Old 17th November 2012, 13:05   #941  |  Link
frencher
French Love
Originally Posted by Eseninzhiv View Post
how to use a plugin to create the raw video streams (left, right) in the format YUY2?
ldecod
BioMvc
It's old now and paying (BioMvc)
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial
Demo for MVC Player Free: Trailer 3D
3DBD's Free - v0.0.0.0005.exe Old
Programing free for all.
frencher is offline   Reply With Quote
Old 17th November 2012, 14:00   #942  |  Link
frencher
French Love
Jeeez other soft Huuuuuu
Old 17th November 2012, 15:45   #943  |  Link
Eseninzhiv
the best option
BioMvc paying?
Left_EYE.avs
DirectshowSource("C:\left.m2ts", fps=23.976, framecount=181762, audio=false)
ConvertToYUY2().AssumeFPS(24000,1001)
Right_EYE.avs
LoadPlugin("C:\bioMVC.dll")
right=bioMVCH264Plugin("C:\bioMVC.set",xxxxxx).assumefps(24000, 1001)
comb=right
return comb
bioMVC.set
InputFile = "C:\left.h264"
InputFile2 = "C:\right.h264"
FileFormat = 0
POCScale = 1
DisplayDecParams = 1
ConcealMode = 0
RefPOCGap = 2
POCGap = 2
IntraProfileDeblocking = 1
DecFrmNum = 0
one problem, I do not like
bioMVC.dll creates the right raw stream format YV12, i can not change that
I need YUY2 or .yuv
BioMvc
anybody can help to change the output format of the right stream?
Eseninzhiv is offline   Reply With Quote
Old 17th November 2012, 16:06   #944  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Can you upload BioMvc.rar elsewhere?
r0lZ
Old 17th November 2012, 18:35   #945  |  Link
Eseninzhiv
Now see what filters using MVC to AVI Converter
post Betaboy from CoreCodec Founder from 2nd May 2012
And whar about CoreMVC? I know it will be a different product but what's the reason for the delay? Is it technical or licensing issues?
CoreMVC 3D has been available for OEM/Developer licensing for over a year now. As far as a consumer decoder however we felt it was more important to get the last remaining features in CoreAVC before releasing it since its 99% based on it.
So we'll continue our non consumer CoreMVC 3D licensing for now and revisit the consumer directshow filter after 4:2:2 is added in v3.5 (Noting my previous post that we are jumping to v3.5 after v3.1 when we add 4:2:2.).
will wait
Old 18th November 2012, 00:01   #946  |  Link
frencher
French Love
the best option
BioMvc paying?
Left_EYE.avs
Right_EYE.avs
bioMVC.set
I need YUY2 or .yuv
BioMvc
3DBDBuster from http://www.biohemmet.se is the owner of bioMVC.dll
Old 18th November 2012, 04:26   #947  |  Link
frencher
French Love
@Neisklar
Is it possible to add the "Decombine" in your program "CombineMVC.exe" ?
Old 19th November 2012, 13:23   #948  |  Link
Eseninzhiv
why do you need it?
Old 22nd November 2012, 03:09   #949  |  Link
frencher
French Love
@Eseninzhiv
why do you need it?
Just to get the flow in case of need and in case of future upgrade of SSIFSOURCE, DirectShowMVCSource, etc...
Old 25th November 2012, 01:43   #950  |  Link
samfednik
2Neisklar
2slavanap
Hi, is there any work on your own plugin MVC?
Maybe you can do until the plugin based on DirectShow filters from Sonic (Mainconcept)?
I tried to extract using graphedit raw YUV stream (or lossles compression), and it is interesting that the right thread, too, like CoreMVC.dll extracted by 1 frame less than the present in it. This similarity - rather strange...
But plus DirectShow filters from Sonic (Mainconcept) that they understand raw .h264
Ie we can extract eac3to continuous left/right h264 stream of the film mpls, when the film is divided into several SSIF.
Tested on MiB3 - results:
eac3to v3.24
command line: eac3to.exe p:\BDMV\PLAYLIST\00800.mpls 2:Left1.h264 3:Right1.h264
M2TS, 2 video tracks, 7 audio tracks, 6 subtitle tracks, 1:45:49, 24p /1.001
1: Chapters, 16 chapters
2: h264/AVC (left eye), 1080p24 /1.001 (16:9)
3: h264/AVC (right eye), 1080p24 /1.001 (16:9)
4: DTS Master Audio, English, 5.1 channels, 16 bits, 48kHz
(core: DTS, 5.1 channels, 16 bits, 1509kbps, 48kHz)
5: AC3, Hindi, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
6: AC3, Kazakh, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
7: AC3, Russian, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
8: AC3, Tamil, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
9: AC3, Telugu, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
10: AC3, Ukrainian, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
11: Subtitle (PGS), English
12: Subtitle (PGS), Estonian
13: Subtitle (PGS), Hindi
14: Subtitle (PGS), Latvian
15: Subtitle (PGS), Lithuanian
16: Subtitle (PGS), Russian
[v02] Extracting video track number 2...
[v03] Extracting video track number 3...
[v03] Creating file "Right1.h264"...
[v02] Creating file "Left1.h264"...
Video track 2 contains 152232 frames.
Video track 3 contains 152232 frames.
eac3to processing took 21 minutes, 50 seconds.
Done.
Extracted (right eye) just like that, because the filters protections from the AVI mux:
The final video for the right eye turned by 1 frame less = 152231 frames, which is not so bad.
The left eye can be indexed DGindex, shorter use the old methods for AVC encoding.
samfednik is offline   Reply With Quote
Old 26th November 2012, 03:47   #951  |  Link
frencher
French Love
why do you need it?
For this problem
Download
Old 26th November 2012, 05:51   #952  |  Link
frencher
French Love
MVC Player Free - Tutorial
The download is in my signature...
Small tool for very fast preview and recode your 3D video files
Install Avisynth (min AVS 2.6.0 Alpha 5 [130918]) and latest ffdshow for perfect works
Fix for: View/Resizing/Do not resize ffdshow video decoder choose all supported format
Extract and run directly MVC Player Free.exe or play associated file with MVC Player Free.exe
/!\ It is strongly recommended to work from an iso and unencrypted
Use Virtual Drive for Play and Recode if difficutly on the fly with BD-ROM drive with index.bdmv and .mpls files...just select one file from playlist.
Drag and drop your file to "MVC Player Free"...
...or use "Open File" (CTRL+O).
If you have this error with audio tracks, try this. (uNicAudio.dll + Source Code.rar for update "DirectShowMVCSource.dll")
Your choice can be seen and re-encoded
By default, resize of video is 1920x1080p.
Preview may not work if more than 1920x1080p but re-encoding is not a problem.
You can export Preview.avs to .h264 and .yuv
If re-encoding does not start is that "avisynth" does not support more than 7 .m2ts or .ssif in a playlist.
To do this you must:
- Demuxing your stream with eac3to
- Combine with CombineMVC (left and right eye)
- Remux the file .ts .mts .m2ts
- Open the resulting file (.ts .mts .m2ts) with MVC Player Free
All suggestions are welcome
Old 27th November 2012, 06:32   #953  |  Link
frencher
French Love
"MVC Player v0.0.0.2" In my signature...
Extract and run MVC Player.cmd
# Remove mplayer for windows api to increase speed
# Added commands: Load, Play, Pause, Stop
# Quick Edit File "AVS"
# Display the elapsed time and total time
# Display the status of "MVC Player"
# The full screen is now supported (double click)
# Suppression of the controls for a more convenient preview
# The real-time resizing the window now possible
# Reduced file size
Should now be able to synchronize the audio (ac3, dts, etc) and subtitles (PGS. Sup,. Srt, etc) in the AVS for proper rendering.
If someone idea I'm interested
@Neisklar
Very nice works for CombineMVC.exe.
Pending news
Old 28th November 2012, 05:48   #954  |  Link
frencher
French Love
I did some tests but I do not know much about the Avisynth filters ...
I still managed to read the video and audio but only outside the "mts".
If you have a better solution with other filter(s) to read directly from the file "mts", which you must choose it and what is the avisynth code.
Attached:
- MVC Player v0.0.0.2 Video + Audio Test 1.rar
Run MVC Player.cmd and Load
- uNicAudio.dll + Source Code.rar
Audio filter of my test
The possibility of "Seek" will be added in the next version of the interface
Old 28th November 2012, 07:10   #955  |  Link
frencher
French Love
"MVC Player v0.0.0.3" In my signature...
Don't look the design of player
Extract and run MVC Player.cmd or play associated file with MVC Player.exe
# Play now with Audio (DirectShow) temporary
# The association is now possible with MVC Player.exe with (mts, mp4, ssif, etc...)
# Full control (volume, seek, mute) are ready just don't use "Play" of interface only button "Load"
Should now be able to synchronize the audio without Direct Show filters (ac3, dts, etc) and subtitles (PGS. Sup,. Srt, etc) in the AVS for proper rendering.
If someone idea I'm interested.
Knowledge is only if it is shared
Old 29th November 2012, 05:22   #956  |  Link
frencher
French Love
"MVC Player v0.0.0.4" In my signature...
# Ability to enable or disable the audio track (some audio may be difficult with DirectShow, me DTS Tracks)
# Save the size of the window leaving MVC Player
# Some fixes
Old 29th November 2012, 20:52   #957  |  Link
Wolfy59
Originally Posted by samfednik View Post
2Neisklar
2slavanap
eac3to v3.24
Done.
Hi all I can t connect smart tee to lagarith losseless codec
is there something to change before connect the two filters ?
Thanks
Wolfy59 is offline   Reply With Quote
Old 30th November 2012, 09:49   #958  |  Link
Eseninzhiv
@frencher
thanks a lot!
you can add a function to converting in uncompressed AVI and YUV?
certainly better YUV, since avi is able to do MVC to AVI Converter
a paid solution, but there's no 3D support
YUV Convert
Old 1st December 2012, 00:56   #959  |  Link
frencher
French Love
Use this AVS Script with avs2avi.exe
You can still download it from moitah's own domain though
Why don't use x264 lossless ? -qp 0
LoadPlugin ("DirectShowMVCSource.dll")
File   = "Video_Source.mts"
Left   = DirectShowMVCSource(File, decodeleft=TRUE)
Right  = DirectShowMVCSource(File)
Video  = StackHorizontal(Left, Right).BicubicResize(1920,1080).AssumeFPS(24000, 1001).ConvertToYV12()
Return Video
Old 3rd December 2012, 19:32   #960  |  Link
Eseninzhiv
I do not need AVI
this makes the MVC to AVI Converter
I would like to receive from the SSIF --> two files with the extension YUV (4:2:0 planar)
YUV Convert
