Old 9th November 2019, 10:37   #1201  |  Link
TomSmith
Originally Posted by Patman View Post
@ TomSmith
i've updated my system now and everything works like a charme. No problems with ram or other hardware issues.
@ all
updated some of my builds
Hi Patman!
My board just got an bios update. It seems that my problem was fixed... at least I haven't seen this errors...
Best wishes!
Tom
TomSmith is offline
Old 9th November 2019, 12:30   #1202  |  Link
Bahamuth
Told you...
I'm making things easy then... I'll just spawn two Staxrip instances both having other videos to encode. This should be a workaround for utilising my CPU to the fullest.
Bahamuth is offline
Old 9th November 2019, 13:00   #1203  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Some people prefer to build two houses simultaneously and some single house but two times faster...
Atak_Snajpera is offline
Old 9th November 2019, 14:07   #1204  |  Link
Bahamuth
Well I'm trying now for many days to make this work. It does not, and I lost these days encoding things I want to encode. So when there is no solution, one has to use a workaround.
Bahamuth is offline
Old 9th November 2019, 15:11   #1205  |  Link
stax76
stax76's Avatar
The way I see it is if the tools are too slow then it's not the fault of staxrip. I'm not sure how difficult it would be to add this feature, the processing routine supports multiple processes so it might not be very difficult.
stax76 is offline
Old 9th November 2019, 15:16   #1206  |  Link
Bahamuth
Could it be, that the icons folder is missing sometimes in the rar file? In the current version it's gone again. And without a proper icon, if you minimize the window to the tray, it's gone. (can use Process Explorer to get the window to front again).
Bahamuth is offline
Old 9th November 2019, 19:11   #1207  |  Link
Bahamuth
I can't change any values using the scroll wheel in fields like quality. Intended?
Bahamuth is offline
Old 9th November 2019, 20:02   #1208  |  Link
stax76
stax76's Avatar
I've downloaded it and the icons folder was there, maybe there is still a bug with the tray icon.
It should work as long as you hover over the control, I wrote this control but the wheel of the default numeric up down control behaves exactly the same as mine.
stax76 is offline
Old 9th November 2019, 23:36   #1209  |  Link
Bahamuth
That... I don't understand. I download https://github.com/Revan654/staxrip/....0.2.4.x64.rar and when I look into the Apps subfolder, I see this:
No Icons subfolder.
check, so I should just keep my mouse over there
Bahamuth is offline
Old 10th November 2019, 02:42   #1210  |  Link
stax76
stax76's Avatar
First post is outdated...
https://github.com/staxrip/staxrip
stax76 is offline
Old 10th November 2019, 13:53   #1211  |  Link
lasa
which avs source filter should i use for bluray to mkv
lasa is offline
Old 10th November 2019, 14:43   #1212  |  Link
jlw_4049
Ffvidesource
Sent from my SM-G965U1 using Tapatalk
jlw_4049 is offline
Old 12th November 2019, 18:38   #1213  |  Link
Forteen88
Herr
I think that LSMASHSource is great for AVC Blu-rays.
Forteen88 is offline
Old 13th November 2019, 10:24   #1214  |  Link
lasa
LSMASHSource or Ffvidesource?
lasa is offline
Old 13th November 2019, 12:02   #1215  |  Link
jlw_4049
Both will do what you need to do
jlw_4049 is offline
Old 13th November 2019, 14:25   #1216  |  Link
stax76
stax76's Avatar
@lasa
There are three popular source plugin for AviSynth and VapourSynth:
ffms2
FFVideoSource
L-Smash-Works
LSMASHVideoSource (*.mp4 file type/extension only, no indexing needed)
LWLibavVideoSource (any video file type/extension)
Both support hardware decoding.
DGDecNV
DGDecode
For dvb it's probably still better than ffms2 and L-Smash-Works.
stax76 is offline
Old 16th November 2019, 16:47   #1217  |  Link
Patman
Patman's Avatar
Hi all, i've updated my builds. There were problems with ffmpeg if you wanted to encode VP9/AV1. If you want to know the estimated file size when using x265-encoder, download my custom build of x265. Thanks for the info Link
L-Smash-Works has been updated Link
Tools for StaxRip | x264 - x265
Patman is offline
Old 16th November 2019, 21:37   #1218  |  Link
NikosD
@patmam
@stax76
Latest QSVEncC v3.25 is out with minor performance gain and among other things, rigaya removed VC-1 from HW decoding.
According to him, he did everything he could but didn't manage to make it work as it used to.
https://onedrive.live.com/?authkey=%...DD4375AC8933C6
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
NikosD is offline
Old 16th November 2019, 21:54   #1219  |  Link
Patman
Patman's Avatar
Hi NikosD,
thanks for the info. I read the changelog on github.
Gesendet von meinem HMA-L09 mit Tapatalk
Patman is offline
Old 17th November 2019, 12:28   #1220  |  Link
Forteen88
Herr
Originally Posted by NikosD View Post
@patmam
It's Maaaaan!
aac, hdr, hevc, nvenc, staxrip, x264, x265
