21st January 2013, 17:15 | #17101 | Link |
Exactly. Note that most (all?) TVs and projectors don't actually use 24 Hz for 24p input sources because of the flicker it causes, so they'll typically play 24p material at 72 or 96 Hz (or higher), presenting each frame 3 or 4 times (or more).
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
21st January 2013, 17:18 | #17102 | Link | |
21st January 2013, 20:51 | #17103 | Link | |
Attached you'll find the madvr-settings I used and the log-file as well. |
21st January 2013, 22:10 | #17105 | Link | |
On the other hand, if I leave my video card at 60Hz the movie still plays back fairly smoothly (I'm usually using ReClock), though there may be some judder. It sounds like even if I set my card to use 23Hz, and the TV reports 1080/24p, the TV is actually using a faster refresh rate... at least it may be. It is labeled as a 120Hz TV, so could this be an instance when the 120Hz - even if it's just LG's TruMotion interpolation - is kicking in? Unlike older models, there is no way to enable or disable TruMotion on the 47LS4500. So if it's automated, this sounds like a case where it would/should be used. CTRL+J OSD lists the display as 23.97550/1/2Hz in FSE (some slight deviation; ReClock is in use), but is this really related to the frequency used by the TV? Sorry if this is OT. I'll just add that using software decoding in LAV (Core i5-3350P @ 3.10GHz Ivy Bridge) I run Jinc3 w/AR for chroma and image upscaling without a hitch for all types of videos. For example, with the Radeon set at 23Hz, my 720x336 23.976 fps progressive (DVR dump to MPEG-2, then XviD-encoded SD) scaled to 1920x1080/24p, render times are Avg. 14.13ms. Admittedly, this low-res, poorly sourced file exhibits a lot of aliasing on objects in motion at this scaling level, but oh well. It was an exercise in copying from a cable co. DVR via S-Vid Out. The MPEG-2 capture was just too damn big to save. LOVE madVR and the LAV suite :-) |
21st January 2013, 22:16 | #17106 | Link | |
22nd January 2013, 01:41 | #17108 | Link |
Kid for Today
Oops, I guess I forgot to say that I still could use a tag for AR as PotP is really pointless for this kind of stuff as it only allows 4:3 and 16/9, duh
And its pan&scan feature is great, but not accurate at all as most of the time it will shrink or stretch the picture by as much as 12 pixels(just like MPC).......a far cry from ffdshow with its 0.01 AR accuracy So yeah, AR tags and making the "windowed/exclusive" OSD messages disappear is all I crave at this point in mVR. Hopefully we'll be reaching 1.0 soon enough so I can ask for these again ^^ And going back to the HD gamut conspiracy theory, I now have that CRT perfectly calibrated and all the latest HD movies I tried looked grossly undersaturated in SMPTE-C....I also couldn't see any diff between EBU and REC.709 for european HD movies, which kinda makes sense. so indeed what may have appeared to be true half a decade earlier might very well not be anymore. I'll keep rolling them but it's rather clear that I'll have to make a new PotP automatic profile for HD@24p=REC.709 Last edited by leeperry; 22nd January 2013 at 04:31. |
22nd January 2013, 10:49 | #17110 | Link | |
I have a problem with Samsung LED TV c5000 series (2010 model, 60Hz), video playback is of low framrate jerky using 1080p24 display mode changer in madVR (with ReClock). The TV reports 1920x1080@24Hz and the playback seems to really be at that refresh rate. Now I wonder what I should do if I play at 60Hz there are judder (3:2 pulldown thing) while at native 23/24Hz it's too jerky. What are you guys using? Last edited by pururin; 22nd January 2013 at 10:52. |
22nd January 2013, 11:25 | #17111 | Link |
You don't seem to be understanding. If, for example, you get a 24 fps clip and play each frame 4 times at a refresh rate of 96 Hz, it'll come out looking the same (but the display will exhibit less flicker than if it were refreshing at 24 Hz). The "jerkiness" of 24p/25p material is inherent - there is simply not enough frames in each second to produce smooth video, and this is the reason for the "film look" of this type of content. If your TV can't do more than 60 Hz then it most likely uses 48 Hz for 24p video (even though it says "24 Hz" or "24p" because that's what the input signal is).
You seem to be confusing this with motion interpolation, which most TVs have the option for nowadays (and often it's enabled by default). This is where, instead of simply repeating frames, the display will create new frames at time points in between the existing ones. This will "smooth out" the video and make it look more realistic and less jerky, whilst removing the "film look".
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 Last edited by DragonQ; 22nd January 2013 at 11:30. |
22nd January 2013, 11:54 | #17112 | Link |
My 2 cents on that, I've had times where motion interpolation appears more jerky, perhaps from it appearing so smooth for the most part until it gets to a particular jerky part in a scene which is less obvious with it disabled.. or perhaps it's a quirk of the algorithm, I'm not sure. Whatever it is for that reason I usually prefer it to be disabled.
22nd January 2013, 12:00 | #17113 | Link | |
Why would you want to use the ffdshow DXVA decoder? I guess I can put it on my list of things to check, but I don't think many people are using that decoder today, considering the LAV Video Decoder should offer the same features and is actively developed. In any case, this will be low priority for me, unless there are several users who're still using ffdshow DXVA for some reason and suffer from the same problem, too. |
22nd January 2013, 13:47 | #17114 | Link | |
E.x. The Dark Knight Rises looks completely oversaturated and unfamiliar with REC.709 to a point where it gets annoying fast. Last edited by iSunrise; 22nd January 2013 at 13:55. |
22nd January 2013, 15:04 | #17115 | Link |
Kid for Today
Oh indeed, in TDKR flesh tones look terribly greenish in REC.709.....oh well, I'll keep rolling the darn gamuts then, luckily I can do it in two mouse clicks now and it works in pause mode too
23rd January 2013, 18:21 | #17120 | Link | |
thx, for your help!!! |
