20th July 2010, 15:08 | #61 | Link |
Just discovered/tested this software, but seems that don't fit my needs.
Dunno if anyone else could be interested in this, but I decided to switch to Vorbis/MKV for CD-Images with embedded cuesheets. It will be possible to use UsEac3to for this purpose ? |
20th July 2010, 15:18 | #62 | Link |
Life's clearer in 4K UHD
Many thanks tebasuna51.
Decoding the HD audio element works a treat now
21st July 2010, 10:28 | #63 | Link | |
UsEac3to in only a GUI for eac3to (and some Auxiliary Tools).
21st July 2010, 11:06 | #64 | Link |
HDConvertToX author
hi tebasuna51
jfyi i made a guide for your gui it's focused on remuxing ts to mkv it's on www.divxmania.it , an italian forum about video/audio encoding (where i am mod) http://forum.divxmania.it/da-ts-a-mk...ca/t12364.html thanks for your tool! BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
30th July 2010, 15:35 | #65 | Link |
Update (only the GUI): UsEac3to 0.7.42
With mkv's generated with defaults in new versions of MkvMerge, from 4.1.0, the audio tracks (AC3, DTS, MP3 and MP2) can't be managed correctly with eac3to (header compression problem). Same problem (eac3to now crash) with video track H264, from v4.2.0. Changes: - The button 'Run and MkvMux' use now --compression -1:none, all tracks muxed without compression. - New option in 'MkvExtract/Mux' to remux the problematic mkv input without compression (now compatible with eac3to, tsmuxer, WD TV, ...)
2nd August 2010, 12:57 | #66 | Link | |
30th November 2010, 15:55 | #71 | Link |
New UsEac3to v0.8
Changes v0.8 2010-11-29 - Now 'Output format' only show eac3to extract/convert allowed options for 'Track Input' If show 'A.Tools' only 'Auxiliary Tools' can manage track/file. Examples: Xvid in mkv can be extracted with 'MkvExtract' Vobsub in mkv also can be extracted with 'MkvExtract' .ogg, .m4a, ... can be decoded with 'Decode ogg/mpx' (external decoders needed). .srt, .ssa, .ass subs and .xml, .txt chapters can be delayed and/or stretched with 'SRT/.../TXT'. - Better support for .mpls. Automatically feature 1) added.
22nd January 2011, 23:00 | #76 | Link |
I can not convert AAC files to AC3 files, as your GUI as it says "Nero Audio Decoder 2 instance failed."
Since I will not have Nero installed, so I downloaded this zip file "NeroAACCodec-1.5.1.zip" from here: http://www.nero.com/eng/downloads-ne...-aac-codec.php And copied exe files into the folder of your GUI and eac3to. I hope you or someone else can help me. |
23rd January 2011, 00:25 | #77 | Link |
NeroAacDec.exe (from NeroAACCodec-1.5.1.zip) can decode AAC audio inside MP4 container (.mp4 or .m4a).
To decode AAC audio with ADTS headers (.aac) you need Faad.exe (http://www.rarewares.org/)
