14th August 2011, 01:47 | #4641 | Link |
Yea, I see what you're saying now. I'm not sure if Nev will agree or not. I don't know what the spec says about that case. But, the behavior you've outlined (that there should be no subtitle selected) is most likely the correct one. So this should probably at least be an option somehow. For me, I'm with Nev...I generally don't use subs unless they're forced unless I'm watching a foreign martial arts movie. But in any case, I agree there's room for improvement. Nev is right that any default settings he makes aren't likely to satisfy everyone, but, I do see the need that you guys are asking for.
14th August 2011, 03:18 | #4642 | Link | |
Firefox User
14th August 2011, 03:44 | #4643 | Link |
Firefox User
And for clips that change its resolution during playback (or resolution probed by avcodec is different from the metadata), LAV Video did cause a ErrorAbort() and pausing the graph (GraphEditPlus can show eventlog)
Sample: http://roy.orz.hm/samples/rv30_chroma_drift.rm (It encoded by RealProducer Plus 8.51 and cropped with RealMedia Editor bundled with RealProducer) Eventlog from MPC-HC codecs: Code:
10:36:19.414: VMRRenderDeviceSet (83), param1=2 (0x2), param2=0 (0x0) 10:36:19.414: VideoSizeChanged (10), param1=31458144 (0x1E00360), param2=0 (0x0) 10:36:30.695: ClockChanged (13), param1=0 (0x0), param2=0 (0x0) 10:36:30.711: Paused (14), param1=0 (0x0), param2=0 (0x0) 10:36:38.117: Complete (1), param1=0 (0x0), param2=0 (0x0) Code:
10:36:56.367: VMRRenderDeviceSet (83), param1=2 (0x2), param2=0 (0x0) 10:36:56.367: VideoSizeChanged (10), param1=31458144 (0x1E00360), param2=0 (0x0) 10:37:08.508: ClockChanged (13), param1=0 (0x0), param2=0 (0x0) 10:37:08.742: ErrorAbort (3), param1=-2147220950 (0xFFFFFFFF8004022A), param2=0 (0x0) 10:37:08.742: VMRRenderDeviceSet (83), param1=2 (0x2), param2=0 (0x0) 10:37:08.742: VideoSizeChanged (10), param1=31458144 (0x1E00360), param2=0 (0x0) 10:37:08.742: VideoSizeChanged (10), param1=31458144 (0x1E00360), param2=0 (0x0) 10:37:22.570: Paused (14), param1=0 (0x0), param2=0 (0x0) // <--- I hit stop button and then click play button again to start the graph 10:37:30.023: Complete (1), param1=0 (0x0), param2=0 (0x0) |
14th August 2011, 09:03 | #4645 | Link | |
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 14th August 2011 at 09:08. |
14th August 2011, 09:27 | #4646 | Link | |
AV heretic
14th August 2011, 10:40 | #4647 | Link | |
14th August 2011, 10:51 | #4648 | Link | |
14th August 2011, 11:03 | #4650 | Link |
Sure, same result as in GraphStudio.
12:02:43.007: VMRRenderDeviceSet (83), param1=2 (0x2), param2=0 (0x0) 12:02:43.008: VideoSizeChanged (10), param1=31458144 (0x1E00360), param2=0 (0x0) 12:03:04.163: ClockChanged (13), param1=0 (0x0), param2=0 (0x0) 12:03:04.240: VMRRenderDeviceSet (83), param1=2 (0x2), param2=0 (0x0) 12:03:04.240: VideoSizeChanged (10), param1=31458144 (0x1E00360), param2=0 (0x0) 12:03:04.240: VideoSizeChanged (10), param1=31458144 (0x1E00360), param2=0 (0x0) 12:03:04.244: Paused (14), param1=0 (0x0), param2=0 (0x0) 12:03:11.783: Complete (1), param1=0 (0x0), param2=0 (0x0)
14th August 2011, 11:06 | #4651 | Link |
guys,
which version of GraphStudio do you use? The latest one that I've found is 0.3.2.0 - Beta from 14/June/2009. Is there anything newer?
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V Win 10 64bit 1803 + Zoom Player v14 |
14th August 2011, 11:15 | #4652 | Link | |
Firefox User
I can't test for Vista/7 as I don't have it now. |
14th August 2011, 11:33 | #4653 | Link | |
My major guess would be your Videoinfoheader change maybe ? - Support for creating thumbnails in explorer/WMP Yep .avi files (@ least with the default AVI Spliiter + Lav Video) are also playing crazy now with VMR9 Renderless Video: Xvid 1920x1080 23.98fps = Black Screen also with Lav Splitter a Black Screen changing to VMR7 Renderless works also here (turning of MPC-HCs Video Frame settings has also no effect (Normal Size) It seem every .avi too broke with VMR9 Renderless now and Lav Video (symptoms perfectly fit to a VideoInfoHeader code change) Working with Lav Video + VMR9 Renderless .mp4 .mkv .3gp .mov .m2ts .ts .wmv .m2v .vob .mpg Black Screen with Lav Video + VMR9 Renderless (working with other Renderer) .avi .flv .bik .webm
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 14th August 2011 at 12:38. |
14th August 2011, 11:53 | #4654 | Link |
14th August 2011, 12:42 | #4655 | Link | |
What the hell after playing now 100 of times different clips it suddenly works with VMR9 Renderless (though i also changed some settings here and their but mostly only chain related Lav Video playback formats ect)
OK just to make sure im not crazy i restarted and tried again (with all those chain related changes) and again black screen on VMR9 Renderless (puhh) then i unregistered the RC and registered the RC2 and tried again no Black Screen anymore (so it seems fixed i try some files more to be absolute sure) But could you please say what it was i mean it suddenly started to work (like i forced it to brake) ? (scary) PS: Wow MjpegB works also 4:2:2 Studio Profile without any Render setting problems (just works and it gets correct Deinterlaced before only Mainconcept did this) http://forum.doom9.org/showpost.php?...ostcount=17995 Nev please just the Lav Cuvid to Lav Video fallback for 4:2:2 Mpeg-2 now (adios Mainconcept and all its DXVA issues with lav splitter)
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 14th August 2011 at 13:42. |
14th August 2011, 13:42 | #4656 | Link | ||
I see the tracker states: Quote:
Thanks for this, & all the great work you do. |
14th August 2011, 17:11 | #4657 | Link |
Nev, I don't have time to pretty up the descriptions on the installer script. Real work is getting in the way this week and I won't have time to work on it. I opened an issue on the tracker (issue 62...defect, sigh...not what I meant to select for an issue type) and attached the script I have with a TODO list of what might be improved. The script works and creates a usable installer that handles LAV Video and allows you to select the defaults in the installer. I hope this helps!
14th August 2011, 17:50 | #4658 | Link |
Thanks, i'll have a look soon.
14th August 2011, 17:57 | #4659 | Link |
NP. Glad I could help out. It's nothing anyone with a text editor couldn't have done, but, I'm hoping it saves you some editing time at least.
http://www.mediafire.com/file/7y3uxo...rs-0.32-RC.exe For those that want the latest with an installer...
14th August 2011, 18:21 | #4660 | Link |
4:2:0 hater
More observations regarding subtitles, this time with Blu-ray sources: with default splitter settings, playing a m2ts file directly from the disc (or using the matching playlist) results in the first subtitle track being selected and displayed, which is usually the full english track. I guess this is the same situation as with MKVs, no forced tracks, no default tracks, LAVS picks the first. Needless to say that seeing full subtitles by default is not pleasant, nor logical. The "only forced subs" and "no subtitles" options are not a solution, since they ignore default flags, messing up everything that has them.
My proposition is still the same: if none of the tracks are preferred/forced/default, don't pick any. |
