27th December 2016, 23:12 | #14641 | Link |
I usually use the [MAIN x.x] 8bit Progressive profile H265, could somebody explain the benefits and pitfalls (if any) of using the [MA10 x.x] 10bit progressive profile please?
I've tried Googling and can't really find anything. |
28th December 2016, 00:07 | #14642 | Link |
Could use some help.
Just finished encoding 2 whole series of about 300 episodes only to discover that my Plex server just stops playing the resulted file after about 1 minute. I can play the file locally just fine with MPC-HC, but all files encoded with RipBot264 behave the same: they stop after ~ 1 minute when playing from a Plex server. ffmpeg -v error -i filename.mp4 -map 0:1 -f null - 2>error.log shows no errors. Anyone else experienced such behavior? later edit: I even tried copying the file to Apache htroot and access the file via Chrome and the play stopped at the same time frame. So clearly Plex is not the problem. Last edited by Deepcuts; 28th December 2016 at 00:54. |
28th December 2016, 01:18 | #14643 | Link |
@ Atak_Snajpera
hai.. can i ask something.. i load file and take long time to gathering information...the file just 1.20GB i try use another computer load fast...can i know what is the problem? thank you hope you reply ASAP |
28th December 2016, 16:24 | #14646 | Link | |
You may also try remuxing your encodes to mkv.
29th December 2016, 05:38 | #14648 | Link |
I have tried to re-encode a file with --stitchable, but the result is the same.
Using Google Chrome to directly play the mp4 from a web server or Plex, freezes the play at ~1:00 min. Using Internet Explorer 11, Plex will not freeze. So I guess this must be a Chrome problem somehow. I tried re-muxing the mp4 as mkv, but no luck. It is still freezing. |
2nd January 2017, 15:56 | #14649 | Link | |
ByteShare
8bit faster encode, slightly smaller filesize (sometimes), and higher degree of compatibility (number of devices that can play smoothly). 10bit better handling of dark scenes and banding (noticeably in CRF 20-24 (were I mostly encode)). |
2nd January 2017, 15:59 | #14650 | Link | |
ByteShare
4th January 2017, 12:51 | #14652 | Link | |
http://forum.doom9.org/showthread.ph...96#post1524496 |
5th January 2017, 11:09 | #14653 | Link | |
some file take around 4-5minute...but i test same file on other pc work fast.. gathering information only take 15-20second only.. |
5th January 2017, 11:32 | #14654 | Link |
Hi Atak,
I think I may have discovered a bug when using the new noise filter MDgrain2. If you abort a job (when using DE, haven't tried it without), and when the pop up comes up "Do you want to keep the current progress ?", and you chose "Yes"...when you come back to it, it starts from the beginning Please feel free to try it, I don't think it's just my setup, as it does it on a couple of different pc's, either W8.1 or W10. But having said that, MDgrain2 does a really good job on "noisy" files, worth the wait, as it is quite a lot slower. Which brings me to my next comment / request. I know I have asked you many times to add more DE servers, 10 is nice, 12 or more would be great...the more help you can get with these new filters and settings, the better. It would be a great new feature to start 2017. Please consider Happy New Year y'all. |
5th January 2017, 18:01 | #14655 | Link | |
ByteShare
My thought is it would be great if you have 9 servers idle they could start on the next encode, meaning once all the chunks are filled another encode would start so no server is ever idle. |
6th January 2017, 00:46 | #14657 | Link | |
But it's only when using the new filter. Not too sure what you mean about the 9 idle servers...or do you mean you might be able to have multiple encodes going, on each DE server, so up to 10 jobs, not 1 job over 10 servers ?!?!? Either way, the more DE servers, the better, especially if you have many powerful pc's. |
6th January 2017, 16:41 | #14658 | Link | |
ByteShare
For the 9 idle servers I mean near the end of a job when you only have a few chunks left and servers start to go idle because there are no chunks left to encode, if those idle servers could start working on the next job that would be awesome. |
7th January 2017, 00:56 | #14659 | Link | |
Yeah, on further observation, I have noticed that the problem occurs on other encodes, not just with MDegrain, so I must have a problem somewhere. Interested in your mention of a manual edit to use MDegrain3....more info on that, please Yep, I have to agree with your idea about the servers activity at the end of a job....good idea !!! But I'd still like MORE..... |
