28th October 2011, 07:42 | #10461 | Link | |
How do I post a log? |
28th October 2011, 09:21 | #10464 | Link |
As far as I know, all cinema movies are recored with 24 fps and are just slowed down to 23.976 for some NTSC compatibility reasons. Direct-to-video releases and television shows might be 23.976 natively, don't know about that.
28th October 2011, 19:08 | #10465 | Link |
soy sauce buyer
10-bit 4:2:2 sample:
BBB422p10-rr3.rar Has anyone reproduced the crash decoding this file with madVR's internal libav? |
28th October 2011, 23:07 | #10466 | Link |
HELP!
just changed from ATI to NVIDIA GT 430 and playback has gone jerky! i have tried custom resolutions but cannot get 23.976 spot on Plus, after creating a custom Resolution i cant set the desktop at 50hz and get MadVR to switch for me beginning to regret moving to Nvidia Last edited by pacemaker1000; 28th October 2011 at 23:10. |
29th October 2011, 03:10 | #10469 | Link | |
Yesterday I overclocked my HD5670, but only in terms of increasing the minimum core and memory clocks so that it never downclocks hard. Played movie and some concert through it in full lenght ( Sony Bravia @23Hz ). Results: movie 150 min - 0 frame drops, concert 1 frame drop in 100min lenght. Need to test movies, where long slow scenes are changing with action panning scenes. 0.77, Lavfilters 0.38RC, MPC-HC latest, Reclock, 11.10RC3 CCC. I have presentation queues 8-8/8 with occasional change to 7-8/8 when using PC Monitor ( DELL U2311H ). When switching to Sony Bravia, I get only 6-7/8, but looked stable. Will test more on monday. Pluto
__________________ System: Intel Core i5-6500, 16GB RAM, GTX1060, 75" Sony ZD9, Focal speakers, OS Win10 Pro, Playback: madvr/JRiver |
29th October 2011, 08:41 | #10470 | Link | |
@Rahzel: And the Presentation Glitches I had are gone after a fresh install of W7, also with a custom made resolution I don t have problems anymore. Maybe it has something to do with XBMC running in the background which I haven t installed yet on my fresh W7 install but I ll test this later today. Last edited by THX-UltraII; 29th October 2011 at 08:44. |
29th October 2011, 10:16 | #10472 | Link | |
I know we will get answers from users that swear by htpc audio decoding and reclock use but I need bitstreaming so that s not an option for me Last edited by THX-UltraII; 29th October 2011 at 10:21. |
29th October 2011, 10:34 | #10473 | Link |
If you setup a good custom resolution, you can get perfect playback. With ATI you may have a better out-of-the-box setup, however if thats not good for you, you have no way to adjust it. Take your pick.
29th October 2011, 11:24 | #10474 | Link |
that s the problem: I can t get a custom resolution with perfect playback. Choosing 23,976 gives a actualy refresh rate of 23,97495 (reported my madVR). Strange thing is that 23,977 gives the exact same reported refresh rate by madVR. Choosing 23,978 as custom resolution/refresh rate in the nvidia control panel results in 23,978xx reported by madVR. The best I can get is choosing 23,976 in nvidia which gives me a '1 frame dropped every 8,30 minutes' while ATI reported 1 frame dropped every 16-20 hours!.
29th October 2011, 11:25 | #10475 | Link |
is that what the OSD says or the actual dropped frame count? in the end, there might be a difference between those two.
29th October 2011, 11:30 | #10476 | Link | |
Also, like Thunderbolt8 says, don't trust madVRs estimate. Watch some movie and see if there really are frame drops.
29th October 2011, 11:46 | #10478 | Link | ||
29th October 2011, 11:49 | #10479 | Link |
Try increasing or lowering the total vertical pixels. But do it only one or two at a time, those settings can have varying effects.
29th October 2011, 12:18 | #10480 | Link | |
Changing it and LOWERING it from 1125 (which was the standard value in my nvidia settings) to eg. 1120 resulted in heavy stuttering. Changing it from 1125 to 1130 gave my no stutter and resulted in a refresh rate reported by madVR from 23,97480 to 23,97487. So I changed it from 1125 to 1160 and madVR reports 23,97560 which is already much better. Going above 1160 results in a blank/blue screen (JVC RS25 projector) so getting to 23,97600 is not possible this way it seems. Second problem is that my screen does not 'fit' anymore: my taskbar is almost gone with 1160 now and the top of my screen is not filled. |
