18th September 2011, 16:18 | #10103 | Link |
Can your iphone or ipad play this sample?
http://www.mediafire.com/?1akz3a7xzbfkxbh
19th September 2011, 02:34 | #10107 | Link | |
http://www.mediafire.com/?01ekii73a0226q9 Please fast forward to 6:10 and you can see the blocks in the shadows and particularly at the shot of the bed on both the left and right sides. Also, in the last shot of the guy in the hat you can see the blocks on the left hand side in the black area (particularly at the top) and the right side in the blue area. Let me know how it plays back for you. Thanks! |
19th September 2011, 10:50 | #10108 | Link |
General Unique ID : 43294437635405724385507939182402684961 (0x2092349439C1C31BFE1378D58D814821) Complete name : C:\Users\Mama\Desktop\AB Chap10 Test.mkv Format : Matroska File size : 120 MiB Duration : 6mn 58s Overall bit rate : 2 399 Kbps Writing application : HandBrake 0.9.5 Writing library : libmkv 0.6.4.1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 6mn 58s Bit rate : 1 711 Kbps Width : 1 280 pixels Height : 688 pixels Display aspect ratio : 16:9 Original display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.081 Stream size : 85.4 MiB (71%) Writing library : x264 core 112 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Language : English Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : A_AC3 Duration : 6mn 58s Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 31.9 MiB (27%) Language : English
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 19th September 2011 at 10:55. |
19th September 2011, 15:57 | #10109 | Link | |
Okay, I tried this install again. Uninstalled everything, and installed everything, rebooted. And I'm still having the same issue with the audio keeps going and the video freezing. So what else could the problem be. I don't ever install any other codecs packs either. I have VLC media player installed, Nero 10 Platinum HD installed as well. I have a malware(Malwarebytes), and Eset BE installed and have no viruses, nor malware installed. So why am I having this issue. I am running Windows 7 Home Premium 64 bit. I can do a 2 pass in little than hour. I am outputting to a AVCHD. I have a Phenom II AMD 6 core processor mobo. ALl help would be greatful as I keep having to throw away wasted media. I also have AnyDVD HD 6860 running as well. Last edited by mrpitman; 19th September 2011 at 16:00. |
19th September 2011, 19:35 | #10115 | Link | |
I was amazed to see most of the 1080p sources coming out at about 2.5gb 720p files and thought that was really small. I was concerned when the average bitrates showed more in the 2500 kpbs range when I read that for 720p you usually want around 6000 kpbs (or 8000 kpbs for 1080p). When I played the 720p files done at crf 20 they looked great. I was amazed and a true believer in how good 264 is so I thought that even though the bitrate seemed low, it didn't matter as the picture looked so good. Aside from all that, the problem I am referring to in the sample is present whether I encode at crf 20, 18, or 2 pass at 6144 kpbs. In addition, this excessive blockiness only seems to occur from VC1 sources. Could it be that some sources (this one in particular) requires a much higher kpbs in order to remove the blocks? I am very interested to hear your take on my understanding of what crf should be used vs overall bitrate and, more importantly, were you able to reproduce the blockiness I am referring to when playing back the sample. |
19th September 2011, 23:04 | #10117 | Link |
You said you haven't installed a Codec Pack at all but VLC includes a Codec-Pack!
Please try MPC-HC from here and disable H.264 and VC.1 insite MPC-HC to force external encoders (Preferences -> Internal Filters). Let us know if you still have these problems. |
19th September 2011, 23:21 | #10118 | Link | |
I'm not trying to watch my avchd on my desktop. I am watching these on my $ony standalone bluray player. So why do I need to install another media player? I don't watch movies on my desktop. I need this issue resolved so I can enjoy my AVCHD on my HTS. Last edited by mrpitman; 19th September 2011 at 23:30. |
