Old 13th July 2016, 08:38   #2101  |  Link
ultim
AVS+ Dev
ultim's Avatar
Originally Posted by TurboPascal7 View Post
Does it even have to do anything with the intrinsics there? Looks completely unnecessary (like most of the C++ duhuhu).
Those shuffles around line 458 need a compile-time constant expression, which is why lines 443-444 were made a constexpr, I suppose. Removing the constexpr needs different templating, different intrinsics, or a condition added in the depths of those loops...
AviSynth+
ultim is offline
Old 13th July 2016, 08:42   #2102  |  Link
TurboPascal7
TurboPascal7's Avatar
Welp. Imo just copypaste the whole function into three different functions for different sizeof(T) and the problem goes away on its own. The code will be better too.
Me on GitHub | AviSynth+ - the (dead) future of AviSynth
TurboPascal7 is offline
Old 13th July 2016, 08:44   #2103  |  Link
ultim
AVS+ Dev
ultim's Avatar
Originally Posted by feisty2 View Post
Guess it's probably not a good idea to stay vs2010 or 2013, the latest c++ standard is c++14 so..
And vs2015 community is free anyways, what's the point of getting stuck at square one
Hopefully not for long.
VS2010-support is only for the public headers, not for compiling Avs+ core itself, so that you have a larger choice of compilers when writing your plugins.
VC2013 is the oldest supported compiler for compiling the core, and is only because of Wine, as apparently it still has some problems with the VC2015 runtimes. As soon as Wine gets with the times, I have no problem in dropping VC2013 support.
AviSynth+
ultim is offline
Old 13th July 2016, 12:20   #2104  |  Link
RazorBurn
Does someone here have links to Avisynth+MT r2005?
RazorBurn is offline
Old 13th July 2016, 13:08   #2105  |  Link
fAy01
http://avs-plus.net/builds
2043 is the latest.
fAy01 is offline
Old 13th July 2016, 20:10   #2106  |  Link
tormento
Acid fr0g
tormento's Avatar
2043 is the latest.
OMG... did not noticed it.
Changelog?
@turment on Telegram
tormento is offline
Old 13th July 2016, 23:42   #2107  |  Link
ryrynz
ryrynz's Avatar
Originally Posted by tormento View Post
Changelog?
https://github.com/AviSynth/AviSynthPlus/commits/MT
Will 1858 be the last unofficial build with legacy plugin compatibility?
ryrynz is offline
Old 14th July 2016, 01:26   #2108  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Just to be clear, the only plugins that are incompatible are those that used "env2" while ignoring the warning not to use it. Mostly to register their MT mode. Only a few plugins are doing that.
MysteryX is offline
Old 14th July 2016, 02:30   #2109  |  Link
RazorBurn
2043 is the latest.
Huge Thanks.. Bookmarked..!!
Old 14th July 2016, 03:44   #2110  |  Link
ryrynz
ryrynz's Avatar
If I install DirectShowSource.dll from link above to the latest build in my plugins folder I get a C++ exception when using avisynth+ffdshow.
I don't believe I'll use it anyway and have deleted it, but can someone quickly detail what features it provides?
ryrynz is offline
Old 14th July 2016, 04:21   #2111  |  Link
Reel.Deel
The latest AviSynth+ releases incorporate pinterf's changes, as well as some bugs fixes, and also introduced support for 16/32 bit YUV formats. High bit depth is still a work-in-progress but there's already a handful of internal filters that support the new formats. Ultim is working on a longstanding MT issue and also mentioned that some MT optimizations are coming.
There's nothing to worry about here, AviSynth+ still supports all the plugins it always has. The issue that MysteryX mentioned has been taken care of, the few affected plugins have been fixed and are working correctly. The latest nnedi3 (v0.9.4.22) is the only plugin currently not working but a fix is coming soon. Use an older version for the mean time.
Reel.Deel is offline
Old 14th July 2016, 05:13   #2112  |  Link
qyot27
qyot27's Avatar
DirectShowSource is a source filter of last resort, because DirectShow support of X or Y format is often unstable (and the filter isn't frame accurate in general). Pretty much every other source filter does a better job for whatever format(s) they're designed to open, leaving DSS for extreme edge cases.
It was the only general-purpose source filter prior to 2007, but ever since FFmpegSource (and especially since FFMS2 and LSMASHSource/LwLibavSource), its importance has shrunk to a minimum.
Because it was one of the few plugins that had used IScriptEnv2, newer versions can only be used by newer versions of the AviSynth+ core. Pairing DirectShowSource.dll from AviSynth+ r2022 or r2043 with the core AviSynth.dll from r1858 or prior will, of course, fail spectacularly.
qyot27 is offline
Old 18th July 2016, 20:46   #2113  |  Link
pinterf
Good evening.
New functions ported to 16 bit/float.
  • Info
  • ShowFrameNumber / ShowSMPTE / ShowTime
  • Subtitle
Info() additions:
  • display the name of the high bit-depth color spaces instead of Unknown color space.
  • display AVX CPU flag if detected.
pinterf is offline
Old 18th July 2016, 23:26   #2114  |  Link
LigH
LigH's Avatar
Indeed, a good evening!
New German Gleitz board
LigH is offline
Old 19th July 2016, 09:44   #2115  |  Link
real.finder
does avs+ has same avs limit of 50 active plugins at one time?
See My Avisynth Stuff
real.finder is offline
Old 19th July 2016, 12:52   #2116  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
IIRC, the limit was gone after 2.57.
Both avs2.6 and avs+ has no imit of number of loading plugins.
my repositories
Chikuzen is offline
Old 19th July 2016, 13:11   #2117  |  Link
real.finder
it still existing in 2.6, I see it in some of my tests in complex script
Old 19th July 2016, 13:34   #2118  |  Link
Groucho2004
Indeed. In plugin.cpp (2.6 and also 2.6.1):
enum { max_plugins=50 };
The plugin loading in AVS+ is quite different and from what I've seen, there's no plugin limit in the code (or maybe I didn't look thoroughly).
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 19th July 2016, 14:00   #2119  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
I will just put this link here. Dlls are fun.
Myrsloik is online now
Old 19th July 2016, 20:58   #2120  |  Link
ultim
AVS+ Dev
ultim's Avatar
In Avs+ there's no limit.
AviSynth+
ultim is offline
