11th November 2013, 18:28 | #1061 | Link | |
Professional Code Monkey
Experimentation welcome. Just keep in mind i didn't write any asm for the vapoursynth functions planedifference and planeaverage yet so for now it will be slightly slower.
11th November 2013, 18:34 | #1062 | Link |
On latest git from vapoursynth:
Python 3.3.2 (default, Aug 18 2013, 22:19:13) [GCC 4.8.1] on linux Type "help", "copyright", "credits" or "license" for more information. >>> import vapoursynth as vs terminate called after throwing an instance of 'std::regex_error' what(): regex_error Aborted Anybody knows if this is supported on other compilers (4.9 looks far away for me)? |
11th November 2013, 20:14 | #1063 | Link | |
11th November 2013, 22:24 | #1065 | Link |
I should be fixed now, I guess. Report any other new linux issues you find.
11th November 2013, 23:27 | #1066 | Link |
Great work so far Myrsloik. :-)
What about making Vapoursynth OpenFX compatible? That would open the power of Vapoursynth to a lot of users, professionals and users of the free but powerful Resolve Lite but I am sure users of other apps like Nuke etc. would would also profit from it. JB Last edited by Joachim Buambeki; 12th November 2013 at 00:27. |
12th November 2013, 00:39 | #1068 | Link | |
12th November 2013, 09:09 | #1069 | Link |
If I prevent removegrain from building everything works great (also just as an informative note, clang throws the same error at runtime when regex are used).
gcc and clang complain on the new code: gcc buildlog Code:
../src/filters/removegrain/clense.cpp:152:19: error: cast from ‘void*’ to ‘int’ loses precision [-fpermissive] d.mode = (int)userData; Code:
../src/filters/removegrain/clense.cpp:152:14: error: cast from pointer to smaller type 'int' loses information d.mode = (int)userData; ^~~~~~~~~~~~~ 1 error generated. ../src/filters/removegrain/removegrainvs.cpp:1241:3: error: constant expression evaluates to -294912 which cannot be narrowed to type 'uint32_t' (aka 'unsigned int') [-Wc++11-narrowing] { -0x8000 * 9, -0x8000 * 9, -0x8000 * 9, -0x8000 * 9 }; ^~~~~~~~~~~ ../src/filters/removegrain/removegrainvs.cpp:1241:3: note: override this message by inserting an explicit cast { -0x8000 * 9, -0x8000 * 9, -0x8000 * 9, -0x8000 * 9 }; ^~~~~~~~~~~ |
12th November 2013, 11:57 | #1070 | Link |
I am not sure what you mean with "source plugin", but my idea was to select Vapoursynth as a filter in the host application and then you can open a console or something similar where you can type in the filter effect (without the import video stuff of course because it does that automaticaly).
What would be even cooler if it would be possible if one could create wrappers to directly call a certain filter (script) from Vapoursynth like a regular plugin. A similar suport for After Effects would be great but that would mean that a separare plugin would have to be written, since AE isn't OpenFX compatible unfortunately. I can only guess but support for these applications should also speed up development of Vapoursynth alot if communicated through the right channels (forums where those people are - CreativeCow, LiftGammaGain, etc.). There should be a fair amount of pros that would be willing to donate their time to help with development I suppose. Last edited by Joachim Buambeki; 12th November 2013 at 12:03. |
12th November 2013, 14:08 | #1071 | Link |
Beyond Kawaii
I'm trying to write a VapourSynth Python script function. When I pass an argument as None, I want AviSynth filter to use the default value for that argument. How can I do that? Can I form a string of AviSynth filter call and "Evaluate" it?
...desu! Last edited by Mystery Keeper; 12th November 2013 at 14:12. |
12th November 2013, 14:16 | #1072 | Link | |
d = dict(arg1=1, arg2=2) #args you always set here if arg3 is not None: # optional arg that shouldn't be set when None d['arg3name'] = arg3 clip = core.avs.AvsFunction(**d)
12th November 2013, 16:56 | #1074 | Link |
Beyond Kawaii
1) Is there mt_diff analog for VapourSynth? I can do it like this:
def absdiff(x, y): return min(max(0, 127 + x - y), 255) diff = core.std.Lut2([a, b], function = absdiff) 2) Is there HistogramAdjust analog for VapourSynth, or should we ask the author for port?
...desu! |
12th November 2013, 17:06 | #1075 | Link | |
2. No again
15th November 2013, 11:31 | #1076 | Link |
Beyond Kawaii
AvsPMod silently crashed after several minutes of experimenting with this script. VirtualDub silently crashed after processing ~120000 of ~150000 frames.
Script uses this function. Code:
avisynth_plugins_path = 'E:\\avisynth-plugins\\' vapoursyth_plugins_path = 'E:\\vapoursynth-plugins\\x32\\' import vapoursynth as vs import sys sys.path.append(vapoursyth_plugins_path + 'E:\\vapoursynth-plugins\\py\\') core = vs.get_core(threads=8) core.set_max_cache_size(3500) import os for filename in os.listdir(vapoursyth_plugins_path): if filename[-4:] != '.dll': continue core.std.LoadPlugin(vapoursyth_plugins_path + filename) core.avs.LoadPlugin(path = avisynth_plugins_path + 'mvtools2.dll') core.std.LoadPlugin(path = 'D:\\Programming\\TempLinearApproximate-VapourSynth\\build\\release-x32\\templinearapproximate.dll') d2vfile = 'F:\\Video to Process\\Riaru Onigokko 2\\VTS_01_1.d2v' ret = core.d2v.Source(input=d2vfile) def pcToTv(input): c = core.fmtc.resample (clip=input, css="444") c = core.fmtc.matrix (clip=c, mats="601", matd="709") c = core.fmtc.resample (clip=c, css="420") c = core.fmtc.bitdepth (clip=c, bits=8) return c z = pcToTv(ret) sys.path.append('D:\\Programming\\TempLinearApproximate-VapourSynth\\') import MCDenoise tlamc = MCDenoise.MCDenoise() tlaArguments = dict(radius=2, BlockSize=8, Overlap=4, SubPel=4, SubPelInterp=2, Search=5, SearchParam=2, PelSearch=4, DCT=10, ThSAD=200) ret = tlamc.TempLinearApproximate(ret, **tlaArguments) ret = tlamc.TempLinearApproximate(ret, **tlaArguments) ret = core.f3kdb.F3kdb(ret, dither_algo=2, grainy=0, grainc=0, keep_tv_range=True) ret = pcToTv(ret) ret.set_output() def absdiff(x, y): return min(max(0, 127 + x - y), 255) unfiltered = core.text.Text(z, "unfiltered") filtered = core.text.Text(ret, "filtered") stack = core.std.StackHorizontal([unfiltered, filtered]) diffhist = core.std.Lut2([z, ret], function = absdiff) #diffhist = core.generic.Levels(diffhist, planes=0, gamma = 3) diffhist = core.text.Text(diffhist, "Difference") filteredhist = core.generic.Levels(ret, planes=0, gamma = 2) filteredhist = core.text.Text(filteredhist, "Filtered amplified") diffstack = core.std.StackHorizontal([diffhist, filteredhist]) compare = core.std.StackVertical([stack, diffstack]) #compare.set_output()
...desu! |
15th November 2013, 11:44 | #1077 | Link | |
15th November 2013, 11:50 | #1078 | Link |
Beyond Kawaii
The processing speed fluctuates relatively much. 5-11 FPS. But I don't know about the time when it crashed. Is there a way to profile at least the memory use without having to constantly monitor it? Is it possible to have on demand FPS and memory usage profiling and logging functionality in VapourSynth?
...desu! |
15th November 2013, 11:55 | #1079 | Link | |
VapourSynth - proving that scripting languages and video processing isn't dead yet Last edited by Myrsloik; 15th November 2013 at 11:55. Reason: Missed the TLA dll |
15th November 2013, 11:59 | #1080 | Link |
Beyond Kawaii
Right, sorry. Restarted the encode with memory limit changed to 2500. 9K frames so far. Memory usage isn't going over 840MB, but IS slowly rising.
Update: 100000 frames. Still the same fluctuating bitrate. Memory usage still not going over 840MB.
...desu! Last edited by Mystery Keeper; 15th November 2013 at 15:23. |
speed, vaporware, vapoursynth |
