14th February 2008, 10:46 | #1041 | Link |
Kid for Today
that's the other way around, actually
Reclock is not compatible with Vista. but only Reclock can resample 23.976@24 and offer perfect timing in 48 Hz. I *do* need Reclock Last edited by leeperry; 14th February 2008 at 10:48. |
14th February 2008, 17:54 | #1044 | Link | |
My website: www.ernstblaauw.nl |
14th February 2008, 18:01 | #1045 | Link |
Kid for Today
14th February 2008, 18:07 | #1046 | Link |
ffdshow/AviSynth wrangler
now playing: [artist] - [track] ([album]) |
15th February 2008, 02:57 | #1047 | Link | ||
According to the developer of Zoom Player:
15th February 2008, 09:49 | #1048 | Link |
Anime Otaku
In my experience, ReClock is still needed. Just try to play a 29.97 fps video in a 60Hz screen and you'll see what I mean. Vista has a 59.97Hz refresh option, which unfortunately has been rendered useless, at least for Nvidia card owners.
AMD FX8350 on Gigabyte GA-970A-D3 / 8192 MB DDR3-1600 SDRAM / AMD R9 285 with Catalyst 1.5.9.1/ Asus Xonar D2X / Windows 10 pro 64bit |
15th February 2008, 16:32 | #1050 | Link |
MPC-HC Project Manager
r404 should fix a lot of problems for people using a lot of hd x264 files, could someone compile this version please? i would like to run some testst
from the changelog Code:
Revision 404 - Directory Listing Modified Thu Feb 14 20:02:01 2008 UTC (19 hours, 29 minutes ago) by casimir666 FIXED : H264 decode in software mode video with wrong SAR and too much ref_frame FIXED : VC1 startcode not added when already present in parser raw stream |
15th February 2008, 17:36 | #1051 | Link | |
15th February 2008, 17:50 | #1053 | Link |
Thanks, that works well with a few x264 files I tried which previously wouldnt play. They now default to SW mode.
Ive been digging through the past threads, but not sure what the problem is with the 1080p h264 files - why do they show in green ? Also, is this decoder likely to be released as a directshow filter so we can use it within MCE ? Thanks for the efforts, much appreciated by a lot of lurkers (like me !), Im sure.. |
15th February 2008, 17:52 | #1054 | Link |
Oz of the zOo
BUG:
1. start an empty MPCHC, a DVD video disc is in the only drive 2. Ctrl-D -- no movie is displayed, but a folder selection dialog appears 3. either choose DVD drive in the dialog or File - OpenDVD - MyDriveLetter (with DVD volume label there) 4. trash displayed, CPU usage 100%, pressing Ctrl-Shift-Esc to invoke TaskManager makes it appear in 5 seconds, another 5 secs to terminate mplayerc EVR custom, XPsp2en, nVidia 7600GT, ffdshow tryouts 27 dec, everything's fine with mplayerC 27.jan.08, all internal MPC/HC filters are off. update: after terminating previous instance with EVR: with HaaliRenderer: File-OpenDVD -- immediate app crash with SysDefault, VMR9rl: OK update2: mpchc + EVRcustom + nVidiaPureVideo works ok with dvd Last edited by wOxxOm; 15th February 2008 at 18:03. |
15th February 2008, 18:02 | #1055 | Link |
Then please grab Dependency Walker, open the problematic mplayerc.exe with it and tell us exactly which DLLs are missing.
I'd hazard a bet it's the Visual C++ 2005 SP1 redistributables, and including those files with MPC ain't gonna happen... np: Grad_U - Knob III (CMYK)
15th February 2008, 18:03 | #1056 | Link | |
What I do is enable dvd video title set and then I just open the IFO file from the dvd. That way, I don't have to worry about menus either. It's not a pretty solution but it works. |
15th February 2008, 18:17 | #1057 | Link |
Oz of the zOo
the fact that MPCHC's Ctrl-D does not immediately display the currently inserted (and the only present) DVD disc is frustrating and meaningless for me. MPC wins it :-)
MPC (/HC) has absolutely no problems with whatsoever part of Haali splitter/renderer (here). The crash was caused by previously terminated mpchc+EVR (after restarting the pc, MPCHC+HR+FFDShow plays ok File-DVD) btw EVR/custom (mpchc) works ok with usual avi/mkv movies (FFDshow+Haali splitter). Last edited by wOxxOm; 15th February 2008 at 18:20. |
15th February 2008, 18:45 | #1058 | Link | |
edit: just to be clear, the dvd is not encrypted |
15th February 2008, 19:05 | #1059 | Link | |
However, Visual Studio 2005 has a nasty habit of embedding a manifest into the executable by default. That manifest causes Windows to think that the runtime is needed. The solution would be to explicitly disable manifest creation and embedding in the project settings.
MPC-HC 2.1.7.2 |
15th February 2008, 19:26 | #1060 | Link | |
np: Joel Tammik - Vorm Ja Praegu (Intelligent Toys 4)
