Old 26th January 2019, 19:33   #3221  |  Link
Revan654
Revan654's Avatar
Originally Posted by _Al_ View Post
Hi, I know this is wrong:
clip = core.resize.Bicubic(clip, vs.RGB24)
but it causes crash for all apps loading script, that error is not caught by script evaluations, perhaps vs.RGB24 is being loaded into wrong place. It gives out legit VideoNode though. RAM overruns even with core.max_cache_size set.
Your missing format syntax. You should only leave out the syntax if you know exactly the order of the variables are.
clip = core.resize.Bicubic(clip, format=vs.RGB24)
You could also Use this:
clip = core.fmtc.resample (clip, css="444")
clip = core.fmtc.matrix (clip, mat="709", col_fam=vs.RGB)
clip = core.fmtc.bitdepth (clip, bits=8)
Revan654 is offline   Reply With Quote
Old 26th January 2019, 22:43   #3222  |  Link
_Al_
Yes, I wanted to bring up if anyone makes this line it freezes and crashes, because Vapoursynth takes 2000010 (id for vs.RGB24) as width.
Argument width, does not have to be explicitly stated, width=something. But that resize is quite complex thing. Color spaces conversions etc., maybe it should be mandatory to state width=something, format=something. Not gravely important, sure.
This is one of those things to repel newcomers to use Vapoursynth. Resize is almost used in every script. So format has to be specified, but not width, not a consistent somehow. It is hard to understand if you are a video guy, not a programmer. But again, I do not expect this to be fixed, I take it as a flag if someone googles it or whatever.
_Al_ is offline   Reply With Quote
Old 26th January 2019, 23:19   #3223  |  Link
poisondeathray
No pathway . That's the error message.
If "clip" is YUV, you need to specify matrix_in_s="709" (or whatever matrix) , if it's not already specified in the clip props
Old 26th January 2019, 23:40   #3224  |  Link
_Al_
I understand that. It took me some hours though to figure that out last year. It takes that value from props, if it is usable, it uses it. Sometimes it is in props , sometimes not, it depends if source filter registers that taking it from video. If not , it has to be specified, if it is needed and not specified error is returned. Which in a sense is great, because we do not want to have any defaults in background going on. If those values loaded by source plugin taken from video are correct ones is another issue of course.
Also values in props are numerical (int) and to get corresponding string value, other script lines are needed to put it on screen. Which you of course can mess you up if you are learning it. :-) matrix table of numerical values with corresponding string values:
matrix_ITU = {0:'rgb', 1:'709', 2:'unspec', 3:'reserved', 4:'fcc',
           5:'470bg', 6:'170m', 7:'240m', 8:'ycgco', 9:'2020ncl',
          10:'2020cl' , 100:'OPP',
matrix_USABLE_ITU = ['709', 'fcc', '470bg', '170m', '240m', 'ycgco', '2020ncl', '2020cl', 'OPP']
myrsloik website explains that but those numbers are not matching, I pulled them from here
page 430 Table E.5 Matrix coefficients interpretation
Old 27th January 2019, 00:31   #3225  |  Link
lansing
Yup the error handling is missing, it should return the error instead of crashing the program.
Old 27th January 2019, 01:55   #3226  |  Link
qyot27
qyot27's Avatar
The problem was that the parameter order wasn't obeyed, so when you told it width=vs.RGB24 (which is what you did by omitting actual width and height and then not explicitly declaring format=), it did exactly what it was told and interpreted 'vs.RGB24' as an integer.
video,848,480,vs.RGB24 = this will work
video,vs.RGB24 = this won't work
AviSynth works exactly the same way concerning parameter order - if you drop one parameter in the middle, everything after that requires explicitly declaring the parameter name too for the values to be set to the right option.
The actual source of the immediate crash is that resizing to 2 million pixels wide is going to cause problems *somewhere* in the chain.
Old 1st February 2019, 05:33   #3227  |  Link
asarian
Can you set a (vertical) offset to core.sub.ImageFile? Really looking to lower the subs a bit.
Gorgeous, delicious, deculture!
asarian is offline   Reply With Quote
Old 1st February 2019, 13:01   #3228  |  Link
jackoneill
unsigned int
jackoneill's Avatar
No, but if you pass blend=False you get only the subtitles, and you can use Crop and AddBorders to move them. Of course then you have to blend them manually with your video clip.
http://www.vapoursynth.com/doc/plugins/subtext.html
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 1st February 2019, 15:11   #3229  |  Link
asarian
I tried to whip out the old SupTitle.dll (as I remembered it can do 'relocation'), but that wouldn't run somehow:
core.avs.LoadPlugin ("C:/VS/plugins/SupTitle.dll")
Should still work, right?!
EDIT: Yeah, that's an old 32-bit filter. Nevermind.
Old 2nd February 2019, 02:25   #3230  |  Link
lansing
Would it be a good idea for vapoursynth to implicitly set the value of an argument to its default value when we declared it without giving it a value? Something like this
fm = core.vivtc.VFM(clip, order)
instead of this
fm = core.vivtc.VFM(clip, order=0) # assuming 0 is the default
Sometime when I'm testing a filter, I would display all its arguments with vs editor's autocomplete feature, and I don't want to go into the manual to enter the default value manually for everyone of them.
Old 3rd February 2019, 13:07   #3231  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I was trying to load pinterf's MVTools2 build in Vapoursynth, but the functions don't appear in the avs namespace (using core.avs.MAnalyze just says that the function doesn't exist). I get this error in the VapourSynth Editor log, is it the reason?
Avisynth Compat: varargs not implemented so I'm just gonna skip importing MStoreVect
Old 3rd February 2019, 18:47   #3232  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Support for avisynth mvtools was removed in R40 due to the ugly hacks needed that slowed down all avisynth filter creation. And and a native version has existed for a long time now.
You can probably grab the avscompat.dll from R39 and use that if you really want to test things though.
Myrsloik is offline   Reply With Quote
Old 3rd February 2019, 19:51   #3233  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Thanks, looks like I'll skip it then. I was just thinking about testing it in case Zopti starts crashing the native plugin which probably doesn't have all the fixes and tweaks from the AVS version. It's been quite some time since the last commit.
Old 3rd February 2019, 20:03   #3234  |  Link
Myrsloik
Myrsloik's Avatar
Just report the bugs you find and they should probably get fixed quite quickly.
Old 3rd February 2019, 22:26   #3235  |  Link
gonca
https://forum.doom9.org/showthread.php?t=154696
gonca is offline   Reply With Quote
Old 3rd February 2019, 23:04   #3236  |  Link
zorr
The latest released version crashes... a lot. I recommend using the version jackoneill shared after fixing this issue (download link available at that url).
I have another issue open, hopefully that one can be fixed as well. But I totally understand it can take time, the author is doing this on his free time after all.
zorr is offline   Reply With Quote
Old 4th February 2019, 05:32   #3237  |  Link
Fabulist
Hello,
May I ask if there is some kind of guide or documentation to help me make VapourSynth work with PotPlayer (more specifically, with madVR/SVP)? I have been researching this for days; I run multiple different installations of both VapourSynth and PotPlayer, seemingly appropriate, but I simply cannot make it work with PotPlayer itself, and of course not with anything else - I have no idea what I am missing.
Sorry to bother, and I am sorry if this is not the right place to ask.
Fabulist is offline   Reply With Quote
Old 12th February 2019, 07:31   #3238  |  Link
hydra3333
Intel claim to speed up python runtime by 20x, for free
https://www.infoworld.com/article/33...lq_cid=4495538
Intel’s distribution is a tuned version of the open source Python we all normally use. It’s been prebuilt to deliver much higher performance by a variety of methods, but most importantly by relying on the Intel Performance Libraries to accelerate x86 and x86-64 performance. This means that performance improvements can come without changing our Python code.
I suppose this does not have any relevance to vapoursynth ?
Cheers
Old 12th February 2019, 11:17   #3239  |  Link
asarian
Cheers
Probably none. The real work is done in the filters.
Old 13th February 2019, 14:17   #3240  |  Link
RainyDog
Vapoursynth newbie here.
Can anyone help me get this bbmod AVS port to work please?
I assume it should be something along the lines of the below syntax but with the correct instruction to replace the *?
clip = core.*.bbmod2(c, cTop = 0, cBottom = 0, cLeft = 0, cRight = 0, thresh = 128, blur = 999)
RainyDog is offline   Reply With Quote
speed, vaporware, vapoursynth
