7th October 2009, 13:22 | #10001 | Link | |
the hedgehog
Athlonx2@2,9Ghz,2G DDRAM2@800Mhz,WinXPSP3 x86,GF8600GTS-256M,Nvidiadrivers 295.73 latest MPC-HC (MVS2010 SP1, GCC 4.7.1) VMR9renderless+VMR9MixerMode+YUVMixing,VSync+AccurateVSync,all GPUflushes on |
7th October 2009, 14:03 | #10002 | Link |
Based on that useful info I suspect that the bug was added in revision 1236.
MPC-HC 2.2.1 |
7th October 2009, 21:42 | #10003 | Link | ||
http://www.mediafire.com/download.php?ydmdrcnvy9n
Tired of tearing? Try this Media Player Classic mod : http://mpc-hc.sourceforge.net |
7th October 2009, 21:47 | #10004 | Link | |
7th October 2009, 21:53 | #10005 | Link |
Bug.
When watching in MPC -HC an avisynth script with dgdecode source, the process stay even when closing player. I have to close it manually (multi instances) as it is making troubles when turning off windows. Tested 1290 build. EDIT: Script have to be paused (once is enough) during playback. Last edited by littleD; 8th October 2009 at 08:19. |
8th October 2009, 18:11 | #10008 | Link |
Im having a problem.
After i reinstalled k-lite with latest MPC-HC i cant make the default decoder for h264 mpcvideodecoder. Using windows 7 rtm. Tryed the windows 7 tweak tools - doesnt detect the mpc codec at all. Tryed chaning the CLSID trough the registry. Still doesnt help. Player still uses the MS DVT-DVD decoder. When i enabled ffdshow for h264 it works fine EDIT: Now i have seen that when i watch standard 720p tv show it uses mpcdecoder But when i try to play transformers 2 prestige it uses the MS decoder Any idea why Last edited by shiloto; 8th October 2009 at 18:17. |
8th October 2009, 19:08 | #10009 | Link |
That file probably contains a H.264 stream that is not compatible with the DXVA decoder of MPC-HC.
MPC-HC 2.2.1 |
8th October 2009, 20:20 | #10010 | Link |
Media Control author
MPC-HC audio renderer WASAPI
here is a patch for MPC-HC that brings WASAPI support (exclusive mode) on the MPC Audio renderer Here is a sample binary file (.ax) I forced it to WASAPI exclusive mode with the useWASAPI bool. All the UI configuration needs to be made : WASAPI vs directsound, and select which device to use for WASAPI and fo directsound modes |
8th October 2009, 23:19 | #10011 | Link | |
However, I've updated yours to register as an audio renderer so is now selectable through MPC's options page directly. However, I had to comment out the new KSDATAFORMATs as I couldn't get it to compile with them in, I have the latest W7 SDK (at least, I think I do ) I've tested it with AC3 and DTS and my amp shows the correct logos for both, but I can't test HD audio. Can anyone try my new ax file and report back on HD please? Get the new .ax file here Thanks |
9th October 2009, 01:10 | #10012 | Link | |
http://forum.doom9.org/showthread.ph...46#post1332746 _ _ _ _ _ |
9th October 2009, 08:06 | #10013 | Link | |
I would like to add some debug traces |
9th October 2009, 08:52 | #10014 | Link | ||
9th October 2009, 11:00 | #10017 | Link | |
Not sure why I can't compile with the KSDATAFORMAT parts. I suspect that's why mine forces WM decoders into the path. I will say tho, using the internal MPC-HC AC3 and DTS decoders I do get sound from my amp (Denon 2805) with my build. |
9th October 2009, 11:50 | #10018 | Link | |
Edit: Sorry for my question, I just find out which setting was making it that way and corrected it (Video Frame==>touch window from inside), thanks. Last edited by boyumeow; 9th October 2009 at 12:02. |
9th October 2009, 16:15 | #10019 | Link | |
9th October 2009, 18:17 | #10020 | Link |
Hi, sorry for hijacking thread, but as there is alot of discussion here and in the ffdshow thread around side versus rear channels.
My question is, for a 5.1 speaker configuration, with a 7.1 sound card, in windows vista or windows 7 even, what is the "correct" setup to choose in both audio card settings, and physical outputs. Should I be using physical rear, or physical side outputs. My XONAR gives audio from both rear and sides, in whatever physical config I use, even in 5.1 config setting in its control panel because there is no way to stop this card upmixing unfortunately. It tries to get too smart so its hard to figure out whether I should be using side or rear outputs. |
