18th April 2011, 22:33 | #7142 | Link | |
When I install 270.61 driver, presentation glitch appears with madvr 0.57 without the hack (with 196.21 I don't have glitches even with madvr 0.51 until 0.57). With hack, like you said, I don't have glitch but problem with sound. I decide to make backup before installing 270.61 and I tested 196.21,266.58 and 270.61 drivers. Now with ou without hack, I don't have glitches and I don't have any problem with sound. I don't know why the comportment of madvr or my computer is erratic tonight. It's not comprehensible I will test tomorrow to see if there is still problem or not with vista. |
18th April 2011, 22:38 | #7143 | Link | |
18th April 2011, 23:09 | #7145 | Link | ||
Exactly watching TV Episodes is the reason I think restoring the previous refresh rate is a bad idea, because this means a lot of switching/flashing between episodes. madVR can't know that there will be a new episode/file with the same frame rate starting just after the previous one. The perfect solution should be something like this: if there is no new movie starting in the next 5-10 seconds - switch to original refresh rate ... but I guess this is more a function of the player not the renderer.
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V Win 10 64bit 1803 + Zoom Player v14 |
18th April 2011, 23:25 | #7147 | Link |
IMHO the best option would be to memorize the state when it was closed. I only change some of the settings, so see all or none is always a pain for me, because I would still need to close or open some. I prefer the settings dialog to show like it was when closed.
18th April 2011, 23:31 | #7149 | Link |
Is it supposed to go back to the original res when the video stops? Cause it's not in my case. Other than that minor annoyance it's rocking nicely. A few minutes of my wife's Glee discs were in sync which is great on that machine. This is awesome!
18th April 2011, 23:48 | #7151 | Link |
*LOVE* the auto-resolution switcher. Would it be possible to add in a tiny bit of intelligence to the auto-switcher to switch to refresh rates that make sense for us projector owners? e.g. I want to keep my resolution at 1080 because without lens memory switching to 720 doesn't make sense. So if a 720p50 source is detected and 1080p50 is in the list it will switch to 1080p50. It makes more sense to be at 1080p50 then staying at 1080p23 when watching 720p50 source
Keep up the great work, madshi!!!! |
18th April 2011, 23:48 | #7152 | Link | |
I've configured madVR to use the following switches 1080p50, 1080p59, 1080p60 but madVR simply refuses to switch to 1080p59 even though the video I start is a 59.940 1080i recording and I do have 59Hz as a selection in Windows / NV Control Pannel / UltraMon. It either switches to 1080p60 or to 1080p50 if I leave only 1080p50, 1080p59 in the settings. here is a log showing the problem http://www.mediafire.com/?u5a3maf9hk6oq52 it happens on both my monitors. Other framerates (23.976 and 50) work fine. I'll continue testing and report after if I find more problems. Otherwise madshi, a lot The perfect would be to remember it's previous state but I guess that's an overkill at the moment. For the moment I'd prefer the options tree to be expanded than to be contracted by default
19th April 2011, 00:01 | #7155 | Link |
Kid for Today
Your wish is my command. In all 3 logs, the refresh rate switches froze PotP
19th April 2011, 00:24 | #7158 | Link |
madshi,
I've just stumbled on a problem with v0.57. I know that you can't see a lot from the log file when there is crash (ZoomPlayer simply vanishes) but I just thought it's better to let you know that v0.57 crashes while v0.56 plays just fine the same file with the same config. Here are the logs from the two different versions http://www.mediafire.com/?3lk8awytknha1a7
19th April 2011, 01:53 | #7159 | Link |
The automatic resolution changing (even in it's limited form) works pretty darned good. Although setting "48p" (1920x1200p48 to be exact) (for 23.976 fps 4:3 videos) in the filename doesn't work, as 1920x1200p48 was "valid". No biggie though.
Would be cool on a future version if there would be changes per aspect ratio, or invidiual customly set resolution changes (would change to a certain resolution per some specification, or combination of specifications is what i mean, similar to ffdshow's resizing) maybe. Also, maybe have an option to change to a customly defined resolution on close, as in some cases keeping the resolution is nice, other's slightly inconvienent. Now i'm sure you have ideas similar to this planned (and other ppl have mentioned similar things as well), but just thought i'd throw in my 2 cents Also, as for glitches and whatnot. I didn't really test anything, but feel any glitches i may see (with the refresh rate sycned the the fps of the video anyways, which are quite minimal then, if not eliminated on some videos) are due to my system in some way, and nothing with madvr, so I don't think that i can help test any of these issues. Last edited by Hprd; 19th April 2011 at 02:08. |
19th April 2011, 02:05 | #7160 | Link |
One question and one comment:
1) What is the exact purpose of the automatic display changer? As per my understanding it changes the refresh rate of the display to match whatever settings the user has input? (e.g. Monitor has refresh rates of 24Hz & 60Hz, default is set to 60Hz. madVR is fed a 1080p24 video and madVR changes the default refresh rate to 24Hz for playback?) 2) I had some 720p files that would drop frames when resized to fullscreen and those don't anymore. I think it has to do with the frame rate detection change. Before they were detected as 25 fps now it shows as 29.976 which is the actual fps. Awesome work madshi! |
