2nd August 2013, 20:41 | #881 | Link |
Software Developer
Didn't realize "vsscript.dll" gets installed into the system folder. Anyway, I also need to find "vspipe.exe" for my application.
Or do you suggest "vspipe.exe" should be redistributed with my application? Will future versions of "vsscript.dll" be backward compatible to current "vspipe.exe" version?
2nd August 2013, 21:38 | #882 | Link | |
Professional Code Monkey
2. Will never happen, converting behind the user's back will cause more problems than it solves. Why not add a conversion line to the end of the script when needed? It also sounds like you want to convert ONLY to conveniently pass clip metadata... 3. Currently there's no good way. I'll create proper registry keys in the R20 installer so HKLM\Software\VapourSynth will have keys containing paths and versions. Chikuzen's way will work if all you want to know is if it's R19 or later. The path in the uninstall entry is of course also valid to use.
3rd August 2013, 12:20 | #883 | Link | |
Software Developer
And indeed, I need to output YUV4MPEG, so that x264 gets the required meta information. Surely the required conversion line can be added to the script manually. But the problem here is that the script is provided by the user. And the GUI needs to ensure it will encode properly. It's not trivial at all to add the required line into an arbitrary user-provided script in an automated way. Currently it will simply error out. And then the user will have to understand and fix the issue himself. That's where 2/3 of all users say "Damn, the GUI isn't working with my script, let's try a different one!". Also, I think in 99% of all use cases where the output of the script is sent to x264, we are going to need YUV anyway. I know x264 can do RGB encoding too, but that's a very rare use case. So, in 99.9% of all cases, either we sent YUV data to x264 or x264 will convert the RGB data to YUV by itself. This means forcing the RGB to YUV conversion on the VapourSynth side wouldn't hurt...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 3rd August 2013 at 12:22. |
3rd August 2013, 17:29 | #884 | Link | ||
@Myrsloik
I'm trying to write (more like copy-paste) documentation for AVISource and have some questions. In Avisynth you can do this AVISource("video1.avi", "video2.avi"), is this possible in Vapoursynth? I tried but I get an error. Just want to make sure so I don't included. Is the order of decompression still true or has it changed because of the additional color spaces that it now supports? Quote:
3rd August 2013, 19:02 | #885 | Link | |
Pixel_type works the same as avisynth describes but with a few additional formats. unset tries (in this order): YV24 YV16 YV12 YV411 YUY2 RGB32 RGB24 RGB48 Y8 P010 P016 P210 P216 v210 I'm going to remove AUTO and FULL (since FULL is implicit when unset) and AUTO is an avisynth leftover. No idea why anyone'd want the old order. Interesting bug find. I think I know why it gives the environment id not set error and I'll probably fix it in the next version.
7th August 2013, 13:05 | #887 | Link |
Probably I'm doing something wrong, but I'm having problems adding black borders to a clip via AddBorders. The borders are always green. I've tried to add the command to a P210 clip but also on a YUV422P8 clip. The size is 1920x804 so I need to add 138px at top/bottom to pad the fullhd resolution.
7th August 2013, 13:19 | #888 | Link | |
AddBorders(..., color=[0,128,128]) For 10bit: AddBorders(..., color=[0,512,512]) I'll make it default to black borders always in the next version.
8th August 2013, 01:44 | #891 | Link |
May i suggest wine and virtualdub?
8th August 2013, 17:28 | #892 | Link | |
unsigned int
(Tested with a grand total of 1 scripts.)
Buy me a "coffee" and/or hire me to write code! |
9th August 2013, 01:12 | #893 | Link | |
9th August 2013, 17:03 | #895 | Link |
unsigned int
I will assume you mean a guide...
clip = core.ffms2.Source("bigbuckbunny.mkv") # Both AssRender() and Subtitle() return a list of two clips: # the rendered subtitles in RGB24 and a Y8 mask you'll # need to use to blend the subtitles with the video clips = core.assvapour.AssRender(clip, "moo.ass") # or #clips = core.assvapour.Subtitle(clip, "Text to be burnt into the video.") # convert the subtitles into the video's format (here we pretend it's YUV420P8) clips[0] = core.resize.Bicubic(clips[0], format=vs.YUV420P8) # and blend ret = core.std.MaskedMerge([clip, clips[0]], clips[1])
9th August 2013, 23:48 | #896 | Link | |
14th August 2013, 18:41 | #897 | Link | |
Could some be so nice to translate the following easy script for me please?
Obviously I need to learn a loooot more about it as all my attempts are quitted with error code 1 (using Simple x264 launcher) Quote:
14th August 2013, 18:51 | #898 | Link | |
import vapoursynth as vs core = vs.get_core() core.avs.LoadPlugin(r"C:\Program Files (x86)\AviSynth 2.5\plugins\DGDecodeNV.dll") core.avs.DGSource(r"The Score.dgi", resize_w=720, resize_h=576, deinterlace=1).set_output()
14th August 2013, 19:29 | #899 | Link | |
Software Developer
15th August 2013, 15:27 | #900 | Link | |
I was close...not that close, but close need to learn more about that "r" in the path setting /EDIT: compared varoursynth with avisynth64 on my machine. Very close....9560 frames with VS and 9575 with AS (5 minute timerun) When there are 64bit builds available tell me IŽll repeat my test. Last edited by Rodger; 15th August 2013 at 16:25. |
speed, vaporware, vapoursynth |
