12th November 2009, 17:52 | #201 | Link | |
Swallowed in the Sea
use either my last build from this month (20091113) or oggz-merge from the oggztools package + kateenc. Same link as above... Last edited by Kurtnoise; 13th November 2009 at 09:14. |
13th November 2009, 14:53 | #202 | Link |
Thanks Kurtnoise!
The last ffmpeg2theora (20091113) works very well with avs script and kate subtitle encode. There is just a concern, the kate lib version built in is just 0.3.1. Would it be possible to change to kate lib 0.3.6(last official version)? Thanks. |
13th November 2009, 16:32 | #204 | Link | ||
btw, I don't know why you're so interesting by the srt support in libkate. The rendering is poor to me (italic not supported by example)... Quote:
13th November 2009, 21:42 | #205 | Link |
Thank you very much.
Agree with you, the kate can not support <i>, <b> tags right now. But Kate is in its early age, let's see its progress. And Kate is the only subtitle format in new OGV format. I am not sure OGV support srt or not even though ogm supports. |
17th November 2009, 16:24 | #206 | Link |
new edition of kate has just released.
It fixes a lot of issues and add support of SRT style(that means italic, bold style can be rendered correctly.). 0.3.7 - 15 november 2009 new encoding functions to specify timing in granule rate units fix SRT timing precision problems new -M option to kateenc to allow HTML-like markup in SRT files allow the last event in an SRT file to not be followed by an empty line |
26th January 2010, 22:19 | #211 | Link |
Actually, since yesterday, a new development branch was created for the eventual 1.2 release... Check it out https://trac.xiph.org/timeline
And there is already some nice improvements. |
6th February 2010, 02:08 | #213 | Link |
I did a small test of ffmpeg2theora 0.26 and x264 r1400. I only two sources and the default settings on both encoders, with x264 encoded at the same and half the bitrate the Theora encoder used. Exact settings, links to source files, PSNR, SSIM and comparison pics can be found in the download. I can upload encoded samples should anyone be interested.
Theora still needs a lot of work. Even at half the bitrate x264 produces clearly better results. I'd be interested why the background in the score area of the Touhou video is so blurry in Theora. Since it is completely static it shouldn't be so low quality. |
6th February 2010, 04:38 | #214 | Link | |
x264 developer
By the way, you should test the latest Theora SVN; they added adaptive lambda (rough equivalent of x264's AQ), which should help quality in flat areas a lot.
Follow x264 development progress | akupenguin quotes | x264 git status ffmpeg and x264-related consulting/coding contracts | Doom10 Last edited by Dark Shikari; 6th February 2010 at 04:42. |
7th February 2010, 19:52 | #216 | Link |
@nurbs
You can try the ffmpeg2theora nightly builds http://firefogg.org/nightly/ last update was today so im guessing they're compiled using latest build |
7th February 2010, 23:32 | #217 | Link | |
FFmpeg fan
D:\Manga\Maian>ffmpeg2theora.exe ffmpeg2theora 0.26+svn16879M - Xiph.Org libtheora 1.1 20090822 (Thusnelda) Yours, Hellfred |
8th February 2010, 05:11 | #220 | Link | |
Unavailable
Astrophizz wrote:
http://svn.xiph.org/experimental/der...a-ptalarbvorm/ |
