3rd October 2012 at 04:35. |
3rd October 2012, 04:42 | #15893 | Link |
abbandon: If things fail in any way...Disable MULTIPROCESS and go from there. Once okay, try MP. It's usually fine left active for most movies.
Jdobbs: Any news with Toy Story? After it's done re-rendering here and rebuilding, I discovered if I click Backup again, it rebuilds shows a longer list of rebuilding text. I'll include logs if you like.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 3rd October 2012 at 06:16. |
3rd October 2012, 13:23 | #15896 | Link | |
mercadonegro
when I want to compress a 25GB Blu Ray. I choose not to keep the original audio. I want to convert or re-encode AC3, I always had errors. Why?.
3rd October 2012, 14:18 | #15897 | Link |
Run inspect.executive from inside the bdrb folder and post the results. That kind of behaviour typically indicates something wrong with the helper aps
Verstuurd van mijn HTC Sensation XE with Beats Audio Z715e met Tapatalk |
3rd October 2012, 19:13 | #15898 | Link |
@mercadonegro
Error 00070 is "Permission Denied" -- you have a permissions issue with either the application or the folder where it is attempting to write. I'd right-click on the files AFTEN.EXE and WAVI.EXE in the BD-RB tools folder and see if there is some rights issue against one of them. Last edited by jdobbs; 3rd October 2012 at 19:16. |
