Old 27th October 2009, 17:07   #501  |  Link
Joshua81
Thanks a lot, now it seems to work. Interestingly, MeGUI responds very slowly, but I can live with that.
Joshua81 is offline   Reply With Quote
Old 28th October 2009, 10:28   #502  |  Link
Audionut
Hi neuron2.
Could you update the log to display the stream type.
Stream Type: Matroska
Profile: High
Level: 4.1
Coded Size: 1280x720
SAR: Unspecified
Display Size:
Frame Rate: 23.976024 fps
Colorimetry: BT.709* [2]
Frame Structure: Frame
Frame Type: I
Coded Number: 61297
Playback Number: 61297
Frame Repeats: 0
Field Repeats: 0
Bitrate: 0.215
Bitrate (Avg): 3.206
Bitrate (Max): 6.668
Audio Stream: 2: A_AC3 48000 6ch "und"
Elapsed: 0:01:57
Remain: 0:00:00
FPS:
Info: Finished!
http://www.7-zip.org/
Old 29th October 2009, 00:13   #503  |  Link
Yes, will do, I missed that as I usually have my log disabled.
Old 29th October 2009, 14:53   #504  |  Link
VincAlastor
in megui ...56 on win7 x64 (admin) appears an error if megui try to open the cuvid sever (200b1). the error: "Cannot run CUVID Server executable... are you sure is it installed?" - i have set an dgNV directory in the megui tools area, and have copied the hole dgdecnv200b1 package. in the megui settings i have set the new program paths and in avisynth plug-in directory i have copied the new .dll's. where is my mistake?
VincAlastor is offline   Reply With Quote
Old 30th October 2009, 00:33   #505  |  Link
You are using MEGUI.
Old 30th October 2009, 03:33   #506  |  Link
squid_80
When I use the latest DGIndexNV.exe to demux a VC1 ES from a .m2ts file, the output file seems to use start codes that are 5 bytes long (00 00 00 01 XX). It seems several programs don't like this (mkvmerge, vc12avi) and the older stand-alone version DGVC1Index.exe (1.0.7 beta 10 is what I found on my HD) creates elementary streams with 4 bytes start codes (00 00 01 XX). Was there a reason for switching to 5 bytes?
squid_80 is offline   Reply With Quote
Old 30th October 2009, 11:42   #507  |  Link
It's a bug as a result of the merger. I'll fix it when I get back home this weekend. I'm out of town right now. Thanks for pointing it out.
Old 31st October 2009, 08:00   #508  |  Link
turbojet
I'm looking forward to the force film option. Is there a chance nvidia's inverse telecine could be implemented as well?
Also any chance for CUVID server to open/close on demand?
Old 31st October 2009, 09:16   #509  |  Link
Not unless it is added to the API by Nvidia.
I don't understand your question.
Old 31st October 2009, 09:34   #510  |  Link
Audionut
I was meaning to ask this also.
ie: you open an avs file and the cuvidserver loads automatically.
Old 31st October 2009, 09:38   #511  |  Link
turbojet
OK hopefully they will as it's pretty decent.
Instead of having to open/close CUVID server it would open CUVID when DGsource.dll is called from avisynth and close when it's no longer needed.
Another thing is it possible to add resizing to dgindexnv?
A resize to 1280x with the updated resolution in the cropping filter window would be plenty for my needs.
EDIT: Actually since this will be very useful for DVD's when force film is added it would be helpful to have a mod8 width and height resize selector as well.
Old 31st October 2009, 13:05   #512  |  Link
J_Darnley
J_Darnley's Avatar
I have been experiencing a crash with this sample using NVTools betas 10 and 11 and also with 2.0.0 beta 1. It was ripped from my DVD of The Forbidden Kingdom (R2 PAL) using DVDDecrypter in IFO mode.
I initially tried to load all 7 vob pieces into the indexers but after they all crashed near the beginning I tried just the first vob, and when that failed as well, I cut it down to this small sample. I have tried ripping it again to see if it was a ripping problem but I still experience the crashes.
They all crash on (when the status window says) frame 503.
The Windows' error dialogs contain the following
NVTools beta 10:
AppName: dgmpgindexnv.exe AppVer: 1.0.3.0 ModName: dgmpgindexnv.exe
ModVer: 1.0.3.0 Offset: 0000a7c5
NVTools beta 11:
ModVer: 1.0.3.0 Offset: 0000a7e5
2.0.0 beta 1:
AppName: dgindexnv.exe AppVer: 2.0.0.0 ModName: dgindexnv.exe
ModVer: 2.0.0.0 Offset: 0000dbc5
sample: http://users.telenet.be/darnley/avis...vts_01_1_0.vob
Can you tell me when you have it so I can remove it? Also tell me if it "disappears" from there and I will upload it to mediafire.
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 31st October 2009, 17:48   #513  |  Link
You can remove it.
I have it fixed and will update the beta shortly.
Old 31st October 2009, 18:47   #514  |  Link
I refreshed the 2.0.0 beta 1 with these fixes:
1. Output 3-byte start code prefix for MPG and VC1 when demuxing. It was erroneously outputing 4-bytes prefixes.
2. Added the Video Type to the log file.
3. Fixed indexing crash for field structured MPEG streams where the first two field pictures are IP.
Old 31st October 2009, 20:31   #515  |  Link
menlvd
Nvtoolz not working with latest NVIDIA ForceWare 195.39 Beta WXPx64
menlvd is offline   Reply With Quote
Old 31st October 2009, 20:35   #516  |  Link
"not working" means what, specifically?
Old 31st October 2009, 20:50   #517  |  Link
menlvd
when run dgindexnv
don't instal new drivers, simple copy new version of nvcuvid32.dll & nvcuda32.dll to sys32 and then rename to nvcuda.dll & nvcuvid.dll
Old 31st October 2009, 21:43   #518  |  Link
GZZ
not sure beta driver are supported, use only the official releases.
GZZ is offline   Reply With Quote
Old 31st October 2009, 23:32   #519  |  Link
What is this, a joke?
Old 1st November 2009, 11:32   #520  |  Link
VincAlastor
DGDecNV is integrated in MeGUI, don't you think you could help kurtnoise to solve the errors? some people just buy DGDecNV licenses to use it in MeGUI...
