25th February 2012, 14:07 | #9401 | Link |
Okay, yeah, there is a performance hit going on with the renderers and DXVA CopyBack vs. Native. I just tried in MPC-HC (later build) with EVR vanilla and again, flawless with both modes. Switched to madVR (for copyback) or EVR-CP and I get slideshows with CopyBAck mode. EVR-CP works fine too with Native mode. Same "birds" sample from above.
25th February 2012, 15:04 | #9403 | Link | |
What renderer are you using?
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
25th February 2012, 15:05 | #9404 | Link |
That specific problem would most likely only occur with EVR - if it even occurs for anyone else.
25th February 2012, 16:31 | #9405 | Link |
The new DXVA checker v2.8.0 (it's in beta) has fixed the problem with LAV Video and Basketball clip and it will support renderless VMR and EVR benchmark modes.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
25th February 2012, 18:36 | #9406 | Link |
I'm trying to watch a HD video file over HTTP over a DSL line. I know I have sufficient bandwidth to do that (more than 3x the bitrate of the video). I'm unable to get it working properly:
- By default, when opening a URL with DirectShow, it uses File Source (URL), which then gets attached to LAV Splitter. The video seems to play properly, but the displayed duration is completely wrong (fortunately, it keeps playing "past the end") and most importantly, I cannot seek. - If I use LAV Splitter Source in GraphStudio and give it the URL, the video plays very slowly, as if the link was too slow. If I try to seek, GraphStudio freezes. It would be great if LAV Splitter could play files over HTTP without issues. Also, I would like to be able to configure LAV Splitter so that it does massive buffering (e.g. 50 MB with 5 MB pre-buffer); this would greatly decrease the risk of buffer underruns when playing from a remote location, or even locally when the storage is under heavy load (e.g. playing video while copying files). Also, does anyone know how to make LAV Splitter Source the default when opening URLs in MPC-HC? |
25th February 2012, 19:15 | #9407 | Link |
The File Source (URL) isn't great on seeking, so if you have any format that requires seeks to gather all information (like most formats do), you might end up with a limited subset of information, like wrong duration.
LAV itself didn't actually have http support yet, i guess Windows somehow emulated it when it tried to opened a file with the name of a URL. I enabled http support (no https yet, need to fix the build system), and first tests look good. http://files.1f0.de/lavf/LAVFilters-0.48-http.zip You can use this reg file to force LAV as http source: http://pastebin.com/XUT3AjZe I'll have to check if there are better ways or if that one has side effects. Regarding buffering, there already is good buffering in place, at about 1000 video frames. In MPC-HC, enable the "Statistics" panel to see the queue status (Ctrl+4) I can probably think about increasing that in case of URL access, if its really required. On a Blu-ray sourced 1080p MKV, the buffer is around 110-120MB for those 1000 frames.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 25th February 2012 at 19:17. |
25th February 2012, 19:51 | #9409 | Link |
I suggest to sit on it, maybe something will hatch from it!
Anyhow, the CUVID decoder is a blackbox, can't look into it. Its all handled by the driver. (Try another one) Are you sure its really VC-1 and not WMV3 in disguise?
25th February 2012, 20:05 | #9410 | Link | |
It might hurt to sit on WD Caviar Black HDDs, so I won't do this.
But why should it work with DXVA and not CUVID? It plays, but with CUVID there's no VPU usage. Does CUVID not support WMV3 acceleration? I found out that it's just Windows Movie Maker output, so here is a short sample (8,5 MB): http://www.mediafire.com/?zpug3goyrj7fwnc |
25th February 2012, 20:12 | #9411 | Link |
The cuvid parser for some reason doesn't support wmv3, even though the hardware supports it.
25th February 2012, 20:22 | #9413 | Link |
I do not.
25th February 2012, 20:26 | #9415 | Link |
QuickSync only supports H264, MPEG2 and VC1. Not WMV3 and not MPEG4-ASP. It may support WMV3 HW accel in the future, but right now it doesn't. Its up to Intels driver team.
25th February 2012, 20:43 | #9417 | Link | ||
25th February 2012, 21:05 | #9418 | Link | |
Are you sure you installed it correctly?
