27th June 2009, 15:32 | #4401 | Link |
NY Frame of Mind
The "bold" above got me thinking (dangerous). I looked at the config tab again and changed "automated-2pass" to "2pass-2nd pass". Deleted the first 2 jobs and enqueued the new job (ie the old job2) and Voila, it runs the encode! Turned out to be a simple solution, after all. Again, thank you for taking the time to address the issue and have a great weekend.
"Talk to me Goose" |
29th June 2009, 21:41 | #4402 | Link | |
NY Frame of Mind
---[NoImage] x264 [info]: slice I:8228 Avg QP:15.07 size: 96212 ---[NoImage] x264 [info]: slice P:67843 Avg QP:16.18 size: 48725 ---[NoImage] x264 [info]: slice B:83215 Avg QP:17.21 size: 27918
29th June 2009, 22:39 | #4403 | Link |
Straight to video
One-click x264 jobs do not work for me. When I enqueue and run a one-click x264 job, MeGUI spits out:
--[Error] An error occurred: x264 [error]: can't open `' Code:
<UseQPFile>true</UseQPFile> <QPFile /> Code:
<UseQPFile>false</UseQPFile> <QPFile>.qp</QPFile> Tested on a Clean XP SP3 VMware image + Windows Security updates + .NET 2.0 SP1 + DirectX 9.0 March 2009 redist + MeGUI 0.3.1.1046 fully updated Can anyone reproduce?
. Last edited by kumi; 29th June 2009 at 22:53. |
30th June 2009, 02:17 | #4404 | Link | |
Mr. Sandman
@kumi: ill have a look at it as soon as i find some time. keep in mind im actually really busy 'till august. be sure to post that in the megui bugtracker on sourceforge, so i wont forget it...
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 30th June 2009 at 02:20. |
30th June 2009, 03:33 | #4406 | Link | |
Straight to video
If I use the built-in updater and update all MeGUI components _except_ core, is that safe?
. Last edited by kumi; 30th June 2009 at 03:40. |
30th June 2009, 07:32 | #4407 | Link |
mp4box 4gb file limit?
Is there a limit on how big the final file can be? I am using meGui to mix 4 files into mp4 and it keeps crashing in the mp4box module on ntdll.dll
Log Name: Application Source: Application Error Date: 6/30/2009 1:25:40 AM Event ID: 1000 Task Category: (100) Level: Error Keywords: Classic User: N/A Computer: ****** Description: Faulting application MP4Box_x64.exe, version 0.0.0.0, time stamp 0x49cd37cd, faulting module ntdll.dll, version 6.0.6002.18005, time stamp 0x49e0421d, exception code 0xc0000374, fault offset 0x00000000000aef37, process id 0x18a8, application start time 0x01c9f94ade2b4e70. Here are the files that I tried to put in there: Complete name : movie.h264 Format : AVC Format/Info : Advanced Video Codec File size : 3.79 GiB Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Width : 704 pixels Height : 304 pixels Display aspect ratio : 2.35 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Writing library : x264 core 67 r1173M f6d3166 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=12 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=12 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=crf / crf=8.0 / qcomp=0.50 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=24000 / vbv_bufsize=24000 / ip_ratio=1.10 / pb_ratio=1.10 / aq=1:1.00 audio: Complete name : audio.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 348 MiB Duration : 2h 8mn Overall bit rate : 379 Kbps Encoded date : UTC 2009-06-29 12:46:39 Tagged date : UTC 2009-06-29 12:57:46 Writing application : Nero AAC codec / 1.3.3.0 cdec : ndaudio 1.3.3.0 / -cbr 384000 -lc Audio ID : 1 Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Codec ID : 40 Duration : 2h 8mn Bit rate mode : Variable Bit rate : 384 Kbps Maximum bit rate : 504 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Rear: L R, LFE Sampling rate : 48.0 KHz Resolution : 16 bits Stream size : 346 MiB (100%) Encoded date : UTC 2009-06-29 12:46:39 Tagged date : UTC 2009-06-29 12:57:46 subtitles: subtitle.srt 122,880 bytes chapters chapters.txt 4,096 bytes I tried on both XPSP3 and Vista 64 SP2
~~~~~~~~~~~~~~~~~~~~~~~~ Intel i7 920 ASUS P6T Deluxe V2 Mboard 6GB DDR-3 Crucial XMS RAM Visiontek ATI 4850 Sound Blaster Audigy |
1st July 2009, 18:51 | #4409 | Link |
I would like to use MeGUI's audio cutter to cut some sound samples. Unfortunately, I don't know the proper way to create a cutlist for it. Is it just a sequence of times in a text file? And if so what format are they in and how are they arranged? Otherwise, how do I make a cutlist file? Please help.
2nd July 2009, 03:49 | #4410 | Link |
Unregistered User
Not sure if this is the right place to ask, but maybe some of you had similar issues.
In Windows 7 x64 I get "x264 has stopped working" with any video and any settings. Same video and settings work just fine in XP. Do I need to tweak something to get this working? Same problem with FFMPEG btw..
avi + m2t -> Vdub + DGIndex -> AE CS3 -> x264 -> Hell On Earth Woop, woop! That's the sound of the police! |
2nd July 2009, 08:49 | #4411 | Link |
I've a silly question for you folks.
My TV set supports only 720p and 1080i. PAL I've a bunch of 1080p Blu-ray material and I'd like to make AVCHD out of it. 1)Better using 1080i or 720p on my TV set? 2)Supposing 8000mbps is the perfect video bitrate for 1080p AVC-H264 encoding, what video bitrate would you recommend me for 720p? Thanks |
2nd July 2009, 10:01 | #4412 | Link | |
8000Kb/s is a low bitrate for 1920x1080 (Qf=0.16), at least 10000Kb/s (Qf=0.2), for average video material, is needed. The relation between 1080 and 720 bitrate is: (1920x1080)/(1280x720) = 2.25 then 10000Kb/s for 1080 is equivalent to 4500 Kb/s for 720
2nd July 2009, 14:33 | #4413 | Link |
Kill!
Hello all,
I have seem to run into a problem with MeGUI. I can't seem to get ANY of the encoder profiles for x264 or xvid to work with one click encoder.... as in I'll add the project to the queue list and click start, but it goes straight to skip in the status tab. I looked under the log tab and it said this: Error starting job Exception message: File exists and the user doesn't want to overwrite Stacktrace: at MeGUI.core.gui.JobWorker.startEncoding(TaggedJob job) Inner exception: null Any help would be great, thanks. Also, running Vista 64bit SP2 Last edited by Douchie; 2nd July 2009 at 14:39. |
2nd July 2009, 15:46 | #4414 | Link | |
Seems to me that this is your problem:
2nd July 2009, 17:09 | #4415 | Link |
nicaudio has been updated...
http://forum.doom9.org/showthread.ph...59#post1300059 can you include it in megui autoupdate? _ |
2nd July 2009, 17:45 | #4416 | Link |
Mr. Sandman
no, since the syntax has changed. megui code needs to be updated and i actually have no time to do that.
2nd July 2009, 18:53 | #4417 | Link |
Sharktooth, I'm using your x264_dp_ Standalone-PS3-Xbox360_Fast.xml profile.
This in order to encode my m2ts files to an AVCHD compatible standard. Yet I'd like to proceed even faster, without losing AVCHD compatibility. Any hint to a newbie? Thanks for your profiles Dan |
2nd July 2009, 19:19 | #4418 | Link |
First off the PS3/Xbox360 profile probably isn't really AVCHD compatible because of the high keyframe intervall and the missing --nal-hdr switch. Also AVCHD compatibility demands specific framesizes.
If you want faster encoding you can lower trellis, M.E. Range, M.E. Algorithm, the b-frame decision or subpixel refinement. You can turn off mixed references, lower the number of reference frames and lower the number of b-frames. |
2nd July 2009, 21:03 | #4419 | Link |
Mr. Sandman
well... what nurbs said plus ensure to use fast avisynth filters and no complex scripts.
2nd July 2009, 22:06 | #4420 | Link | |
Straight to video
When attempting an x264 One-Click job, do you see the same --[Error] An error occurred: x264 [error]: can't open `' error when you look in the Log tab? If yes, maybe it's the same bug, so post a quick comment in the sourceforge bug page confirming it.
. Last edited by kumi; 2nd July 2009 at 22:27. |
megui |
