9th December 2009, 21:44 | #10741 | Link |
No problem on Win7x64, cat. 9.11 and ATI HD4770
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
9th December 2009, 22:00 | #10743 | Link | |
Maybe revert? |
10th December 2009, 01:17 | #10744 | Link |
I would second this. Beliyaals changes from 1311 to 1312 seem to cause random stuttering. Maybe he can fix this (i think its caused by trylock and the "preventing" other processes from accessing directx) or revert. I do not really know if the changes fixed anything for anybody. If there is somebody for whom the 1311 to 1312 transition fixed something related to beliyaals code, please report!
10th December 2009, 09:19 | #10745 | Link | |
Do you have "random stuttering" using default MPC-HC settings ?
Intel UHD Graphics 750; Win 10 22H2 |
10th December 2009, 10:08 | #10746 | Link | |
10th December 2009, 11:01 | #10748 | Link | |
It's not that new versions aren't better most of the times, it's that beliyaals particular change in 1312 seems to be detrimental to a number of people with different configs while not having any benefits. |
10th December 2009, 11:09 | #10749 | Link | |
Exactly as I thought please use DEFAULT not optimal ! or at least disable "Enable Time Frame Correction" and "Alternative VSync" (except for when using "WMVideo Decoder DMO" for VC-1 i )
Even better Quote:
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 10th December 2009 at 11:14. |
10th December 2009, 13:51 | #10750 | Link | |
Perhaps we need to look for the common elements between the reports of stuttering? |
10th December 2009, 20:08 | #10751 | Link | |
so for those on win7 who uses TV as a secondary monitor and gets stutter free playback, what card do you have and what config do you use? (renderer, filter, etc.) thanks. |
10th December 2009, 20:47 | #10752 | Link | |
11th December 2009, 12:51 | #10755 | Link |
It simply uses an external decoder from Broadcom. If you want the same for NVIDIA, then install the Purevideo decoder (or any other DXVA MPEG-2 decoder, like the Cyberlink one). But be aware that DVD subtitles won't work properly when using DXVA on Vista/7.
MPC-HC 2.2.1 |
11th December 2009, 13:22 | #10756 | Link |
The PGS subtitles are NOT displayed in some files: sample (although I can see / select them in Filters-> File Path ->... or Navigate -> Subtitle Language ->...) but they are displayed in the same file using other players
Also, it takes 2-3 or more sec before PGS subtitles are displayed while the external subtitles (srt, sub ...) are displayed immediately
11th December 2009, 21:21 | #10757 | Link |
Otaku
MPC hangs under the following conditions:
Using two displays and Direct3d fullscreen if a video is already playing and you try to open another one (with double click) without closing the first one with ctrl+c the player leaves fullscreen and hangs leaving two copies of mpc running. if you terminate the first copy both terminate. further double clicks in videos just increase the number of mpc copies running in the background but if you open another one yourself then double click a video the copy you have opened opens that video.
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
12th December 2009, 09:10 | #10758 | Link |
Hello, people. I have been using MPCHC for quite a bit of time, it’s a wonderful piece of software – fast, small, powerful and universal. Thanks for your hard work, MPCHC staff!
However, lately I had encountered a very unpleasant problem with this player. You see, I had fallen a victim of this “netbook epidemia” and purchased asus t91. It’s a convertible netbook with a touchscreen, nice for a websurfing in tablet pc mode. Another reason why I bought it was it’s videochip – Intel GMA 500. Yes, it can do DXVA, so I won’t be hold back by an Atom CPU while watching HD video with MPCHC. Quite a combination of a PMP and a PC! Or so I thought. Here comes the catch – I like watching movies in high quality with an original sound (I’m not a native English speaker, you see). That’s why I need both DXVA acceleration AND subtitles. And here we have a problem. Every time I try to enable EVR CP (the only way to have DXVA and subs in Windows 7, right?), it crashes after restart (probably, because MPCHC applies renderer settings change only after restart). But when I use simple EVR net3 – it works perfectly – no lags, CPU load being low during playback, writing “DXVA mode: H264 bitstream decoder: no FGT” in filters>MPC Video Decoder properties. So, it is not impossible to enable DXVA on my netbook with it’s current OS and software. But I need subs also. I tried everything from here http://sourceforge.net/apps/trac/mpc...ing_guidelines (including installation of august09 DirectX and both Microsoft Visual C++ packs). I tried clean install. I tried latest SVN builds. I tried disabling Kaspersky Internet Security. I tried 3D fullscreen. I tried different resizers. I tried PowerDVD decoder as an external filter. I tried disabling Aero. I tried another (older) videochip driver. After all, I tried resetting everything to default via registry as described in troubleshooting guide. It won’t work. EVR CP still crashes. Here are my system specs. Everything is the same as on Asus website http://www.asus.com/product.aspx?P_ID=qdwslBLhhfuw43HS but I installed Win7 Pro on it instead of XP. Aero is on. OS: Win7 6.1.7600.2.0.0.256.48 MPCHC versions I tried: 1.3.1333.0, 1.2.1008.0, SVN 1347 GMA 500 Drivers I tried: 5.0.0.2015 from Oct 14, 2009 (current), and 4.0.2 from 11.08.2009 Certain oddities that might be helpful: VMR 9 renderless crashes also, but VMR7 and Overlay Mixer both works with Aero on. This is strange, because when I try using Overlay Mixer on my desktop (Win 7 also), it kills Aero immediately. Widows problem tool says that the problem is with an "igdumd32.dll version 8.14.10.2015" Here is my minidump http://sharebee.com/683340d4 Sorry for such a long post, and for my poor English everyone. But I am desperately looking for help. |
12th December 2009, 10:06 | #10759 | Link |
MPC-HC Project Manager
Hello T91User,
Please use this build for the time being: http://www.xvidvideo.ru/media-player...-svn-1311.html Can you contact Beliyaal (send him a PM) There is a bug in the intel driver for the GMA500 and its being triggered by the scanline changes introduced in 1312. Beliyaal does not have this hardware so he needs someone to test some things for him.
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
12th December 2009, 11:58 | #10760 | Link |
Thanks a lot, tetsuo55! This words are too pale to express my feeling of gratitude, but i will repeat: thank you. With the version that you recomended, it all works - dxva, subs and evr cp. I'm happy I can continue to use my favorite player. Already wrote a PM to Beliyaal. If i could be of any help for testing, I'll do it.
