12th January 2008, 07:20 | #2601 | Link | |
also PROCODER 3 can convert the m2ts from a bluray file directly (havent tried from a disc yet). no remuxing required. im still testing but did a short sample and it seems to work fine. audio and video. Last edited by nincollector; 12th January 2008 at 11:43. |
12th January 2008, 10:31 | #2603 | Link | |
If you use eac3to feature_1.evo+feature_2.evo you should see info about video and audio. As eac3to can't read the files I can't demux/remux anything... |
12th January 2008, 10:41 | #2604 | Link | |
12th January 2008, 10:44 | #2605 | Link | |||
12th January 2008, 11:00 | #2608 | Link |
I intentionally didn't implement any features like that because it would open up a can of worms for new bugs and I'm not really willing to spend much time on debugging problems related to features that I don't really find all too important. If you want to remove some streams of an EVO file then EvoDemux should do the trick just fine. I'm not planning to add this kind of feature to eac3to.
13th January 2008, 00:34 | #2612 | Link |
Hi! Question concerning David Gilmour Blu-Ray Concert Disc:
I've demuxed TrueHD from mpa file using xport; converted to FLAC using latest eac3to, and then muxed it with my own x264 encode along with LPCM track. LPCM plays fine, but TrueHD goes out of sync ~ middle of concert 1-1.5sec. As I understand, DTS from x264 encode had no problems. I have tried madFlac and FFdshow Audio decoder, both had exact off-sync issues on this concert.. Could someone explain what could be the problem? Last edited by yfed; 13th January 2008 at 03:38. |
13th January 2008, 07:24 | #2613 | Link |
stdout not working with TrueHD?
I've been using eac3to's stdout into neroaacenc to transcode HD-DVD e-ac3 tracks to aac, without problem, using a batch file like this:
C:\eac3to "C:\PEVOB_1.EVO"+"C:\PEVOB_2.EVO" 3: stdout.wav | C:\neroAacEnc_SSE.exe -q 1.0 -ignorelength -if - -of "E:\output.mp4" Code:
stdout.16bit.wav stdout.24bit.wav and BTW why does it output to the two files? |
13th January 2008, 09:20 | #2614 | Link | |
13th January 2008, 09:23 | #2615 | Link | |
This has been explained multiple times in this thread. Basically there's a chance that the TrueHD decoding is 16bit or 24bit. eac3to doesn't know until the whole decoding is done. So after decoding eac3to keeps the WAV file with the correct bitdepth and deletes the other one. |
13th January 2008, 11:18 | #2616 | Link |
madshi,
Wouldn't be easier to add support for ogg and aac like ac3 and flac? I mean drop the appropriate encoder into eac3to directory and type something like: Code:
eac3to input.* output.ogg or aac |
13th January 2008, 13:48 | #2617 | Link | |
This work for me: Code:
eac3to 6chan.wav stdout.wav | neroaacenc -q 0.5 -if - -of 6chaac.mp4 eac3to 6chan.wav stdout.wav -0,2,1,4,5,3 | oggenc2 -Q -q 5 - -o 6chogg.ogg Code:
eac3to 6chan.ac3 stdout.wav -libav | neroaacenc -q 0.5 -if - -of 6chaac.mp4 eac3to 6chan.ac3 stdout.wav -libav -0,2,1,4,5,3 | oggenc2 -Q -q 5 - -o 6chogg.ogg Code:
eac3to v2.14 eac3to 6chan.ac3 stdout.wav -libav -0,2,1,4,5,3 AC3, 5.1 channels, 0:00:20, 448kbit/s, 48khz Remapping channels... Remapping channels... Loading white noise (needed for dithering)... Writing WAV... Creating/writing file "stdout.wav"... Writing the destination file failed. EDIT: of course this work for me eac3to 6chan.ac3 out2.wav -libav -0,2,1,4,5,3 (not problem with -libav decoder) EDIT2: and same problem using like input .thd, .mlp, .eac3 or .dts Last edited by tebasuna51; 13th January 2008 at 23:43. |
13th January 2008, 17:30 | #2618 | Link |
Turkey Machine
Small feature request if possible: merging 6 separate FLACs to a 5.1 FLAC. Currently, eac3to doesn't do this, nor does FLAC.exe.
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld |
14th January 2008, 00:23 | #2619 | Link |
The following is the error message sent by eac3to GUI while trying to extract audio from an EVO file.
D:\EAC3>eac3to.exe "F:\FEATURE_1.EVO" "F:\Working\convert Feature1" -448 -nero EVO, 2 video tracks, 5 audio tracks, 0:50:02 1: VC-1, 1080p24 /1.001 2: VC-1, 480p30 /1.001 3: TrueHD, 5.1 channels, 48khz, dialnorm: -27dB 4: E-AC3, 5.1 channels, 384kbit/s, 48khz, dialnorm: -27dB, -17ms 5: E-AC3, 5.1 channels, 384kbit/s, 48khz, dialnorm: -27dB, -17ms 6: E-AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB, -17ms 7: E-AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB, -4ms This audio conversion is not supported. Is this because I do not have the Nero Blu-Ray/HD DVD Plug-in or is because these files use 384kbits, or something else? Any help would be appreciated. |
14th January 2008, 00:54 | #2620 | Link |
I don't think the gui is updated to support the newer eac3to versions.
Anyway the command is totally wrong. Have a look in the first post and don't use the gui this time. Without the plug in, the nero decoders don't work so you have to use another decoder. If i understand correctly, what you want to do is to create an ac3 file (from the truehd track). Then you have to type: Code:
eac3to "F:\FEATURE_1.EVO"+"F:\FEATURE_2.EVO" 2: "F:\Working\your.output.file.ac3" -448 |
eac3to |
