14th August 2009, 14:02 | #101 | Link |
Software Developer
Updated x264 to r1210 (JEEB's builds). Download link in first post updated.
18th August 2009, 02:27 | #102 | Link |
Software Developer
Updated x264 to r1214 (JEEB's builds). This fixes a bug in QPRD (SubME 10) and greatly improves 1-Pass VBV. Update to x264 r1214+ is highly recommended.
18th August 2009, 04:50 | #103 | Link | |
I have one question regarding your software. Is the software only encode video without audio or it also encode audio for the movie (like Megui)? |
18th August 2009, 07:04 | #105 | Link | |
Since you have answered the question, I thank you very much. |
18th August 2009, 12:31 | #106 | Link |
Software Developer
Correct. It's a very simple front-end to x264.exe, nothing else. And x264.exe doesn't process audio at all
I recommend MKVToolnix or YAMB to mux in the audio after encoding, when needed...
18th August 2009, 14:08 | #108 | Link |
Software Developer
19th August 2009, 23:23 | #109 | Link |
Software Developer
Updated x264 to r1217 (JEEB's builds). Download link in first post updated.
20th August 2009, 04:37 | #110 | Link | |
28th August 2009, 18:30 | #111 | Link |
Hi there!
Benchmarks are fun! AMDPhenom(tm 9950 Quad-Core Processor 2.60GHz; Windows Vista(tm) Ultimate 64bit SP2, Source: DivX.Avi@17000kbits (Ingame Video); x264 JEEB's builds from your .7z archive Code:
Source: H:\17000B&B.avs Preset: Faster Tuning: None Profile: High Params: (din't show but --crf 23.0 --output H:\17000B&B2.mp4) [Type: 32-Bit, Pipe Buffer Size: 0 MByte] encoded 10104 frames, 30.87 fps, 4849.01 kb/s encoded 10104 frames, 31.22 fps, 4848.35 kb/s encoded 10104 frames, 31.35 fps, 4847.00 kb/s [Type: 64-Bit, Pipe Buffer Size: 0 MByte] encoded 10104 frames, 31.96 fps, 4850.68 kb/s encoded 10104 frames, 31.95 fps, 4850.15 kb/s encoded 10104 frames, 31.88 fps, 4847.02 kb/s [Type: 64-Bit, Pipe Buffer Size: 1 MByte] encoded 10104 frames, 32.17 fps, 4843.76 kb/s encoded 10104 frames, 32.13 fps, 4848.87 kb/s encoded 10104 frames, 32.22 fps, 4851.95 kb/s [Type: 64-Bit, Pipe Buffer Size: 2 MByte] encoded 10104 frames, 32.74 fps, 4849.16 kb/s encoded 10104 frames, 32.77 fps, 4849.17 kb/s encoded 10104 frames, 32.74 fps, 4844.90 kb/s [Type: 64-Bit, Pipe Buffer Size: 4 MByte] encoded 10104 frames, 32.97 fps, 4847.00 kb/s encoded 10104 frames, 32.93 fps, 4851.58 kb/s encoded 10104 frames, 33.01 fps, 4846.86 kb/s [Type: 64-Bit, Pipe Buffer Size: 8 MByte] encoded 10104 frames, 32.86 fps, 4847.44 kb/s encoded 10104 frames, 32.95 fps, 4849.03 kb/s encoded 10104 frames, 32.92 fps, 4849.81 kb/s Resolution: 1280 x 720 Frame No. : 10104 Frame Rate: 25/1 x264 0.72.1217M 5e9ae4c built on Aug 20 2009, gcc: 4.3.4 20090220 (prerelease) (x64.generic.Komisar) Revision: 1217 Source: YV12 640x360 Code:
Source: H:\17000B&B.avs Preset: Faster Tuning: None Profile: High Params: [Type: 32-Bit, Pipe Buffer Size: 0 MByte] encoded 10104 frames, 128.38 fps, 1441.13 kb/s encoded 10104 frames, 117.09 fps, 1441.13 kb/s encoded 10104 frames, 117.66 fps, 1441.13 kb/s [Type: 64-Bit, Pipe Buffer Size: 0 MByte] encoded 10104 frames, 123.71 fps, 1441.13 kb/s encoded 10104 frames, 125.47 fps, 1441.13 kb/s encoded 10104 frames, 123.43 fps, 1441.13 kb/s [Type: 64-Bit, Pipe Buffer Size: 1 MByte] encoded 10104 frames, 136.70 fps, 1441.13 kb/s encoded 10104 frames, 134.54 fps, 1441.13 kb/s encoded 10104 frames, 136.24 fps, 1441.13 kb/s [Type: 64-Bit, Pipe Buffer Size: 2 MByte] encoded 10104 frames, 134.89 fps, 1441.13 kb/s encoded 10104 frames, 142.73 fps, 1441.13 kb/s encoded 10104 frames, 134.41 fps, 1441.13 kb/s [Type: 64-Bit, Pipe Buffer Size: 4 MByte] encoded 10104 frames, 137.39 fps, 1441.13 kb/s encoded 10104 frames, 137.96 fps, 1441.13 kb/s encoded 10104 frames, 135.49 fps, 1441.13 kb/s [Type: 64-Bit, Pipe Buffer Size: 8 MByte] encoded 10104 frames, 139.85 fps, 1441.13 kb/s encoded 10104 frames, 139.96 fps, 1441.13 kb/s encoded 10104 frames, 139.14 fps, 1441.13 kb/s Don't know if you can use this: DivX.Avi@17000kbits with JEEB's builds from your yesterday.. no big changes: Code:
Source: H:\17000B&B.avs Preset: Faster Tuning: None Profile: High Params: (din't show.. but: --crf 23.0 --output H:\17000B&B2.mp4) [Type: 32-Bit, Pipe Buffer Size: 0 MByte] encoded 10104 frames, 31.01 fps, 4820.78 kb/s encoded 10104 frames, 30.86 fps, 4820.53 kb/s encoded 10104 frames, 31.17 fps, 4819.30 kb/s [Type: 64-Bit, Pipe Buffer Size: 0 MByte] encoded 10104 frames, 31.68 fps, 4819.03 kb/s encoded 10104 frames, 31.82 fps, 4817.60 kb/s encoded 10104 frames, 31.79 fps, 4818.23 kb/s [Type: 64-Bit, Pipe Buffer Size: 1 MByte] encoded 10104 frames, 32.07 fps, 4818.78 kb/s encoded 10104 frames, 31.77 fps, 4818.48 kb/s encoded 10104 frames, 32.19 fps, 4818.60 kb/s [Type: 64-Bit, Pipe Buffer Size: 2 MByte] encoded 10104 frames, 32.69 fps, 4818.92 kb/s encoded 10104 frames, 32.39 fps, 4819.50 kb/s encoded 10104 frames, 32.92 fps, 4818.74 kb/s [Type: 64-Bit, Pipe Buffer Size: 4 MByte] encoded 10104 frames, 33.03 fps, 4817.76 kb/s encoded 10104 frames, 32.77 fps, 4820.07 kb/s encoded 10104 frames, 33.23 fps, 4820.41 kb/s [Type: 64-Bit, Pipe Buffer Size: 8 MByte] encoded 10104 frames, 33.20 fps, 4818.04 kb/s encoded 10104 frames, 33.01 fps, 4818.66 kb/s encoded 10104 frames, 32.49 fps, 4817.34 kb/s x264 0.72.1235M 448b138 built on Aug 27 2009, gcc: 4.3.4 20090220 (prerelease) (x64.generic.Komisar) Revision: 1235 Last edited by Teddl; 29th August 2009 at 11:01. |
3rd September 2009, 08:00 | #112 | Link | |
http://x264.nl/ ? |
3rd September 2009, 12:33 | #113 | Link | |
Software Developer
Updated x264 to r1247 (JEEB's builds). Download link in first post updated!
(Just be sure to save the 32-Bit build as "x264.exe" and the 64-Bit build as "x264_x64.exe" in the same folder as the "launcher.exe") 3-Pass is a placebo
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 3rd September 2009 at 14:04. |
6th September 2009, 22:43 | #114 | Link |
Software Developer
Updated x264 to r1251 (JEEB's builds). Download link in first post updated!
I also fixed job control on Vista/Win7. This should make "abort" work on those OS. Before only 'pipebuf.exe' was terminated, but not 'x264.exe' and 'avs2yuv.exe'
6th September 2009, 23:08 | #115 | Link | |
6th September 2009, 23:12 | #116 | Link | |
Software Developer
The one and only thing that could effect the audio sync would be the framerate. My GUI will obtain the framerate from Avisynth and forward it to x264. And that seems to work properly for me...
6th September 2009, 23:17 | #117 | Link | |
6th September 2009, 23:34 | #118 | Link | |
Software Developer
Why not use MKVToolnix ???
So unless there is any indication that something is wrong with the video part, your muxing problem doesn't belong to this thread...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 7th September 2009 at 00:18. |
9th September 2009, 10:53 | #120 | Link |
Software Developer
Updated x264 r1251 with latest JEEB builds, including the fixed HRD patch. Download link in first post updated!
