Old 3rd April 2014, 11:50   #1  |  Link
Dlget
External subtitle not showing
Hi ,
I'm using these
MPC-BE 1.4.2 x86
madVR v0.87.9
LAVFilters v0.61.1
XySubFilter 3.1.0.546
I just updated MPC-BE, LAVfilter & madVR
After that i got this i'm unable to load external subtitle automatically.
I have to drag n drop subtitle file & which is handled by MPC's internal subtitle renderer.
But if subtitle is embedded [muxed inside mkv] then subtitle shows normally with xysubfilter.
i have disabled inbuild subtitle renderer & added xysubfilter to external filter inside MPC-BE & ticked prefer option for xysubfilter
So can u tell why xysubfilter is not taking that subtitle file if it's not inside video file???
I uploaded settings for lavfilter,xysubfilter,madVR & MPC-BE
Dlget is offline   Reply With Quote
Old 3rd April 2014, 18:40   #2  |  Link
cyberbeing
Broadband Junkie
Originally Posted by Dlget View Post
madVR v0.87.9
What has changed is that madVR versions starting with 0.87.5 expect XySubFilter to load itself into the graph, rather than being loaded by madVR.
Update to XySubFilter Beta2, run the Install_XySubFilter.bat as administrator and this problem should be resolved.
Old 3rd April 2014, 22:51   #3  |  Link
Dlget
Thanks for helping
It worked
mpc-be, subtitle, xysubfilter
