22nd January 2007, 13:16 | #201 | Link |
Happy Easter!
I demuxed a vc1-stream with the demux tool offered here,then i try to mux it into mkv with Haali , but this process is taking a incredible long time , is that normal ?
Sorry for my terrible English! I am from Germany. |
23rd January 2007, 13:22 | #206 | Link | |
23rd January 2007, 15:45 | #209 | Link |
When using a graph or player to render evo files, how to choose audio track ? If we have 2 or 3 audio tracks on the evo file, how to select track 2 or 3 ?
I've the same problem using software when playing decrypted evo files, PDVD6.5 for exemple, unable to select audio track .... |
23rd January 2007, 16:50 | #210 | Link |
@lordx: you can't that's why we need demux ...
I have been playing around Serenity' mianintro.evo and ape's idea, and it seems that Sonic filters is defenetly output 24 fps ! graph: mainintro.evo -> sonic demuxer -> sonic video decoder avs: DirectShowSource("MAININTRO.grf", audio=false, fps=24, seek=true, seekzero=false, framecount=1550) LanczosResize(1280,720) ConvertToYV12() Info() So it gives the 01:04:528 time, which is good. Q: How do we know if it produce the correct frames? A: try a larger framecount value (eg: 2300), and see that after the intro (01:04:528) it gives us grey color picture !!! So the tricky part is how we get the correct framecount ! Maybe ape can help us in this. If you give smaller framecount value it cuts the stream at the given point... It's okay with single files, but not with multiple evos So we must know the correct framecount ... I'll try this method with Serenity feauture_1.evo to see if it's correct ... |
23rd January 2007, 22:36 | #212 | Link | |
if an XPL file contains this: Code:
... <TitleSet timeBase="60fps" tickBase="24fps" ... ... <Title titleNumber="1" alternativeSDDisplayMode="letterbox" titleDuration="01:58:54:22" ... |
23rd January 2007, 23:00 | #214 | Link |
if it is 1h, 58m, 54s, 220ms then its 7134.22sec
@24fps, thats 171221,8 frames (give or take :P) for 257638 frames we need a movie of 2 h, 58m, 54s, 916ms, which is about an hour less than titleduration. so please stop using Calc for windows!!! Last edited by mixanobios; 23rd January 2007 at 23:01. Reason: calc |
23rd January 2007, 23:18 | #215 | Link | |
$ ./ffmpeg -i DELSCENE1.EVO -acodec copy -vcodec copy DELSCENE1.avi FFmpeg version SVN-r7676, Copyright (c) 2000-2006 Fabrice Bellard, et al. configuration: libavutil version: 49.2.0 libavcodec version: 51.29.0 libavformat version: 51.8.0 built on Jan 23 2007 17:04:42, gcc: 4.1.2 20061115 (prerelease) (Debian 4.1.1-21) Input #0, mpeg, from 'DELSCENE1.EVO': Duration: 00:00:29.8, start: 0.037278, bitrate: 7487 kb/s Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480, 9800 kb/s, 29.97 fps(r) Stream #0.1[0xc1]: Audio: 0x0000, 48000 Hz, stereo, 192 kb/s Stream #0.2[0xc0]: Audio: 0x0000, 48000 Hz, stereo, 192 kb/s Stream #0.3[0x22]: Subtitle: dvdsub Stream #0.4[0x21]: Subtitle: dvdsub Output #0, avi, to 'DELSCENE1.avi': Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=2-31, 9800 kb/s, 29.97 fps(c) Stream #0.1: Audio: ac3, 48000 Hz, stereo, 192 kb/s Stream mapping: Stream #0.0 -> #0.0 Stream #0.1 -> #0.1 Press [q] to stop encoding frame= 896 q=1141135.2 Lsize= 25845kB time=29.9 bitrate=7089.7kbits/s video:25092kB audio:700kB global headers:0kB muxing overhead 0.204367% It can parse EVOs with VC1 streams in it, but it can't write them properly. This is the output from an EVO with VC1: Code:
$ ./ffmpeg -i sample.evo -acodec copy -vcodec copy sample.avi FFmpeg version SVN-r7676, Copyright (c) 2000-2006 Fabrice Bellard, et al. configuration: libavutil version: 49.2.0 libavcodec version: 51.29.0 libavformat version: 51.8.0 built on Jan 23 2007 17:04:42, gcc: 4.1.2 20061115 (prerelease) (Debian 4.1.1-21) Seems stream 0 codec frame rate differs from container frame rate: inf (1/0) -> 90000.00 (90000/1) Input #0, mpeg, from 'sample.evo': Duration: 00:00:10.6, start: 0.038278, bitrate: 11808 kb/s Stream #0.0[0xfd55]: Video: vc1, 90000.00 fps(r) Stream #0.1[0xc3]: Audio: 0x0000, 48000 Hz, stereo, 192 kb/s Stream #0.2[0xc2]: Audio: 0x0000, 48000 Hz, 5:1, 768 kb/s Stream #0.3[0xc1]: Audio: 0x0000, 48000 Hz, 5:1, 768 kb/s Stream #0.4[0xc0]: Audio: 0x0000, 48000 Hz, 5:1, 1536 kb/s Output #0, avi, to 'sample.avi': Stream #0.0: Video: 0x0000, q=2-31, 90000.00 fps(c) Stream #0.1: Audio: ac3, 48000 Hz, stereo, 192 kb/s Stream mapping: Stream #0.0 -> #0.0 Stream #0.1 -> #0.1 [avi @ 0x843f914]dimensions not set Could not write header for output file #0 (incorrect codec parameters ?) Last edited by Rufus210; 23rd January 2007 at 23:25. |
24th January 2007, 01:59 | #217 | Link |
hey guys is installing scenarist the only way you can get the codecs to work? I'm having trouble installing the program, as soon as I open setup.exe it gives me an error saying that my configuration does not support any of the included products.
